Question about Tools & Hardware - Others
I have a briggs and stratton 23 hp vanguard engine model #380447-0155-e1 that will run at idle but as soon as i power it up it chokes itself out and dies is there an easy fix?
Model # 380447-0155-e1.
miket756
  • 2702 Answers
SOURCE: I am considering purchasing a used Exmark with a
yep its a briggs and normaly there very good ploders
if your john deere spluters and back fires it needs a good looking at check the valves first,,,a hand full of bolts and the heads off and if your carfull you can still use the same head gasket again,,,also check the carb there very finiky and need to be kept clean the air filter is a joke,,,but clean it anyhow and they like new plugs,,,every ten years or so? iv worked on 100s of brigss and stratons/vanguard. there good engines but there ploders not sprinters there ok in a tractor but no good in a tank there to darn slow
Posted on Mar 28, 2010
  • 4088 Answers
SOURCE: Briggs and Stratton Vanguard 23Hp starter issues
The starter may need shims between the engine and starter to permit the relative gears to release. Compare the two starters, if you still have the old one, for shaft length and bendix construction. Hope this helps!
Posted on Jun 06, 2010
Testimonial: "drallim, Everything checks out, cannot believe I've received 2 bad solenoids from NAPA. I had bought a new one and exchanged it because it seemed the switch was sticking. Still have not solved problem. Thank you for your time and efforts. Tim"
Vanny Man
  • 4 Answers
SOURCE: I have a 23 hp Briggs vanguard engine-V Twin Model
It will probally be your valve setting might be off so pull the valve covers off and try setting your valve lash
Heres the factory settings
.006 on Intake
.008 on Exhaust
Posted on Oct 26, 2010
  • 2841 Answers
It is starving for fuel. Replace the fuel filter first thing. Clean or replace the air filter. Also purchase a can of Seafoam or Techron fuel treatment. Follow the directions on the can and put some in a full tank of fuel. After running this full tank if you still have the problem then you may need the carburetor adjusted or cleaned out. I would advise you to seek professional help in accomplishing this.
Posted on Aug 08, 2011
  • 13 Answers
SOURCE: 23 hp engine will start great when cold, but after it run a short it will not start Brfiggs&Stratton vanguard V-Twin Vertical Ohv Engine start.
it sounds like a fuel starvation problem it is very possible theres a blocked vent in the carb. the carb will probably will need rebuilding not very difficult
Posted on Apr 09, 2012
Briggs and stratton vanguard 16 hp v-twin starter replacement
It most Likely is located under the engine cover..it mount just below the flywheel. Good luck
Apr 11, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Will start with choke up and will run for about one minute
Sounds like the filter may be plugged up..not expensive change it see if that helps..good luck..
Dec 18, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
I have a 23 hp Briggs Vanguard that i have to run with the choke a quarter of the way on or it will die. What will cause this to happen?
Aug 08, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
How does choke work on 20 horse briggs the throttle only has turtlespeed and rabbit no place marked choke
Many have auto chokes, which are set to close and open essentially with spring pressure. You can verify this by looking into the intake, ahead of the throttle plates. Other designs use a priming bulb to accomplish the same function.
Nov 23, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
I have a 23 hp Briggs vanguard engine-V Twin Model 380447/type 76-E1 code 4241. The engine is less than two mowing seasons. The engine will not turn over properly and I have used another start I have and...
.006 on Intake
.008 on Exhaust
Sep 05, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
18 Hp V-Twin quits after warm up - will restart but only runs with choke fully engaged
i have the same issue and trying to figure it out so I appreciate being part of this conversation,
May 05, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Engine pumps raw gas out of the carb under power
NEED TO KNOW WHAT KIND OF ENGINE. DOES IT HAVE A PUMP? IS IT GRAVITY FEED? IS THE CARB AND GAS TANK ONE PIECE? IT SOUNDS LIKE FLOAT IS STUCK OR FLOAT BOWL GASKET BAD. COULD BE ALOT OF THINGS. NEED ENGINE MODEL OR NAME ON COVER.
Jul 12, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Tools & Hardware - Others Logo
48 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
