Question about Motorola Mobility RAZR V3c Cellular Phone
Screen does not completely boot up
The screen has bunch of lines with different letters and stars
  • 2 more comments
  • steve396 Jan 03, 2009
    How do I remove the simm card from a v3m phone???
    I see a small square below where battery is but it seems to be latched in some how. Maybe I should just take it to the shop.
    It just has an arrow on it. Yeah, it has a small bar holding it in. Tried to get it to lift over the bar by wetting finger but it didn't work.
    President:
  • 1,990 Answers
I know this is what Cust. Service ask's But, Have you Turned it off, Removed the Battery and Sim, Replace after 4 Minutes?
Posted on Jan 03, 2009
  • 1 more comment
  • Travis Humphries
    Travis Humphries Jan 03, 2009
    After you remove the Battery it will be the Small White Square Card Just wet your Finger Tip and Slide it Out Carefully
  • Travis Humphries
    Is it White and Says like ATT or something On it? Should have a Small Flat Bar across it to keep it in. Just wet the Tip of your Finger and Slide it out, Should not be hard to get out.
  • Travis Humphries
    Ok, You might not have to send it in, Do you have an Authoized Service Store near you? Like an ATT Wireless Store? They might be able to fix the Problem right There in no Time.
Hard disk is not boot up after windows screen appears
It seems you computer is not recognising the hard-drive, on boot up, because it doesn't know where to look, i.e. it is booting up to a different drive letter. Have you got more than one drive on the system? If you have you will need to reconfigure the bootup list. Good Luck. George
Mar 29, 2013 | Fujitsu MHW2120BJ-G1 Hard drive 120GB...
Computer will not boot to normal and verticle lines on monitor, dell XPS410, windows vista 32 bit
Unplug the monitor video cable from the computer. Power on the monitor and see if you get the same results. If so then your monitor is defective.
Oct 11, 2012 | Dell Computers & Internet
The screen goes black with a bunch of different numbers and letters how do i fix this
If you have original disks, try and reload OS. If that doesnt work motherboard may be done. Could try taking apart and hitting reset button on the motherboard.
Sep 26, 2010 | Apple iMac G4 Desktop
2long 2short 2short beeps on mother board
You really need to go to the BIOS manufacturer's website to ensure the beep codes are the same but here is a link to a site that has some of the common codes with different BIOS manufacturers. To determine which BIOS you are running, when the computer boots up, it should be at the bottom of the screen as it initializes each device. It looks like a black screen with a bunch of lines popping up with the status of each device. The Bios will be down at the bottom left during this process. IF you have a splash screen instead you will need to interupt the bios boot process, either by hitting the DELETE button, or F1 or F2, depending on the manufacturer. Hope this helps. If not post back with the computer manufacturerer and model number and I will try and determine the step by step instructions to assist you.
http://www.5starsupport.com/info/beep_codes.htm
Aug 03, 2010 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Does not boot, i can get the screen after pushing f8, but does not boot, goes to a blue screen
Windows was completely corrupted by a big bunch of viruses. Reinstall from scratch and use a better antivirus.
Jul 10, 2010 | Acer Aspire X3200 PC Desktop
TV Screen has verticle lines with a message
Place the red line actualy the reds fine cause the blue is behind it but the bla k could maybe use some stars in it ya know my ninjas and maybe fade with the colors just to keep addin to it bits at a time but yeah post me a solution lol
Aug 05, 2009 | Philips Televison & Video
Cant find the imei for my krzr
switch it on , and at the main screen press *#06# (star, hash, zero, six, hash) and your imei will be displayed on the screen
Jun 09, 2009 | Motorola Mobility SLVR L7 Cellular Phone
HP Pavillion ZV5405 with Black/White vertical lines through screen
Will it boot from a CD/DVD? Make sure the boot sequence is set to boot CD first and then see if it will boot into setup from a CD/DVD. If it will, then maybe try reinstalling windows. Hope this helps.
Aug 21, 2008 | Acer Aspire 5100 Notebook
Horizontal multicolored lines appearing
Open up the TV and unplug and re-plug the connectors to the circuit boards. This is most often caused by a poor connection of the circuit board connectors.
Mar 25, 2017 | Samsung LN-S4092D 40 in. LCD HDTV
Motorola Mobility RAZR V3c Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
