Swingline 211xx load staples - Office Equipment & Supplies
5 Suggested Answers
SOURCE: Staples penetrate, but do not bend
If you unscrew 4 bottom screws to lift the top cover, you may find out that there are 2 orange rubbers above its hammer that broke and needs to be replaced.
Posted on Jun 25, 2009
  • 6 Answers
SOURCE: Stapler (Swingline 211xx) has jammed. It is electr...
Turn the stapler over, remove the batteries, then remove the black pads and the four screwa under them. Take off the bottom cover and you will see the clear tabs of the cover sticking through the bottom plate. Pust them with a screwdriver toward the center of the stapler while squeezing the cover from the other side. Chances are that you will find the plunger that drives the staples is misaligned. Bend it gently forward or back until it moves without binding. Good Luck!
Posted on Feb 16, 2011
SOURCE: how do I open and
Take off the part at the opposite end of where the staples come up and press down the little metal piece that sticks out. The part where the staples load should then click out for you.
Posted on Jul 15, 2011
  • 1833 Answers
SOURCE: Someone loaded regular staples into
Using the wrong or style ofstaples, overfilling the machine and stapling through too-thick materials can causeOptima to jam. Now follow these steps: 1. Holdthe base down as you lift the top of the Optima stapler to access the stapletray. 2. Removeall the staples from the tray so that you have access to the jammed staple. 3. Turnthe stapler upside down and shake it to clear out staples you can't reach withyour fingers. 4. Gripthe jammed staple with the needle-nose pliers and, while holding the staplersecurely, pull it up. 5. Twistthe staple until it breaks into two pieces if it will not pull straight out.Pull out the two individual pieces. The Optima stapler line bySwingline is designed to be jam-free when Optima premium jam-free staples areused. Using another , style or brand may cause frequent jamming. Hope thiswill help you. Good Luck.
Posted on Jul 21, 2011
Swingline 211xx Electric/Automatic Stapler
According to what I see that you have posted, it appears you have a Swingline stapler.
You have not mentioned why you posted this information.
Were you just telling us that you have one?
Mar 01, 2018 | Swingline Office Equipment & Supplies
900XDN-C SWINGLINE HIGH CAPACITY HEAVY DUTY STAPLER OPERATIONS MANUAL
auto parts store sells a pick with straight on one end and 90 degree on other end.
This should be slender enough to pull staples out.
Mar 27, 2013 | Tools & Hardware - Others
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
We have a swingline model #690 - after loading with new staples, it does not staple. It is plugged in and makes a sound like it's stapling but does not release a staple.
1. Make sure you have the correct staples for the machine. The type appears to be:
Swingline 50050 Cartridge Staples, Chisel Point, 1/2"" Crown, 3/16"" Leg, 5000 Per Box High-quality Swingline cartridge
2. Check the cartridge to make sure there are no visible jams.
3. Contact the manufacturer at http://www.acco.com/swingline/, or
Repair Service/Technical Support:
Phone: 800.790.7787
Apr 18, 2011 | Swingline Portable Electric Stapler
Instructions on how to load a swingline heavy duty stapler.
You pull up and back on the stapler head. Then pull out the spring that keeps the staples loaded. Be careful as the spring is very strong. Then put in the staples and put the spring back in behind the staples.
Aug 13, 2010 | Swingline Heavy Duty Stapler 30 160 Sheet...
Stapler (swingline 211xx) has jammed. It is electric. When I plug it in it make a very loud noise like it's trying to staple but nothing happens. When i press the release button on the top the stapler tray...
May 20, 2010 | Office Equipment & Supplies
May 04, 2009 | Office Equipment & Supplies
k24674
jasbo
jasbo
