Question about Apex Digital Televison & Video
Apex digital flat screen model LD3288T has sound but no picture, has blue lines
TV has sound but but no picture just crowded vertical blue lines
  • 375 Answers
SOURCE: No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Posted on Aug 18, 2007
hawkwatcher
  • 67 Answers
SOURCE: Zenith LCD Flat Screen TV just shows vertical lines of color
Press menu button on the TV if the on screen display is also distorted or no pic the TV is definetely defective. You can try unpluuging from wall for about 15 minutes and see if reset helps if not problem is either main p.c.b , LCD panel , LVDS cable or Power supply board. and would require service. most likely problem would be bad connection at or defective LVDS cable that connects main p.c.b to Panel (cheapest fix) or defective main p.c.b. If it is the panel it would probably not be worth repairing and you may want to sell as is on ebay.
Posted on Jan 13, 2008
  • 6 Answers
SOURCE: THICK BLUE LINE VERTICAL LINE ON SCREEN OF MY PLASMA PICTURE
IF THE LINE IS ABOUT 1INCH WIDE THE CHANCES ARE IT WILLBE YOUR PLASMA DISPLY THAT HAS GONE . WOULD BR CHEAPER TO BUY A NEW UNIT . HOWEVER TRY RINGING HITACHI EXPLAIN THE FAULT COMPLAIN THAT IT SHOULD OF LASTED LONGER THAN THE WARANTY AND SEE WHAT THEY WILL DO ABOUT IT
Posted on Feb 15, 2008
SOURCE: Philips flat screen TV MODEL ID 19PFL5422D/27
I bought the television less than a year ago, so I called Philips Magnavox and they asked for the serial and model numbers. Next thing I know they asked for my name and address and Philips is sending a brand new television to replace it !!! The new one should arrive in about ten days. How's that for service? I'm very happy that I bought Philips and I will do so again. So don't forget to keep all the paper work that comes with your new televisions,especially Model and Serial numbers ! Thanks for asking , Debbie Hoffman
Posted on Aug 19, 2008
SOURCE: LCD TV - Vertical Blue line
use menu and h/v then change then move to higher level and it will take it away.
Posted on Aug 24, 2008
How to fix cracked screen on apex lcd tv ld3288t?
  • The TV has to be replaced if the screen is damaged.
Jan 01, 2016 | Televison & Video
Apex TV LD3288T can't find channels
Have you set it on cable, it may be set for antenna.
Oct 12, 2014 | Apex Digital Apex 32 Class 720p 60hz LCD...
Red light flashing 4 times
sounds like it's toast http://community.sony.com/t5/Television-Picture-Sound/Vertical-Lines-of-death-KDL-52W4100/td-p/29582
Mar 26, 2014 | Sony KD-27FS170 27-Inch FD Trinitron WEGA...
Lcd tv goes blue screen
Blue Screen usually means you have no video source, but also it can be a bad cable, bad signal, or week signal. I will try to hook it up to a dvd and test it on another source. However the screen should be all blue aand not blue lines, if you can email me a photo of the screen I will be able to properly address it.
Tony Mitri
goldtekfl@hotmail.com
Feb 15, 2014 | APEX Digital Inc. Apex Digital 32" 720p...
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
Won't power on
Check your power outlet for any loose contacts and ensure there is power. Try connecting the TV to a different power outlet.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 04, 2012 | Apex Digital Apex 32 Class 720p 60hz LCD...
I have an apex LCD 32in model ld3288t I turn it on and have no picture but I can hear the audio
Show a torch light on the screen from a safe distance, when program runs. If you can see the picture, the problem is with the backlight and might require the attention of a qualified service technician.
Jul 31, 2012 | Televison & Video
Televison & Video Logo
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
