Question about Honda Garden
Oil fill for Honda GX390 reduction case
Where is the location of the reduction box oil fill on the Honda GX390 generator
sschoemann
  • 150 Answers
SOURCE: Add auto idle to generator
Your genny should already have this feature as it is part of the function to maintain the output voltage, if it isnt working I would look for a service manual for it and taker it from there as there can be many things that could prevent it from working properly
Posted on Dec 31, 2008
frcs68
  • 1605 Answers
SOURCE: Where can I find an owners manual for a Black Max
low oil sensor will not cause the motor not starting.
most likely is th ground wire.
you can try to attach that wire to any surface and try to start it. of it start, then you have to dis-assemble the head and find out where the wire should be attached.
if not, the wire is attached to a hot side. either way you have to dis-assemble the head.
http://www.honda-engines.com/engines_owners_manuals/ownersmanuals/gx390.htm
here is the site for the manual.
Posted on Apr 07, 2009
  • 225 Answers
SOURCE: honda 5.5 generator gas is filling oil compartment when not in us
turn the fuel off when not in use,it is going through the carb.to the oil.
Posted on May 31, 2009
Richie_asg1
  • 1036 Answers
SOURCE: honda generator gx390 will only run with the choke
Most problems like this are a fouled inlet in the carb. Try adjusting the carb settings fully in - then back out tooriginal position. This often crushes any debris causing the problem.
Failing that, clean out the carb.
Posted on Feb 07, 2010
  • 50 Answers
SOURCE: what type of oil I
normal 10/30 petrol oil will do
Posted on Aug 02, 2010
Honda GX390 Generator not performing under load.
a GX390 Honda Motor but the used generator stator can be different cannot give more suggestions then measuring the circuitbreaker it can be broken the suggestion 60 mf capacitor can have trouble and electronic modul and bridge rectifier for some other dc connectors the coil diodes inside the stator. several options to go.
Jun 21, 2017 | Honda Electrical Supplies
Location of idle screw on a engine
It usually is in the neck of the carburator in older
Models it looks like a screw
Sep 13, 2014 | Honda Engines GX390 Series General Purpose...
What oil weight is used in the pressure washer pressure unit
Non-detergent 20-30-weight goes into pump port, and is filled about half way.
Ordinary motor oil 10-W30 or 40 goes into engine port.
Nov 11, 2012 | Dewalt Gas Pressure Washer: 4200 psi 4.0...
Honda gx390 keeps cutting out
Linda, Sounds as though the engine is starving for fuel.
Sep 17, 2012 | 13 HP Electric Start GX390
How much oil do I put in my Honda GX390 13hp Pressure Washer. Theres no lines on the Dipstick
you fill the oil up to the dipstick hole,just so it doesn't over flow out.
Nov 13, 2010 | Honda Garden
Where can I find an owners manual for a Black Max 8125/ Honda GX390 OHV generator? I searched Honda's site but not there, no black max site. My lawn guy pulled a wire off and I need to see where it is...
Apr 07, 2009 | Electrical Supplies
Garden Logo
284 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
