Question about HP Officejet J5780 All-In-One InkJet Printer
J5780 DOES NOT COMMUNICATE WITH COMPUTER
J5780 SCANNER DOES NOT COMMUNICATE WITH COMPUTER.IT SAYS DEVICE NOT CONNECTED EVEN IF HARWARE IS CONNECTED. I ADDED ALSO STILL SAME ERROR
  • shameus Jan 06, 2009
    when I press SCAN TO button on Hp J5780,  printer screen reads "No Scan Options" I'm using a Mac
CD that comes with "costco" HP printer... does not have mac drivers... mac will find printer on its own so printer works... but you need to go to hp website and download updated driver...
uninstall hp software, erase trash, restart computer, then install new driver...
Posted on Jan 06, 2009
Go into tool on pc and open paint, that,s what works for me. or call hp and they will walk you thur
Posted on Jan 04, 2009
250 error on documate 510 xerox
Symptom: When scanning you receive an error 250. Cause: This problem can be caused by several different things but is often a driver or communication problem. Solution: Here are several solutions that can resolve this problem:
Solution 1 - Check for communication problems
Using any of the following can cause communication errors:
  • USB hubs
  • Docking stations
  • USB extension cables
  • USB cables longer than 6'
  • Connecting the scanner to one of the computers front USB ports (desktop computer only)
Connect the scanner directly to a USB port on the back of the computer (or side for notebook computers) using a 6 foot or shorter cable.
If you still receive the same error message, try a different USB cable.
Solution 2 - Redetect the scanner with Hidden Devices
Windows Vista, XP and 2000 users
  1. Disconnect the power and USB cable from the scanner.
  2. Click here and select "Run" or "Open".
  3. The Windows Device Manager will open.
    • Click on the "View" menu then select "Show hidden devices".
  4. Click the "+" next to "Imaging Devices". This will show all Imaging Devices previously and currently connected to the computer.
  5. Right-click on the Visioneer or Xerox scanner name and left click on "Uninstall".
  6. If the scanner is listed more than one time, uninstall ALL occurrences of the scanner.
  7. IF you see "?Other Devices" in the device manager list, click on the "+" to view the list of Other Devices.
  8. Right click then left click on "Uninstall" for each occurrence of the scanner. The scanner may be listed as any of the following:
    • USB Scanner
    • USB Device
    • Unknown Device
    • 1200 DPI Scanner
    • (Your Scanner Model)
    • (any other scanners or cameras listed here that you no longer use)
  9. Click the "+" next to "Universal Serial Bus Controllers".
  10. Right-click every listing of "Unknown Device" and select uninstall.
  11. Once all instances have been removed from device manager, reconnect the power and USB.
Windows Me and 98 users
  1. Right-click on the "My Computer" icon on your Windows Desktop
  2. Select "Properties" from the list
  3. Click on the "Device Manager" tab
  4. Find "Imaging Devices" and click on the plus (+) next to it to expand the list
  5. Select your scanner, then click on the "Remove" button
  6. IF you see "?Other Devices", click on the plus (+) next to it to expand the list
  7. Select your scanner then click on the "Remove"; button – your scanner may be listed as any of the following:
    • USB Scanner
    • USB Device
    • Unknown Device
    • 1200dpi Scanner
    • (your scanner model)
  8. Close the Device Manager
  9. Unplug the scanner from the computer and from the power
  10. Plug the scanner back in to the computer and power
Solution 3 - Check for power problems
If the power for the scanner is plugged into a surge protector, battery backup (UPS), or extension cord, plug the scanner directly to the wall.
Solution 4 - Check for conflict with other devices
This error can also be caused by a conflict with another USB device.
  1. Disconnect all USB device from the computer (including the scanner), except for you keyboard and/or mouse
  2. Turn the scanner off
  3. Restart the computer
  4. Once the computer has fully restarted, reconnect and power on the scanner
  5. If the scanner works properly at this time, it means there is a conflict with another device on the computer
  6. It may help to isolate the two items by connecting one of them to a USB add-in card
Solution 5 - Test the scanner on a different computer
If possible, you should try the scanner on a different computer. If the scanner works correctly on a different computer, then the problem is environmental and may be related to your chipset. See solution 6 below.
Solution 6 - Check the computer's chipset
This problem can also be caused by the computer's chipset. To check the chipset:
  1. Vista, XP and 2000 users: Click here and select "Run" or "Open".
    ME and 98 users: Right click on 'My Computer', select 'Properties' then click the 'Device Manager' tab.
  2. The Windows Device Manager will open.
  3. Click on the plus (+) next to 'Universal Serial Bus Controllers'.
  4. This list will include your computer's chipset.
  5. The follow chipsets are known to have communication problems:
    • SiS 7001
    • VIA Rev. 5 or later
    • Open HCD
    • ALi
  6. If your chipset is one of those listed above or it is only listed as 'Standard', you can try updating the chipset drivers.
    • Contact your computer's manufacturer for more information.
  7. If the problem persists, you may need to use a USB add-in card.
    • This is a PCI card that will add more USB ports to your computer.
  8. For more information about USB chipset issues, see www.usbman.com.
Jul 12, 2010 | Xerox DOCUMATE 510 Flatbed Scanner
HP Officejet J5780: Cannot scan, copy, or fax from my computer.
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Nov 12, 2009 | HP Officejet J5780 All-In-One InkJet...
HP Officejet J5780 scanner communication error
I had this problem too, and after a while just gave up on the uesless HP interface, and went to the simple but efficient Windows Fax and Scan program on the Start>Programs menu.
Jul 09, 2009 | HP Officejet J5780 All-In-One InkJet...
HP J5780 - Using scanner with print server
no, print server is just that, print server is only good for printing. I don't know if there are a device you can use for all-in -one office machine. I am looking for one myself.
May 29, 2009 | HP Officejet J5780 All-In-One InkJet...
yes. this printer can be use for wirelss connection, so it can be use with wired jetdirect. however, you are going to need the web jetadmin from hp in order to reconfigure the IP address for the jetdirect.
you can download a copy form HP.com
Jan 13, 2009 | HP Officejet J5780 All-In-One InkJet...
All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
May 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Scanner component stopped communicating
well, reinstall the software and see if it will work.
Aug 13, 2007 | HP PSC 1350 All-In-One Thermal Printer
HP Officejet J5780 All-In-One InkJet Printer Logo
197 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
