Question about Dell 2335dn Multifunction Laser Printer
Blurry copies dell 2335dn
Getting blurry copies (like smudges) along out 1/3 on each side of the copy made from the platen (glass). I am about 1/2 way through a replacement generic toner cartridge that I have been using for 2 months with no problems.
  • 279 Answers
SOURCE: Dell Photo All in One Printer 964-scan/copy problem
This sounds like a problem I've had with a Lexmark scanner. It turned out that there was a switch on the bottom of the scanner that would lock the mechanism in place for shipping. Do you see anything similar on this unit, or am I barking up the wrong tree?
Posted on Aug 28, 2007
SOURCE: Dell AIO 962 copy & fax issues
I'm betting the Cold cathode fluorescent lamp needs to be changed
Posted on Feb 22, 2008
proton77
  • 1183 Answers
SOURCE: Printer Busy
As you have already worked with Tech support at Dell, they may have exploited all the options but do try the following steps and tell me if that worked
1. DIsconnect you printer from the computer
  1. Press the down arrow button until Maintenance is highlighted and press the Select button.
  2. Press the down arrow button until Reset Defaults is hightlighted and press the Select button.
  3. The printer displays a confirmation message. Highlight Yes and press the Select button
This would reset your printer to factory defaults.
2. Unistall the drivers using the following file
R166225 .zip from the link below
http://support.dell.com/support/downloads/format.aspx?c=us&l=en&s=gen&deviceid=9913&libid=40&releaseid=R166225&vercnt=1&formatcnt=0&SystemID=PRN_PHT_964&servicetag=&os=WLH&osl=en&catid=-1&impid=-1
-> Save the file to desktop
->Double click to extract the file and see where the file is being extracted.
-> Go to extracted file folder ,right click on the file named setup and left click on run as adminstrator.
-> Follow on screen instructions and it would uinstall the printer
3. Restart your computer.
4. Install the drivers back on to the computer using the printer cd. Note :connect the printer only when prompted on the screen.
Once the printer has been installed , we need to update the printer aswell .
5. Download the printer firmware from the link below
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R114639&SystemID=PRN_PHT_964&servicetag=&os=WLH&osl=en&deviceid=9913&devlib=0&typecnt=0&vercnt=2&catid=-1&impid=-1&formatcnt=1&libid=40&fileid=151153
6. Follow on screen instructions to install the same
7. Check if the printer works after this , otherwise its time for a new one.
Thanks
Mandeep
Do let me know , if the information above was of any help. by rating me for the same.
Posted on May 08, 2008
  • 85 Answers
SOURCE: laser scanner on dell 5110cn laser printer, prints black smudges
replace fuser. How far apart is the ghost image?
Posted on Feb 16, 2009
  • 53 Answers
SOURCE: prints faint copies
If the print rubs off the page, this means the toner is not being fused to the page. Fused......this is done by the fuser. This would have nothing to do with light print.
The dell (1600n and 1815n /1815dn) printer drivers has a toner saver mode, which can contribute to light print.
To turn Toner Save Mode off, (Windows XP) perform the following steps:
  1. Click the Start button, click Settings, and then click Printer and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser MFP 1600n, 1815dn, and left-click Printing Preferences.
    The Dell Laser MFP 1600n, 1815dn Printing Preferences window appears.
  3. Click the Advanced button.
    The Dell Laser MFP 1600n, 1815dn Advanced Options window appears.
  4. Click to highlight Toner Save.
  5. Click the drop-down list and change it to Off and click OK.
  6. Click OK.
One thing that you mentioned in your post "it takes the printer forever to warm up". The fuser does have to reach operational temperature in order for it to fuse the toner to the page. So it is possible that you are having fuser problems, because of the time it is taking for it to warm up. Another thing that can contribute to the warm up time is not plugging the laser printer directly into a wall outlet. This would be true for any laser printer, not just a Dell laser printer. The low voltage power supply is what works the fuser, along with sensors and other motors in the printer.
