Question about Brother Sewing Machines
I have a Lx2500 Brother need to knlw how to set for free motion quilting
How to lower feed dogs to free motion quilt and where all settings should be
5 Suggested Answers
  • 1116 Answers
SOURCE: Free motion quilting
Refer to the accessories and you will find one is a darning plate. If you check the section for darning, there will be more information.
Look on the throat plate and there should be a tiny hole on each side of the feed dogs, this is where the plate snaps into place.
If you do not have the plate, set the stitch length to zero, and then tape an index card over the feed dogs with a hole punched out for the needle.
You may use this method forever, or check with your local Brother dealer for the accessory.
Posted on May 01, 2010
  • 201 Answers
SOURCE: help setting Viking Designer I machine for free motion quilting
I assume you are doing free motion quilting? Use the V Menu, choose the first stitch. If you are using the Q Sensor foot or the spring free motion foot, go into the Set menu, hit "More" twice then turn On for either the Q Foot or Free motion. Make sure you have Needle Down turned on (top right-hand button on the left side above the needle). You might need to loosen the top tension by one or two clicks - first screen of the Set menu, under the picture that looks like DNA. A Size 90 needle is probably best and if the quilt is difficult to move about you might like to either use the Sewing Advisor to set for Heavy fabric or lessen the upper presser foot pressure - Set menu once again, next picture after the DNA. I have never had to do this with my D1 but I know some other people have. Get back if things are not working well for you.
Pam
Posted on May 02, 2009
RichSew
  • 194 Answers
SOURCE: Can't free motion quilt on Juki-T98QE
You need to be using a free motion foot or a darning foot, the regular presser foot is not for free motion.
Posted on Jun 03, 2010
SOURCE: Lost my manual. I need to lower the feed dogs to
singer.com has a free operation manual to download
just put in the search box w2999 & it will bring up the free download option
Posted on Dec 01, 2010
Will my Brother LB6800pRW sew sideways?
The needle will probably zig-zag, but No the machine generally will not sew sideways unless it is stitching embroidery. To sew sideways, you can use a darning foot or free motion foot, lower the feed dogs, and manually move the fabric sideways as it stitches (see free motion quilting).
https://wpt.org/SewingWithNancy/Video/free-motion-quilting-beginners-part-1
Dec 04, 2017 | Brother Sewing Machines
How do you set up a brother XL-5700 for free motion quilting
Be sure to have a darning foot or free motion quilting foot (this presser foot is shorter in height so when you lower it, it will not press the fabric to the feed dogs). The foot must allow space under it so the fabric can be manually moved.
The last step is to lower the feed dogs so they are not interfering with your manual manipulation of the fabric.
Lots of web sites about free motion quilting.
Learn How to Free Motion Quilt Stippling
May 05, 2017 | Brother Sewing Machines
Janome 1600P DBX
You need to drop the feed dogs, install a darning or free motion quilting foot (make sure the presser foot is lowered). Because you will not be using the machine to move the fabric, the stitch length selection is of no importance. Make sure the stitch width is set to zero. You should test FMQ on a scrap quilt sandwich of the same makeup of your project, ie quilt fabric with batting sandwiched between. The upper tension should be set so that both threads meet in the middle of the quilt sandwich. Because it is FMQ, some extra adjustment may be needed.
Once the tension is where you want it, you can practice FMQ until you can move it smoothly in conjunction with the machine speed.
Practicing on a white board with erasable markers is a handy way to learn to move smoothly. The most difficult part of free motion quilting is learning to move the fabric smoothly. Do NOT lack for practice as that is the only way to improve. Those people who make it look simple have been doing it for years!
How to Free Motion Quilt on Regular Sewing Machine
Free Motion Quilting for Beginners Part 1 Video from Sewing with Nancy
Oct 31, 2016 | Janome Sewing Machines
Is there a setting to quilt freehand?
Are you asking about free motion quilting (FMQ)?
If so, you need a darning foot of some type (a foot that does not press the fabric to the sewing surface).
You need to drop the feed dogs (or if your machine does not have that capability, a feed dog cover that probably came with your machine and set the stitch length to zero).
Then, add lots of PRACTICE!!! I like to draw designs on a white board with an erasable white board marker... The more fluid you can become, the better experience you will have with FMQ.
Free Motion Quilting Beginner Tutorial 1 of 4
START HERE
Sep 29, 2016 | Sewing Machines
How do I avoid breaking a needle on a 26 foot beginning a free motion project after programing the foot choice and lowering the foot?
#26 is an embroidery foot. Why are you using an embroidery foot for free motion quilting? A #24 free motion embroidery foot will work but not the #26. Try using a darning foot that is just a smidgen shorter so there is space between it and the needleplate for you to freely move the fabric. (Adding a Supreme Slider sheet to the work surface of your machine helps make the fabric glide much smoother.) A standard presser foot is made to press the fabric against the feed dogs so the feed dogs will move the fabric. When free motion quilting, you would drop the feed dogs and move the material with your hands.
Depends which model Bernina you have (new or old style presser feet), which will work on your machine. There are also many generic darning/FMQ feet available that will work on your machine.
12 BERNINA presser feet Darning foot 9 (old style)
Quilting foot 29C (new style)
Bernina 530 53 Free Motion Quilting
Top 5 Tips for Successful Free Motion Quilting WeAllSew BERNINA USAs blog...
Seven Steps to Free Motion Quilting
Dec 31, 2015 | Sewing Machines
Which foot do I use for quilting
a quilting foot or buy one with a round hole in it great
Mar 09, 2015 | Sewing Machines
Viking designer 1
Hi, Free motion quilting is done with your programmed quilting stitches, Lower the feed dogs using the small white dial on the front of the machine behind the accessory tray, pick from one of the quilting stitches. they do make a free motion quilting tool ( I think they call it a hoop), but it just sets on top the material and helps you guide your material thru the machine. Hope this helps
Aug 29, 2014 | Husqvarna Sewing Machines
May 01, 2010 | Brother XL-5340 Mechanical Sewing Machine
Sewing Machines Logo
295 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
