Question about Zanussi FJS1225W Front Load Washer
Zanussi turbodry w 1042 w
The washing machine works fine but when we put the tumbledryer on the house 'trip switch'' turns the power off the the power sockets in the house? the fuse is not blown? any ideas what is causing this?
    President:
  • 1,462 Answers
Probably short to earth on the dryer elements. to check. take top off, disconnect dryer elements then run on dry program. if the trip stays in, then you have identified the fault
Posted on May 16, 2007
My washing machine is zanussi turbodry 1200.Is there an instruction manual I can download?
You should be able to get one from zanussi by going on to there website
Dec 15, 2017 | Zanussi Washing Machines
Where can I find a manual?
You may view/download the manual here.
Mar 14, 2012 | Zanussi Washing Machines
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
Zanussi jetstream 1000 turbodry door remained locked this morning. Emptied machine through filter port and cleaned filter. Door opened ok. Machine will now not start any program although the power light...
the drain pump is jammed .........remove the filter at the bottom left of the machine get down and look in the hole and you will likeley find something in there if not you need a new pump
Feb 26, 2010 | Zanussi FJS1225W Front Load Washer
Zanussi jetsystem turbodry 1200 door wont open
its the doorcatch,turn power off, remove lid and put hand in machine where doorlock is situated feel about and try open catch, repair or replace?
Jun 24, 2009 | Zanussi ZWF1420W Front Load Washer
Washing Machine trips circuit breaker when Drying
This will be the dryer heating element needs replacing.
Hope this helps.
Jan 21, 2009 | Zanussi WDA1055W Front Load Washer / Dryer
What is E 40 on Zanussi Turbodry 1200?
E40 indicates the doors not closed properly. Sometimes it can be the lock itself or the main control board
Nov 24, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi Turbodry 1200 spin problem
if this washer is used alot then it will more then likely be the carbon brushes which u will need to take the lid off undue 4screws out where it joins front to the back screws at the back to the bottom and 1screw either side of the bottom where the panels join together behind a little cap which will have an hole in the middle of it to get it out u will then be able to get to the motor to replace the carbon brushes
Nov 22, 2008 | Zanussi ZJD1219 Front Load Washer / Dryer
Zanussi turbodry 1050
this may sound silly but check the waste outlet pump electrically, some models are wired up so if the pump fails the water will not enter the machine, this works on the theory that if it fills up it can not empty also check the solenoids for open circuit electrically, double check the water supply to the machine, it may have been fine but you could have kinked the pipe placing the machine back where it should go?
Oct 04, 2007 | Washing Machines
Zanussi jetsystem Turbodry 1200
It appears that you may have a faulty door interlock or a faulty PCB. pcb is not really a DIY job as some boards require proramming on certain versions. Regards Advisor
Oct 30, 2006 | Zanussi FJS1225W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
157 people viewed this question
Top Zanussi Washing Machines Experts
jimorris77
shaun taylor
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
