Question about Fujitsu Heating & Cooling
Fujitsu ASU9RLQ error code: (2) flashes red & green; followed by (5) flashes red only
5 Suggested Answers
  • 86 Answers
SOURCE: Fujitsu ASU9RLQ
check indoor unit sirkit board
Posted on Mar 15, 2008
louislevel_2
  • 374 Answers
SOURCE: Air conditioner not blowing cold air anymore
hi! there,
if no cold blowing,evaporator is not working,have you ever heard compressor is running,check this out,no compression of course you dont have cool on evaporator.if the compressor is running check the oprating current,if still have enough freon charge,if not running check thermostat reset setting on the coldest,ifn still not run check overload relay on panel control reset lever to put back compressor to run,check condensing fan if working,if not check also over load protection,this should be done by ac tech nician.have a nice day,dont gorget to rate me, thank's
Posted on Apr 18, 2009
SOURCE: My Fujitsu a/c unit is not cooling, the error code
I am having the same issue. Can someone help?
Posted on May 23, 2010
hvac1960
  • 2133 Answers
SOURCE: fujitsu asta24jcc error code is 4 x grenn and red
Indoor pipe sensor faulty..Replace it.
Posted on Jan 19, 2011
My fujitsu abt18lbaj won't go, the red light flashes constantly and the green light flashes 4 times
Hi Russell,
I hope the following link is of some help to you
Good luck
http://errorcodeairconditioning.blogspot.com.au/2010/10/fujitsu-air-conditioner-error-codes.htmlNIGY5Q
Jan 25, 2015 | Fujitsu Heating & Cooling
I have a fujitsu inverter asta 24jcc every eight seconds the red and green light flashes about five times
Hi Ken,
I hope the following link will help you?
Good luck
Dec 13, 2014 | Fujitsu Heating & Cooling
Fujitsu ASU18RLQ heater/air conditioner with 2 green and 7 red flashing error lights
Here is a link to the error codes.
http://www.fullyairconditioned.com.au/images/uploaded/files/fujitsu%20fault%20code%2
0split%20system.pdf
Hope you find an answer there.
Feb 15, 2013 | Fujitsu ASU18RLQ Single Zone Wall Ductless...
Fujitsu airon ASTA24LCC 2 flashes green and red then 5 red flashes any idea what it means
Had similar problem (ie. 2 green & red flashed followed by 5 red flashes - Fan blowing but not cooling ... I also noted that the outside unit fan wasn't going). Tried restarting several time after waiting only a minute or two after turning the mains power off but with no change. So turned the unit off at the mains power and then fired it up about 2hrs later and it was all working fine.
Jan 24, 2013 | Fujitsu 24C1 Air Conditioner
I have a Fujitsu p42vca30eh which when switched on flashes the error code 4 red 1 green. I can't find blink codes for this model, can anyone help. Thanks
Four red [4]. One green [1]. That is error code is (41). Try to downlaod the service manual to this set. It will have the details of fault.
May 25, 2012 | Fujitsu Televison & Video
Ihave a fujitsu air conditioner model asta18lcc about 2 yrs old when I turn it on fan works but room wont get cold or hot,red operation light does not stay on but green timer light flashes on. thanks...
The lights on the front panel indicate fault codes dependent on the amount & intervals of the flashes. Fujitsu units carry a 5 year warranty so check with your local Fujitsu store for the agent in your area.
Aug 13, 2010 | Fujitsu 24C1 Air Conditioner
Fujitsu ASU9RLQ
Mar 10, 2008 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
49 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
