Question about Dell Office Equipment & Supplies
Scan error - scan to folder not found 031-530
Trying to scan and sent to my network computer
4 Suggested Answers
BoxenRyan
  • 31 Answers
SOURCE: network scanning to a network drive/folder on a
Map a network drive as follows:
net use m: \\computername\sharename
The M: Drive would now be the output of the files, this also needs to be changed in the Panasonic DP-C265 settings of where the files are stored.
Sincerely,
Ryan Deschaine
Systems Administrator
Boxen Solutions LLC
http://www.boxensolutions.com
Email address: ryan@boxensolutions.com
Office number: 262.254.0064
Mobile number: 262.834-5844
Fax: 414.918.8432
AOL: BoxenRyan
Twitter: BoxenRyan
W172 N9175 Shady Lane
Suite 418
Menomonee Falls, WI 53051
Posted on Sep 23, 2009
SOURCE: HP Color Laser Jet printer CM1312nfi: scanner no
Go to your network and sharing center. Choose homegroup and sharing options. Change advanced sharing settings. Under your home or work profile, scroll down to file sharing connections. Switch to enable file sharing for devices that use 40 or 56 bit encryption. If that does not work, under password protected sharing, select "turn off password protected sharing". This is not recommended if you use your computer in multiple locations (laptop). I have found that turning all of these features off, running a scan from the printer successfully and then turning them back on, Windows seems to be comfortable allowing the printer to connect to the computer.
Posted on Oct 17, 2010
  • 385 Answers
SOURCE: I cannot scan through the
Hi!
Make sure your firewall is off and that the anti virus does not block the incoming scans!!You also need to set the privacy settings if scanning smb and make sure the folder is shared!!
Good Luck!
Posted on Jan 29, 2011
Error code 0x80070005
Easy Way to Fix Error Code 0X80070005 - YouTube
? 4:04
https://www.youtube.com/watch?v=n9mHnVFrxUE
Aug 8, 2014 - Uploaded by Windows Error Support
Error 0X80070005 is a typical Windows Error Code. This error usually occurs during installation or Windows ..
Nov 17, 2015 | Microsoft Windows 7 Ultimate for PC
Error type connect model 1128
The following is the list of info required to setup smb scanning. The easiest way to enter it, is via the devices webpage. Make sure the folder is fully shared.
"Host Name" = The computers name
"Port Number" = Either 139 for windows XP computers or 445 for windows 7 computer
"Path" = name of folder where the scanned documents are sent/saved.
"Login User Name" = Windows user name
"Login Password" = Windows login Password
Feb 24, 2014 | Kyocera Office Equipment & Supplies
I cannot scan through the network to my computer which has windows 7 with Panasonic KX-MC6020 copier. Everytime I go to scan it says communication error or device not found. I have try to scan from windows...
Hi!
Good Luck!
Jan 29, 2011 | Panasonic KX-MC6020 All-In-One Laser...
I've configured the network interface to have a static IP on our network, as well as the proper gateway, DNS servers, etc. II'm pretty sure that shared folder address book entry within the scanner is...
Is the network folder on the same subnet as your scanner? We discovered with ours that the folder needs to be on the same subnet to be able to scan to it. Canon tech support verified this when we called them. Also, I would verify that your domain accoutn can reach the destination outside the scanner to eliminate that possible issue. Our solution to placing something on another subnet was to set up a folder on the subnet to scan to and then use a batch file to copy the files out to the other location at a given regular interval.
Jan 25, 2011 | Canon ScanFront 220P Flatbed Scanner
When it scans document, the data can be sent to other computer in our office network except for mine. IP of computer is correctly addressed on the web monitor. Every computer has no problem but mine....
make sure the folder is shared and has wright permision enabled
and the path needs to be correct If all correct make sure the user name and password for that folder is set correctly in the hotocopier.
see if u can brouse to ur folder from the copier screen, go to scan screen press manual entry a very tiny button on the screen and see how far u get
Dec 01, 2010 | Gestetner DSc338 Color Copier
Im trying to scan and the canon says: "set the pc to start scan"...? Nothing pops up on the computer, what do i need to do?
I'm using an MG5220 and got this same message. Here's how I fixed it.
On the printer control panel press the soft key to select the scan function. Then hit the soft key to select Save/Forward. Then select Foward scanned data to a PC. On the next screen make sure to select the appropriate PC. In my case I'm connected wireless but the selection was set to USB connection and that's why I was getting the error noted above. When I picked the PC that is connected wirelessly everything worked fine again.
Jul 12, 2009 | Canon PIXMA MX850 Multifunction Printer
Cannot share files/folders with home network...
Bill,
I understand the frustration and I will try not to add to it. I did a bit of searching and found one thread on another forum that was similar to your situation. This person said the following:
The solution was simple:
I was running NORTON 360.
Under firewall settings; disable personal firewall.
Once this is done, access is allowed to the host pc.
You can then set your permissions, create network paths and map network drives like you would normally do.
Bill, I can't tell you this will solve the issue but it did for this person.
Good luck
Apr 01, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
SMB settings error.
if i remember right, the settings should be:
server: 192.168.1.10 / or server name
folder: Sbssvr1\Scans\SCANS
and if still not working, try give some user name and pwd, some networks require this.
Apr 24, 2008 | Konica Minolta bizhub C250 All-In-One...
3,266 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
