Fujitsu Plasma 42" won't turn on power light blinks red
Plasma TV (Fujitsu PDS4203W-H) went pop one day. When I turn it on, light turns green for a couple sec. and I can even hear a clicking noise like it is trying to fire up but then nothing happens and power light goes to blinking red. My understanding is plasmas don't have lamps, could it be the power supply board? Any knowledge appreciated. Thanks
likha
  • 790 Answers
SOURCE: Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Posted on Oct 02, 2007
  • 3 Answers
SOURCE: Pioneer PDP 5030 power supply problem
Ok here's how I manage solve the problem... Having the back removed opens the contacts on the interlock switch so I guess if it powers up in this state it senses the high voltages are exposed and for safety shuts down... After this the unit will not power up and the power led flashes red continuously as described before…
After some thought it occurred to me that there may not be a problem at all, just be a simple reset function for this condition… I managed to find an easy solution to this… Just call up the hidden engineer’s service menu – On 3rd generation Pioneer Plasmas it’s as follows > Power down the screen > Hold down the “Input” and “Vol +” buttons on the front > Power the screen up and the Service menu comes up on the screen > You don't need to change anything just simply power off and from then the screen should operate as normal…It did for me so I’m well happy now!!
I hope this information will help someone else one day – Good Luck!!…Rob UK…
Posted on Jan 04, 2008
gilheero
  • 207 Answers
SOURCE: High Pitch Noise on 42" PLasma Gateway TV
how old is your plasma TV? try check the switch / volume of the sound settings.. Sometimes, when you always increase the volume, it will tend to alter the limit of sound and causing the sound to provide sound undesiredness. I suggest to check it with a liscensed technician.
Posted on Feb 05, 2008
SOURCE: fujitsu pds4209u-b 42 plasma
Chances are the PDS4209 has a broken axis board. I don't think the 4203 has the same board. I don't think the 4203 compnents can run the 4209
Posted on Aug 26, 2008
SOURCE: Magnavox 50" plasma Won't Power on/Shut's off/Blinking red LED
The above fix, listed by Tom saved us!! We did as instructed and took off the back of our 50 inch Magnavox plasma tv. We were not sure what we were looking for so we googled capacitator (image) & there was a photo of a fried capacitator! Sure enough we noticed ours were "fried", we took out the board and went to an electronic supply store, bought the 2 capacitators ($2.00 each!!) and then found someone who did tv repair to sauter the new capacitators onto the board. (It is important someone who know how to sauter and recognizes polarity do do this for you) All in all we fixed this following the above instructions for $34.00 and our time. For a month we were told to spend hundreds getting a new power board!
Kudos to you Tom & thanks so much!!
Posted on Feb 02, 2009
P42VHA20WS
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Feb 18, 2014 | Fujitsu Plasmavision 42" TV
Panasonic 42 inch plasma wont turn on. red light blinks 10 times
I unpluged mine and the light was still blinking when it was unpluged. I thought that was weird. So I pluged it back in and just heald the power button in untill the light went out. It went out within ten seconds. I pushed the power button again and the tv went on. WOOHOO!!! Just needed reset, I guess.
Dec 10, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
P42vHA30 - picture disappeared and on/off light blinks red/green/red/green, etc. What is wrong? How to fix?
I would suggest taking a look at the power supply board and making sure there is nothing that has went bad such as fuses, capacitors, transistors, etc.
Jan 13, 2011 | Fujitsu P42HHA30ES (Bundle) 42 in....
Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
Apr 14, 2010 | Philips 42PF9631D 42 in. Plasma Television
Red blinking light
same problem, red blinking light in series of 5 flashes
May 30, 2009 | Pioneer PureVision Pro-1000HD 50 in....
42" Fujitsu Plasma TV (About 10 yrs old)
You have not fully identified the model number of your unit, but
this is most likely caused by the Main Power pcb.
For models P42HHxxxxx and P42HCxxxxx see Fujitsu Service Bulletin on this problem. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
Sep 29, 2008 | Fujitsu Plasmavision 42" TV
Fujitsu plasma went blank
Need to have the power supply checked by a qualified technician.
Feb 12, 2008 | Fujitsu Plasmavision 42" TV
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Fujitsu 42" Plasma Display shuts off after 20 minutes
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu 'service@fujitsugeneral.com'
Oct 21, 2007 | Fujitsu Plasmavision PDS-4233 42 in....
Televison & Video Logo
535 people viewed this question
Top Televison & Video Experts
