Question about Lexmark All-in-One Printer with PictBridge
Lexmark x2650 printer not responding to new cartridge
I bought a new Lexmark yesterday and cleaned out the colour ink printing off a load of pictures. I bought some Lexmark 31 photo ink today and placed it in the photo section (had to remove the existing black ink cartridge). So now the printer has just the photo cartridge in there.
The printer will not respond to the new cartridge. Do I need to go and buy a colour ink cartridge so that the printer recognises 2 cartridges at the same time?
Thanks - rach
  • Anonymous Mar 10, 2009
    i have tried every thing but nothing happens, i have the right ink cattridge (check number of net) and still no response
  • 685 Answers
Yes you have to have both of them then everything should be fine.if you have the color cartridge that is empty put it in for now and see if it will work it will let u know that it is empty but at least you will be able to print in black
Posted on Jan 04, 2009
  • Juanita Vega
    Juanita Vega Jan 04, 2009
    yes you have to have both of them then everything should be fine.if you have the color cartridge that is empty put it in for now and see if it will work it will let u know that it is empty but at least you will be able to print in black
I refilled my cartridge for x2650, its full, but doesn't print I refilled my cartridge with ink myself that i bought from Argos, now it is full of ink, but still shows the message that i must replace...
Please note that Lexmark does not recommend the use of refilled cartridges. Refilled cartridges tend to degrade in print quality and performance.
You may try to re-seat the cartridge and make sure it's properly seated in the cartridge carrier. Also note that once a cartridge is refilled, it can no longer register its ink level.
Aug 11, 2011 | Lexmark X2650 All-In-One InkJet Printer
I have a Lexmark X6690 and bought new Lexmark print cartridges today - Black and Colour. The printer is recognising the colour cartridge but not the black one. Driving me nuts!! Please help x
Try to reseat the black cartridge. If that doesn't help, try to clean the cartridge nozzles. On the printer operator panel > press Setup button > Maintenance > Clean Cartridges > Ok. Your printer will then print a page, forcing ink through the nozzles to clean them. Try to print again. You may also try to insert a different known working black cartridge to determine if the other is faulty. If your new cartridge is faulty, return it to the purchase store (if within return period) or contact Lexmark technical support for assistance.
May 27, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Where can i put lexmark ink?i can't see the place where should i put the new ink for lexkmark x2650
Make sure the Lexmark X2650 printer is on. Lift the scanner unit to access the cartridge area. The cartridge carrier will move to the center automatically for the loading position.
Press the down the carrier levers to open and remove the used cartridges. Load the new cartridges and close the cover. Close the scanner unit.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source. Thanks.
Nov 06, 2010 | Lexmark X2650 All-In-One InkJet Printer
My printer wont accept my coloured ink cartridge
Is it the new original cartrigde colour or not ? If yes, you should ask a guarantee from the seller.
There is a chip inside the cartridge, sometimes it doesn't compatible for the printer software to read the chip.
The printer will keep asking for the new one if there is no ink in the cartridge.
Sep 06, 2009 | Lexmark X2650 All-In-One InkJet Printer
Lexmark X2650: will it let me print when out of 1 colour ink?
lexmark printers usually just have a pop up on the screen to let you know you are out of ink in that cartridge, but it will still normally let you print.
Jun 30, 2009 | Office Equipment & Supplies
Can't Fill ink in X2650 Lexmark
If your looking for cheap ink, try buying a more expensive printer as ink for the expensive printers are relatively cheaper. I also tried refilling the inks for my printer but to no avail, it simply leaked out the bottom making a big mess
Jun 08, 2009 | Lexmark X2650 All-In-One InkJet Printer
Still getting message empty cartidge lexmark x2650
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 26, 2009 | Lexmark X2650 All-In-One InkJet Printer
Refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
Jan 08, 2009 | Lexmark X5150 All-In-One InkJet Printer
Help - Black not printing
Try cleaning the contact points of the cartridge itself and the unit that holds the cartridge with alchol. If still not printing try nossle cleaning from your printer properties.
Mar 27, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark All-in-One Printer with PictBridge Logo
437 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
