Question about KitchenAid KCMS1555RSS Stainless Steel Microwave Oven
Microwave stopped heating, evenything else works
KitchenAid KCMS1555RSS stopped heating. Everthing else works, full display works, time counts down, turntable rotates, light comes on, etc. but no heat. First three times this happened, I fixed it by unplugging the unit, waiting a few seconds, and then trying again. Unit worked each time for another week or so. Happened again, and now power cycling it does not help.
  • 2 more comments
  • rphilli5 Jan 09, 2009
    Everything appears to be working normally, except it does not heat the food. Any ideas?
  • jhmarcus Jan 10, 2009
    Microwave was only about 7 months old. Turned out to be a bad magnetron which KitchenAid did warranty.
    Thanks for the ideas!
  • Anonymous Apr 01, 2009
    Same description, no heat but everything else works except makes loud hum. Magnatron? Cost to replace? Unit is just past warranty period, of course.
  • William Miller
    William Miller May 11, 2010
    Any unusual noises? Is
    it louder or quieter than usual?
    We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
    With the symptoms you
    have described, I would most strongly suspect a shorted high voltage rectifier
    diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
    How old is it / how many years have you owned it?
  • KitchenAid Master
  • 9,098 Answers
Posted on Jan 10, 2009
Door open button won't work on KitchenAid microwave model YKCMS135H
Page 3 of the exploded view here shows the door open parts 24510L and 250201 (or 23551B if your full model number is YKCMS135HSS).
What look like part numbers seem to be reference numbers.
For further help you will need to contact Kitchenaid Canada here.
Sep 05, 2012 | KitchenAid KCMS1555RSS Stainless Steel...
Model KCMS1555RSS appears to be in demo mode. How do you turn that off?
Here is what I found. You can click HERE for the owners manual online, but here is the skinny
To Turn On/Off Demo Mode: Touch and hold TIMER for 5 seconds until 1 tone sounds, and "DEMO ON" appears in the display. Repeat to turn off Demo Mode
Happy to help anytime, please rate service :)
Joe
Sep 01, 2011 | KitchenAid KCMS1555RSS Stainless Steel...
I have a Kitchenaid built-in microwave mod: kcms1555rss-2 . When you close the door it hums and gets hot on the inside. Open the door and it stops. It got hot enough to smell when I walked in the house...
call kitchenaid and let them know it stays on and heats i belive this unit has a new board to stop this issue. It isa safty isssue they should repair it free..dont forget to rate me Thanks
Jun 07, 2011 | Microwave Ovens
KitchenAid KCMS1555RSS - display completely blank and does not function. Is it worth fixing?
i would try and see if the fuse is blown in unit ... normally behind control panel there is a in line 20 amp fuse that may have blown.... if the unit makes noises when you touch the buttons but no display then you have a bad control board assembly
Jan 11, 2011 | KitchenAid KCMS1555RSS Stainless Steel...
Microwave is running but not heating - what do I need to do/
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 01, 2011 | KitchenAid KCMS1555RSS Stainless Steel...
KitchenAid KCMS1555RSS stopped heating. Everthing else works, full display works, time counts down, turntable rotates, light comes on, etc. but no heat. makes loud hum. Magnatron? Cost to replace? Unit is...
If it is making a loud noise, check the diode and magnetron for damage.
BEWARE OF LETHAL VOLTAGES!
The fault may be just the diode and a reasonable cost will be involved. If it is the magnetron, depending upon where you purchase one from will command the price.
Hope that helps.
Nov 13, 2010 | KitchenAid KCMS1555RSS Stainless Steel...
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
And please reply back with your brand and model number so we can help you.
Jul 29, 2008 | KitchenAid KCMS1555RSS Stainless Steel...
KitchenAid KCMS1555RSS Stainless Steel Microwave Oven Logo
1,112 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
