Question about Homelite Garden
Unloader valve homelite 2700 psi. subaru motor
3 Suggested Answers
wmpcs
  • 100 Answers
SOURCE: I have a 4,000 psi, 4.5 gpm 45G cat pump powered
I would just purchase a new unloader valve, they usually aren't worth rebuilding. I would like to have a picture of the set up that you have, if you can send me a picture of the unloader region of the pump I can get you are price on a new one. email is justin@wmpcs.com
Posted on Oct 25, 2010
  • 142 Answers
SOURCE: Just purchased a homelite 2700
Check for spark first If it has spark, remove the breather and put a few drops of gas in the carburetor.
Posted on Jun 05, 2011
The engine cuts off when i squeeze the handle on the sprayer, what is causing this to happen?
Sounds like a bad unloader valve. Do a search on "pressure washer unloader valve symptoms". When they are faulty there will either be little pressure or it will stop an engine abruptly. The engine will not just die down as it you were turning it off. It would stop cold.
May 28, 2015 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Where the pressure release valve on 2500 psi gas model
A pressure release valve on a pressure washer is called an unloader.. It is on most machines a removable part. It allows the pressure that is created when the trigger of the wand is released to be re circulated inside the pump manifold assembly. They are pre adjusted at the factory and I do not recommend screwing around with the adjustment because if it is tampered with it can cause the unit to stall or blow out your water seals. Yes the unloader on most models be replaced, but you have to order specific to the model you have to ensure you have the correct one.
0da044b2-f75b-474d-bf93-eee0e6d8d14a.jpgThis pic is a typical unloader found on most Briggs and Stratton and other branded pumps averaging 1600 2500 psi.
http://www.allpartsinc.com/ProductDesc.aspx?code=16030
Aug 27, 2014 | Homelite Garden
Why can't I get pressure
Bypass valve may be stuck open bypassing the pressure.
www.homelite.com/service_support
Jun 23, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Homelite Pressure Washer. 2700 psi 2.3 GPM Gas Pressure Washer won't start
I found a small long spring disconnected from my throttle which made the engine run rough It is easy to reconnect and makes a big difference in engine performance. also, if there is a very dirty air filter-oil/dirt it will not start-replace filter.
Jun 17, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Honda 160 homelite pressure washer 2700 psi no pressure
Water comes out the nozzle, but low pressure? ( more than when the motor is not running)
I would check the check valves and the unloader.
If the amount of water coming out the nozzle is the same when the motor is running or not running.
Either the key that connects the motor shaft to the pump shaft is sheared, or the pump is trash.
No water comes out the nozzle would indicate a clogged inlet filter or blockage at the gun valve or nozzle.
May 05, 2014 | Homelite Pressure Washer. Honda 2700 psi...
Homelite ut80522d pressure washer motor reves up and down then dies
It's surging... your carburetor needs to be serviced. It's not giving the proper air fuel ratio to the engine...
BriMaxSmallEngineRepair
Gibbstown,NJ
Jul 26, 2013 | Homelite Gas Pressure Washer: 2700 psi 2.3...
Oil runs out under flywheel when motor starts honda GCV 160
Your top seal on the mower motor is faulty...replace with new seal...
Mar 25, 2013 | Homelite For Husky - Pressure Washer Pump...
Pressure washer surges
This could be your unloader valve taking in account the engine isn't surging. Does the engine run smooth? Do you have at least 50 psi water pressure feeding the pump? Inlet screen clogged? ALL tips act same way or no change?
Sep 08, 2012 | Generac 2700 PSI 2.3 GPM Gas Pressure...
Mi TM 2700 pressure washer has no pressure.
With the water on, to the washer and the unit running. Does the water come out at the same rate before the trigger as at does after the trigger (run test with spray nozzle removed). Its not impossible for unloader valve to be bad but it usually is a dependable component. Make sure the unit has the air purged from it properly before start-up, make sure there are no obstructions before the trigger, then the nozzle. The unloader valve just puts the pump into by-pass until the trigger is depressed.
Apr 10, 2009 | Mi T M WP-2700-4MHB Pressure Washer
Garden Logo
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