Replacing the fuser and or the low voltage power supply in this model of printer is not an easy task. If using a Dell branded toner cartridge and checking the toner saver mode does not fix the issue. Then you would be looking at more expense then the machine would possibly be worth.
Posted on May 07, 2009
WHAT IS THE PLATEN GLASS AND HOW TO CLEAN IT?
the platen glass is small glass on the left side of normal copy glass. The platen copy glass is used when you making the copies from ADF.
Hope that helps
Feb 13, 2011 | Canon imageRUNNER 1023N Black and White...
The screen says the Paten glass needs to be cleaned. What is the paten glass? Also when copies are made a black line is showing up on the edge of the copy.
platen glass means that you need to clean the copy glass - glass where you put the originals for copying.
If you have an auto document cleaner there is also small glass on left side of "platen glass" wich is seen when you open the copy machine cover or dadf.
The black line is probably from dirt on copy glass, I pressume because courectour liquid ( most common ). use some stronger detergent or wd-40 to disolve the dirt and clean with glass detergent and dry it.
If you still have the black line try to print something from machine.If you do not have it on print its the copy glass problem - clean it - again.
Pls.rate
May 09, 2010 | Canon imageRUNNER 1023iF Black and White...
Black smudge mark down 2 inches of right side of copy?
Do you see the same smudge mark if you lay the original on the platen rather than using the document feeder? If it only shows when using the document feeder, clean the scanning glass for the document feeder. It's the small glass to the left of the main glass with the cover open. Use a damp cloth and clean off any dirt or white-out.
Nov 04, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Platen glass dirty clean platen glass
user mode
common settings
additional functions
13. adf dirty error
display(default) / do not display
Sep 18, 2009 | Canon imageRUNNER 1023iF Black and White...
Konica bizhub 250
on the left hand side of the platen glass there is a **** glass just clean that with alcohol or wet rag.
HH
Feb 14, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Black line on document when I scan from platen or ADF or scan to save as PDF.
As a tech I've never seen that happen. from the doc feeder only Yes, not both the feeder and the glass but not show up when you print from the computer ?????????
For sure there is a dot or something on the small strip of glass, only when you do it from the feeder.
the reason is that the document is moving and the dot on the "small" strip of glass now looks like a line to the copier.
You said it also does it when you lay it down on the glass !!??(platen) that should of indicated the drum has a ring around it, but since it doesn't come out on the PC copy then the glass must have a line on it.
Oct 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Lines on copies
The lines are caused by some debris that is on the platen (the glass where you normally place the copies). The usual culprit is white-out smudges from a copy that wasn't completely dried yet. When you make copies using the feeder, the roller passes the paper being copied over a little section of the platen (if you pull up the feeder "lid", it'll be on the right-hand side of the big glass... it might even be marked with 2 green arrow stickers, but if not, it's the part of the glass directly under the roller of the feeder). You can just take an alcohol wipe or soak a cotton ball with alcohol or windex and wipe down that strip of glass under the roller.
Jul 01, 2008 | Canon ImageClass D861 Printer
Black smudges across sides of 81/2 x 11 paper
The optics may be dirty or you could have a bad drum cleaning blade.
Feb 13, 2008 | Office Equipment & Supplies
Verical line(s) problem with canon mp780
Hi Nick, It's ONLY when you copy? I start by cleaning the platen glass. Wipe the Platen Glass with a clean, soft, lint-free cloth moistened with water. Then wipe with a clean, soft, dry, lint-free cloth making sure not to leave any residue, especially on the Platen Glass. If you have trouble getting the scanning area clean, wipe with diluted mild detergent (for dish washing). Do the same thing for the white area under the platen lid. If this does not resolve the problem let me know. His Dudeness
Nov 15, 2006 | Canon PIXMA MP780 All-In-One InkJet...
Dell 2335dn Multifunction Laser Printer Logo
53 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
