Question about Panasonic Televison & Video
My jvc has e4 HDMI 1 permanatley - Panasonic Televison & Video
2 Suggested Answers
  • 8457 Answers
SOURCE: I have suddenly got a gray panel on the right hand
U have a reminder.It show up because u press MENU button to show up.Press menu agian well disappear.
Posted on Feb 10, 2010
I have a JVC HD-70FH97 hooked to my digital box, via HDMI cable, and connected to the TV HDMI input 1. I cant get my surround system to work - any ideas what im doing wrong?
Check your HDMI audio settings. It may be trying to send a signal that is incorrect. How is the wiring setup? cable box to stereo, then to Tv?
Sep 21, 2016 | JVC HD-70FH97 70 in. HDTV Television
I can't connect any sort of HDMI enabled device to my JVC HD-52G887 television. Does anyone know how to fix this?
Check to confirm that you are using the correct input source for where it is plugged in. ie HDMI 1 HDMI 2
If that doesn't work check that the cable is good and is seated properly on both ends.
Jun 10, 2015 | JVC Televison & Video
View input from hdmi-2 JVC LT-32E478
Port 2 must be a dummy, then!
Aug 29, 2012 | JVC LT-32E478 TV
Hdmi isn't working on jvc 52z585 tried resetting it with remote it seems like its locking out other devices for like copy rights infringment
hi,
JCV 52Z585 has 1 port HDMI that support 480p
if your input higher your tv will not support.
There are 2 type of HDMI 480p signal, 640x480 and 720x480.
To seting input HDMI to JVC, you should seting input device to default resolution or 480 depend on device (DVD, PC, blueray etc).
Mar 25, 2011 | JVC HD-52Z585 52" Rear Projection...
I have suddenly got a gray panel on the right hand side of the JVC TV screen saying E4 HDMI 1 1080i How do I get rid of it? Alan
Feb 10, 2010 | JVC LT42P789 42 in. LCD TV
HDMI input 1 with Analog Audio
In the audio menu there should be a setting for which audio you are using. JVC loves putting different options in there audio menu.
Oct 14, 2009 | JVC LT-46J300 46 in. LCD TV
HDMI broken on JVC HD-56G786 TV
have you ever went thru your hdmi setup procedure that jvc recommends?
Sep 07, 2009 | JVC HD-56G786 56" Rear Projection HDTV
Cant hook up HDMi cabe from PS3 to JVC
1. check the input that the PS3 is connected to
2. select that input on the TV
3. Press and hold the [power] button on the PS3
4. perform the video setup for the PS3
My guess is that you don't have the HDMI setting correct on the PS3.
Apr 15, 2009 | JVC LT-42X688 42 in. LCD HDTV
JVC LCD TV (LT-42X688) input panel not working!
1. This TV has setting for the HDMI input that allows you to select the HDMI Audio or Analog(red/white wire) audio. Make sure this is correct
2. Most cable boxes are DVI not HDMI. If DVI then you actually do need to use those Red/white cables. If HDMI, refer back to #1.
3. The cable box has a setting to select the Audio output, HDMI (digital) or Analog(red/white cables). Just like #1, this has to be set.
4. Contact your cable company to help you set up the box correctly. JVC can probably help you check the TV
Mar 05, 2009 | JVC LT-42X688 42 in. LCD HDTV
JVC THD-50 system
Yes, that is correct. You can either use optical or digital for the audio to the jvc system. They give you 2 options but you can use either, they both work just as well.
Apr 03, 2008 | JVC THD-50 System
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
