Question about Honeywell Dryers
I need a fan control switch uc-9060-1 for ceiling fan made by honeywell
5 Suggested Answers
Cerfer39
  • 709 Answers
SOURCE: wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Posted on Oct 29, 2007
  • 75 Answers
SOURCE: Remote Control Ceiling Fan Problem
OK, first off, there have been some problems with those remote units. That said, let me tell you what the wires should be doing and you can see if that is happening.
Normally they take a "Hot Wire" and attach it to the white wire that goes to the switch. It is hooked through the switch to the black wire to bring the "Hot" back up to the light/fan. The whites in the ceiling box are the neutral. A "Hot" and a neutral are required to make anything work. The copper is a ground, or added safety. It usually is attached to the same spot as the neutral in the breaker box, so it is not a big deal. If you have a hot going to the switch which works as the off/on valve, and back up to the box. The hot and a neutral make what ever you hook it to work. Now, if you have a remote, it uses a connection at ceiling box to turn it on and off. You can have a switch to turn the whole thing off and on, but if that switch is on, the remote is just a different way to turn it off.
If you have a way for the electricity to make the big circle, it should work, unless a part some where is not letting it through. I imagine in your situation it is the remote.
If this is new, you may want to see if you can get another, and take the remote part out (Up in the fan) and replace it. You would not have to re-assemble the whole fan. I have replaced several of these lately, and even put a different kind of remote on a few.
Posted on Dec 22, 2008
  • 37 Answers
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Posted on Jan 27, 2009
SOURCE: I need a fan control UC-9160-1C for ceiling fan AC
If this is a switch for a Honeywell ceiling fan, I have two new UC-9160 wall controllers. I can sell them to you.
Posted on Dec 13, 2009
It will operate the fan but not the light
Check to make sure the fan switch on the light is not in the off position. Also check the reverse switch is not stuck half way in between forward and reverse. Also if you installed the remote component in the fan yourself you may have to go back in and check for pinched wires or loose connections. Hate to say it but it probably isn't the fan.
Nov 16, 2015 | Honeywell Handheld Ceiling Fan Remote...
Why doesn't ceiling fan reverse?
Putting the fan in reverse is done by mechanically reversing the leads powering the motor. All the wall switch does is supply the power and the fan circuits take care of the speeds and direction.
Your problem is with the fan reverse control and/or electronics.
Sep 08, 2015 | Dryers
I need to replace the remote, uc 7067rya
You should be able to get a universal remote for a ceiling fan at home depot or lowes. Be aware they only sell then WITH the remote and the receiver unit as a package. Be aware, you'll need to check the 4 "dip pin" positions on the receiver unit on the fan itself to program the new remote. Yes, you'll have a spare receiver left in the package unless you choose to install the new one. You may have to remove the fan to do this, as they're usually found in the canopy (where the fan hangs from the box in the ceiling.) Often, the dip switches are just left all "up," however, they could easily have been changed. Some fans are programmable now, and you can test the code without having to check the receiver in the fan (similar to an older TV remote.) If you're using this for a TV, Satellite dish, etc, you'll need to find a compatible one online (not necessarily that model, it's "UNIVERSAL" and follow the instructions that come with it. TV and Ceiling fan remotes operate totally differntly, so if you have a remote that does both tasks, it's fairly new technology, and you'll have to follow instructions for the one you purchase.
Feb 13, 2015 | Universal Remote Control Hampton Bay...
Where to buy uc 7051r for hamton bay fan
That's a low-end store brand for Home Depot so I would start there. What is a uc 7051r? fanman9952@aol.com
Jun 12, 2014 | Aloha Housewares (93645) Ceiling Fan
I have a harbor breeze ceiling fan on a dimmer
You have 3 options. You can connect the fan blue and the fan black to the red ceiling wire. Then you will need to control the fan and light with the strings. The wall switch will turn off everything. Option 2 is make sure that there is a switch wired to the black ceiling wire. If there is a switch I would check to make sure the switch is working. Option 3 is to purchase a remote control unit for both and leave the wall switch to shutoff the whole unit. Hope this helps.
Oct 11, 2013 | Speed Ceiling Fan 3-speed Switch By...
The fan controller will not work, only runs in med speed...will not change speeds. Mod UC-9051T & reciever UC7067RC
Hello there, the controller seldom gets spoilt because all it does is to regulate the quantity of power which is supplied to the fan. The fan has a capacitor which regulates the quantity of power which the fan receives to determine the speed. I f the fan begins to move at a specific speed even when the regulator or controller is turned then it is an indicator that the capacitor is getting bad and therefore requires replacement.
Once you replace the capacitor the fan should function fine.
Hope this support has been helpful?
Thank you for visiting FixYa.
Aug 30, 2011 | Hampton Bay 54 In. 5-Blade Fan Brushed...
I need a fan control UC-9160-1C for ceiling fan AC 522 ,or a replacement.
Sep 04, 2009 | Honeywell Dryers
Bathroom ceiling fan has stopped working
remove the switch and test it with a meter on ohms or remove the switch and disconnect the fan wires and connect the fan wires to an extention cord to test.
Phil
Jun 09, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Dryers Logo
337 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
richie46
Steve
Level 1 Expert
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
