Question about Emerson Smartset Clock Radio
Wont turn on
My clock was still lite up in red but the time was not correct and the low battery light was flashing. I put in a new battery and now the clock wont light up at all, it does nothing. I put in the old battery and the same thing happened. I plu it in and I get nothing at all. The clock is only one year old.
  • Anonymous Jan 04, 2009
    I've plugged the clock into several outlet and nothing happens; clock doesn't turn on.
    President:
  • 814 Answers
This looks like a component failure problem. The failure has caused damage to Clocks control and display circuits. These type of problems are not user repairable. The Emerson customer support telephone number is 1-800-909-1240 you can call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio. Tell them the problem you are having with the clock and the clocks display. They should be able to help you get the Clock/Radio repaired. I hope this information help you with your problem. Thank you for using FixYa and have a nice day.
Posted on Jun 13, 2009
Red lite flashes when i plug it in
I can only guess that the batteries need replaced .
Sep 05, 2015 | Rascal Auto Go 550 Portable Power Scooter...
I have a Fishman pre-amp mod MKAB Acoustic Base Optimized in a Michael Kelly Dragonfly 5FL TBK.. as soon as the plug is pushed in the jack, the battery lite on the amp flashes for an instant , then goes...
Most acoustic/electric pre-amp's red light comes on when the battery is low & ready to die. The red light flashes when you put the jack in because the battery light takes a fraction of a second to proccess. If the red light flashes off & on when you push on the pre-amp, it is probably because you are causing the battery connector to short or disconnect giving the pre-amp low voltage so the red light comnes on.
Nov 06, 2010 | Fishman Audio Players & Recorders
Wont re-charge,when attempting to,red light flashes once then nothing,same when turning on,green light flashes once,then nothing
Sounds like the battery is dead. Sent it in for repair or buy a new battery if possible. Check google for solutions.
Nov 10, 2009 | Nintendo DS Lite Console
Why does my ds lite not power up
Does the battery light flash? If red: CHARGE! If doesn't charge, a new battery is needed If green: New battery is needed
Batteries lose their charge holding capabilities after being used for a long period of time. DS lite batteries have a price range from around 4-20 dollars depending on the web site/store and the quality, some can go longer without charging, others can be charged a higher number of times so you won't have to buy them all the time.
If the light doesn't flash: I am not sure. I think a new battery should fix that too
Oct 25, 2009 | Nintendo DS Lite Console
Continuous alternating one green and three flashing red battery
note.gif NOTE: Battery operating time (the time the battery can hold a charge) decreases over time. Depending on how often the battery is used and the conditions under which it is used, you may need to purchase a new battery during the life of your computer. Check the battery status light — If the battery status light flashes orange or is a steady orange the battery charge is low or depleted. Connect the computer to an electrical outlet.
If the battery status light flashes green and orange, the battery is too hot to charge. Shut down the computer, disconnect the computer from the electrical outlet, and then let the battery and computer cool to room temperature.
If the battery status light rapidly flashes orange, the battery may be defective. Contact Dell _I found this on : http://support.dell.com/support/edocs/systems/latd820/en/ug/index.htm Hope this helps and good luck. if i "fixed ya" please rate me. thanks-jmattes
Oct 22, 2009 | Dell Latitude D820 Notebook
Nintendo DS Flashing Lights
It just means you are low battery. Have you tried recharging it? Just turn it off and on and should you should be ok.
Jan 06, 2009 | Nintendo DS Lite Console
T-MOBILE DASH WONT TURN ON!!!!
On page 30 of the manual a red light states "Solid red-battery is not installed or is over discharged. Flashing red-battery very low(less than 10%)
In other words if you get a solid red light either you put the battery in incorrectly or your battery is over discharged and is no good.
Nov 02, 2008 | T-Mobile Dash Smartphone
Green light goes to red
What type of new batteries did u put, same as original ?
Oct 03, 2007 | Kodak EasyShare C340 Digital Camera
Kenwood kac 859 amp
hi, note that if you are not using the proper gauge b+ and gnd cable with this amp then the current available at the amp wont be sufficint to keep amp on. also try using this amp while vehicle is idling. if this doesnt work then disconnect all spks from amp and check if red lite stops flashing. if it doesnt stop flashing then amp has internal fault. if lite stays on brite then proceed to check each spk load impedance, then reconnect each spk individually. the minute red lite starts flashing it will give you a clue that the channel or spk load is faulty. cheers
Jul 27, 2007 | Kenwood KAC-859 Car Audio Amplifier
Emerson Smartset Clock Radio Logo
139 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
