Question about JVC AV-32D305 32" TV
I have a grey panel on the right hand side the jvc tv screen saying E4 HDMI 1 1080i how do i get rid of it
I have suddenly got a grey panel on the right hand side of the JVC TV screen saying E4 HDMI 1 1080i how do Iget rid of it
  • 1694 Answers
SOURCE: JVC TV
The black box is called a text box and it is a selection in the
closed caption feature or CC......go thru each menu page until
you find CC....cycle thru choices until you get to off or try each selection until Text box and CC are off.................T.
Posted on Dec 24, 2007
  • 10 Answers
SOURCE: remote control code for jvc tv
HERE IS SOME CODES FOR THAT TV 557 558 559 560
Posted on Jan 11, 2009
  • 10 Answers
SOURCE: What is the code to unlock channels for JVC TV
JVC Standard Televisions 'Set Lock Code' are factory set to '0000'
Posted on Nov 17, 2009
SOURCE: How to remove closed caption from JVC TV without original remote
how can i get rid of the closed caption on my magnavox tv without the original remote
Posted on Jan 12, 2010
  • 8457 Answers
SOURCE: I have suddenly got a gray panel on the right hand
U have a reminder.It show up because u press MENU button to show up.Press menu agian well disappear.
Posted on Feb 10, 2010
LG 60UF7300 UHD TV has screen issues
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 19, 2017 | LG Televison & Video
Why can't I use the HDMI port on a JVC LT-42E478?
your hdmi is not connected tight or the cable is bad,or it is dirty,use canned air to clean out plug.extend your comp screen to the tv
Jul 14, 2015 | JVC Televison & Video
I didnt have a picture so i started hitting buttons. Now I have HDMI Settings with two options showing and can'get rid of it
Have you tried using the "Menu" button or "Input" button on the left-hand side of the set to make a selection/change the current selection?
You may also want to try unplugging the set for at least 30 seconds to see if removing power will clear the frozen screen.
Finally, note that three of the four HDMI inputs have notes associated with them in the manual on page 3, the "Part Names" page. See the notes on the right-hand, bottom of the page; items 3, 4, and 5.
Dec 31, 2014 | Sharp 60" LC-60LE650U AQUOS Full HD Smart...
How do i get rid of the blue box on my tv screen without a remote? Its from the picture inside the picture.
Normally there are controls for tv on rear to 1 side of tv , different sides for different makes, LG is on right hand side when looking at the screen.
Nov 29, 2014 | Televison & Video
JVC LT-32X787 stays on a grey screen wont open any other things not even menu
Is there a master reset?
Look in your user manual, or get in touch with a JVC tech.
Good Luck.
Mar 11, 2014 | JVC LT46FN97 46 in TV
I HAVE 2 GREY BARS DOWN BOTH SIDES OF THE SCREEN ON MOST OF MY STATIONS...DOES ANYONE KNOW HOW TO GET RID OF THEM
This is more likely a loose connection. You would need to remove the TV stand, back panel. Remove the front cover and panel. Where the TV stand sits on the front of the TV there is a cover you need to remove. It's easy there is a metal frame all around the front panel, at the base is the what you need to get to. There are 2 white computer cables, one controls the left side, the other the right side of the LED's. When this cable comes loose, you have the problem you described. to remove the cable lift up on the small black bar just above where the cable connects.
Mar 21, 2013 | Sharp LC60LE810UN 60 in. LCD TV
Digital input not working and greyed out on the menu.
Most JVC TV's with HDMI and Digital Input have an optical sensor inside the case to sense if someone is trying to bypass the hardware encryption. My JVC was exposed to sunlight prolonged sunlight and triggered this optical sensor which disabled my HDMI ports. This may be the same situation for you.
JVC HDMI Port Fix
Turn the TV on, and enter the Service Menu. Select 2 for Self Check. Then turn the TV off, and after the fan turns off, unplug the power cord. Reconnect the power cord, turn the TV on, and the HDMI port is re-enabled.
Here's how to get to Service Menu:
Before entering the SERVICE MENU, confirm that the setting
of TV/CATV SW of the REMOTE CONTROL UNIT is at the
"TV" side and the setting of VCR/DVD SW of the REMOTE
CONTROL UNIT is at the "VCR" side. If the switches have not
been properly set, you cannot enter the SERVICE MENU.
1) Press [SLEEP TIMER] key and while the indication of
SLEEP TIMER 0 MIN is being displayed, press
[DISPLAY] key and [VIDEO STATUS] key (Fig.2)
simultaneously.
2) The SERVICE MENU screen of Fig.1 is displayed.
3) Verify what to set in the SERVICE MENU, and set
whatever is necessary (Fig.1).
Refer to the SERVICE ADJUSTMENT for setting.
4) Press the [BACK] key to return the SERVICE MENU.
Dec 12, 2010 | JVC AV-56WP74 56" Rear Projection...
I have suddenly got a gray panel on the right hand side of the JVC TV screen saying E4 HDMI 1 1080i How do I get rid of it? Alan
Feb 10, 2010 | JVC LT42P789 42 in. LCD TV
Git rid of display on screen
Hi There,
Can you access the Menu List from your front panel?
Mar 29, 2009 | JVC AV-32D305 32" TV
No video input -- all ports -- for JVC LT-37X688
JVC may allow warranty exception or some accomodation for 15 days out. You have 2 seperate issues
1. White lines spreading is probably a video process problem. I think this TV has 3 Boards inside. Middle one is most likely suspect followed by the one on the Right
2. HDMI input not working is because they were turned OFF. JVC TV's have a sensor that will shut off the HDMI if the TV's back cover is removed. This must be reset in the Service Menu.
Nov 16, 2008 | JVC LT-37X688 37 in. LCD HDTV
JVC AV-32D305 32" TV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
