Question about Sony Audio Players & Recorders
How do you wire the SS-WMSP66 subwoofer to a receiver requiring a male plug
The subwoofer comes with dual split wires but hookup to receiver requires a male plug
robotek
  • 1512 Answers
SOURCE: subwoofer hookup
Hi silverfox55
You probably wont experience any sound quality losses, however, you may pick up mains hum that will be noticeable at low levels, and also prevent you sub from auto turning off. It will also be suseptible to RF interference, such as that from taxi and police radios,and mobile phones. Try it first, you may find that it works ok. Your house may have foil building paper as insulation that will sheild the outside sources of Rf interference. The mobile phones however... If it doesnt work, I suggest you use the existing speaker cable to pull through for a run of decent audio coax. This way you will not end up with any unwanted signal getting into your sub.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jun 03, 2008
SOURCE: Pioneer VSX-505S Subwoofer Installation
That type of subwoofer is not used with this receiver. This receiver actually outputs no power for a subwoofer, therefore only needs a plain ol' rca signal wire. This is due to the fact that you need a powered sub... one that you plug in to the wall and it has its own built in amp. you simply run an rca from yyour 505s to that sub.
Posted on Jun 24, 2008
dunnbiker
  • 8546 Answers
SOURCE: Receiver cannot recognize subwoofer
As I implied earlier, take a clue from the physical style of connectors for both parts of the subwoofer function in the old and new receivers:
RCA connections are for Line Level signal between components only.
The input (bare wire) at the speaker is for AMPLIFIED signal.
You can't just modify one to fit the other and expect magic to happen. Be glad you didn't do it the other way around and modify an amplified (speaker level) outout into a Line Level input. You likely would have smoked that component.
Your subwoofer is a passive speaker, that is, like any other speaker it needs an amplifier. Many subs are self-powered (amp built-in) and they would mate well with the RCA sub output of the receiver.
Get yourself an Active (self-amplified) Subwoofer and run UN-MODIFIED RCA cables to it, according to its instructions, from the Sub Out of the receiver. Or get an amplifier between your receiver and the sub you have.
Posted on Feb 21, 2010
Testimonial: "Thank you for your help to an electronics layman!"
pgh_pa_guy
  • 2992 Answers
SOURCE: diagram of pioneer receiver vsx-454 to show wire hookups
This site has the manual for downloading. You need to register but it's free.
Posted on Mar 02, 2010
markfreedman
  • 312 Answers
SOURCE: I recently purchased a new
Your sub-woofer apparently does not have an amplifier built into it. This type requires you to use your front left and front right speaker output to got through it to your regular speakers. It is called a passive sub-woofer for that reason.
To set it up, Connect your front speakers to the "output" of the sub. It should say "to speakers" on it.
Then connect the Speaker Outputs for the left front and right front on your Denon AVR-391 directly to the Sub. It should say on the back of the Sub "to amplifier".
Here is some theory you should know, if you don't already know it, that will help you get a satisfactory result in setting up this system.
There is a condition on setting up all speakers and subs that not everyone know. It's call "phase alignment". Phase alignment (A Good Thing) refers to all of the speakers in a system moving in the same direction (in and out) at the same instant in time. This gives you much clearer sound and better response from your sub-woofer.
Phase Cancellation (a bad thing) is when some of the speakers are moving out and other moving in during the very same instant in time. It causes problems in sound.
IN A SUB-WOOFER, IT CAN CANCEL OUT THE LOW NOTES.
Here is how to handle it:
On the back of the receiver the speaker terminal outputs are colored Red and Black. Black is considered negative and Red is considered positive. On the back of the Sub woofer and on the speakers the same colors apply. MAKE SURE THAT ALL OF THE CONNECTIONS GO BLACK TO BLACK AND RED TO RED WHEN CONNECTING UP THE SPEAKER WIRES.
The system will work either way. But you will have severe bass loss if the woofer wiring is out of phase because of phase cancellation.
Hope this helps,
Best Regards,
Mark
"Phase Cancellation"
Posted on Jan 05, 2011
OmniS10 does not work
Mine has issue with the sub input that runs from the receiver sub output. So I don't have the LFE effect. I have to use the secondary hookup which is:
-run your front speaker wires from the receiver into the input. Then run wires out back to your front speakers.
Is your completely dead period? Or is the light coming on? If its dead, it may be a fuse or the power supply has failed....if the light comes on. Try the secondary hookup. Make sure both your reciever and the sub are unplugged. Plug them back in after you have hooked everything up..
Feb 08, 2013 | Mirage OMNI S10 Speaker
Whats a control jack on a sony SS-WG450 plug into if i'm hooking it to a JVC reciever?
That subwoofer is included in the MHC-GX450 system. I have the amp/CD/radio unit. but not the subwoofer. The control cable connects the LED on the Sub to the main unit. When the main unit detects this connection to the LED it switches on its internal subwoofer amp to drive the subwoofer.
Does the JVC receiver use a "control" circuit through its external subwoofer unit to signal that it is connected to the subwoofer? If not, you do not need to use the control jack on the
SS-WG450 to connect to the JVC receiver. Connecting the Sony subwoofer to a subwoofer output on the JVC unit may be enough. Do check the impedance required by your JVC receiver. Sony lists the SS-WG450 as having a Nominal impedance of 6 Ohms. Is this high enough for the JVC unit?
Feb 03, 2012 | Sony MHC-GX450 CD Shelf System
Feb 21, 2010 | Pioneer VSX-D607S Receiver
What wires go to the subwoofer to connect to a sony receiver
hi you should only need 1 rca going from the sub pre out to your subwoofer inout.
some subs require a stero signal coming in and you may need to pickup a Y adapter at radio shack.
Jan 02, 2010 | KLH ASW8120 Subwoofer
How can i connect an mp3 player on my Power Acoustik PTID-4007
Expandability Options:
  • 3 sets of preamp outputs (front, rear and subwoofer)
  • Telephone Mute trigger wire for Bluetooth adaptation
  • iPod Ready: IC-1 iPod Connection Cable Required and Sold Separately
  • Front-panel auxiliary input: Mini USB input and SD Card slot
  • Rear auxiliary input: 1 back-up camera input and 1 A/V input
  • 1 Video output
The aux rear a/v input should do the trick.
If it is a component (RCA) type input, you will need a Male 3.5mm to dual Male RCA adapter.
If it is a 3.5mm input, a Male 3.5mm on each end.
I believe you will need the Dual RCA (red/wht) to 3.5mm cable.
The Audio inputs are purple RCAs on the back of your head unit.
Jan 14, 2009 | Car Audio & Video
Connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Nov 22, 2008 | Audio Players & Recorders
    Need help hooking up a KRK powered subwoofer to an Onkyo 7.1 receiver
    a single male rca spliting into 2 male rca's ....a signal splitter
    Oct 30, 2008 | Onkyo TX-SR804 7.1 Channels Receiver
    The lights are off
    Do you have a 12 volt power running to the lighting plug? That enclosure requires a seperate 12 volt power line in order to make the lights come on.
    Jul 16, 2008 | Dual XINBP-210 Car Subwoofer
    214 people viewed this question
    Top Sony Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
