My Honeywell DT92E is reading 10C hotter than the room temperature & even when I raise the setting to 35C it still does not switch the heating on. It has worked fine for 2 years until now
I have read all the forums, got the full manual, checked the installer mode is correct but still nothing. Its 18C in the room but the DT92E thinks it is 28C and even with the temperature set at 35C it does not switch on the heating. ECO is off, setting are correct. It has lost communication several times with the control box a ST9420C after no previous issues!
hotuna
  • 288 Answers
SOURCE: Temperature varies 13 degrees around setpoint on aux heat
I don't have the book for this particular unit but, check the sequencers that control the electric heat mode, as the regulator heat pump works good. The part may have a time or temperature delay that is too long for you. Also if it has a remote thermostat, check the heat anticipate setting. You will have to check the installation manuel, but its usually .6 to .8, but I don't think that is the problem.
Posted on Dec 04, 2007
SOURCE: I have vulcan ducted heated
I replaced the batteries, even though 'battery low' message was not displayed. this fixed my problem. I wish I'd have just done that to start with.
Posted on Aug 13, 2008
hemantraj
  • 638 Answers
SOURCE: Hotpoint RGB747GER oven does not heat properly
www.repairclinic.com
Posted on Aug 18, 2008
  • 116 Answers
SOURCE: how to remove thermostat cover to replace
the cover pulls off if it has a green screen then most likely takes batteries if does not light up then no batteries with a small piece of insulated wire jump from green to red if indoor fan does not come on then transformer bad
Posted on May 15, 2009
localwonder
  • 6784 Answers
SOURCE: control panel on my fridge
Pull the power cord for 5 minute to reset the control board. if this control panel malfunction still exist after the reset, replace the control circuit board.
This is a typical control fault that should be corrected by pulling power for 5 minutes. if not, this reset will confirm major damaged to the circuit board.
Posted on May 25, 2009
My thermostat is set on 68 degrees and it shows room temperature is 68, but the furnace still kickson, Honeywell said it has a 1 degree difference. so what's the problem then?
Yes there is a one degree tolerance, in fact my heater just kicked on and it is set to 67 and the inside temperature reads 67. It is also a Honeywell.
Dec 28, 2016 | Heating & Cooling
I have installed a Honeywell DT92E which keeps turning off the boiler before room temperature is reached
Hello David, I don't know if you installed this thermostsat or had someone else to install it. If you don't have the manual for your DT92E thermostat, I found a PDF file online that coveres both DT92A and DT92A. If you scoll down the PDF file after opening it, towards the bottom, you will see how to adjust the boiler timing. Maybe the timing is still in default mode and needs to be adjusted for a longer burn time? Hope this helps out.
Mar 04, 2014 | Honeywell Heating & Cooling
I just installed a honeywell 5-2 progammable thermostate.. Everything is hooked up fine and I have my days, hours wake, sleep, leave...etc all set, but when it goes on.. for example, I have it set for...
You didn't include a model number, so it's hard to know for sure - but I'll take a stab at this one. Many of these t-stats have a programmable offset to reduce "hunting". This can be as little as 1 degree or more than 2 degrees.
This means if you set the offset to 1 degree and the room temperature to about 65 degrees, the furnace will heat the room until the t-stat registers a rising temperature of 66 degrees. The furnace shuts off and will not turn on again until the t-stat registers a falling temperature of 64 degrees. The average is 65 degrees, and prevents the furnace from starting and stopping numerous times instead of just once with the 1 degree offset.
You can further reduce the number of furnace start and stops by increasing the offset to 2 degrees. This would work like this when the t-stat is set to 65 degrees and the room is cool:
Room Temp Furnace
63 On
64 On
65 On
66 On
67 On
68 Off
The room is now warm and heat or furnace is off. The room begins to cool like below:
67 Off
66 Off
65 Off
64 Off
63 Off
62 On
With a 1 degree offset, the room temperature varies +/-1 degree (about 2 degrees total). With a 2 degree offset, the temperature about varies +/ -2 degrees (about 4 degrees total).
Also, when the thermostat shut the heat off, the heat that was made is delivered to the space instead of wasted by sending outdoors - so the room will get a little warmer even though no fuel is being burned. The same holds true at the other end. When the t-stat turn heat on, fuel is burned, but there's little heat until the source has reached the optimum temperature and then the heat is delivered to the space.
I hope this helps & good luck! Pleas rate my reply - thanks!
Jan 24, 2011 | Honeywell Programmable Thermostat Heater
DT92E room stat appears to be very inacurate with its room tempreture, our normal room temp is about 22c we have to set the stat at 25c to get heat and the stat cuts out after a temp rise of 1c
All thermostat is calibrated @ difference of 2 degree.to cut in and cut off.
In heat mode, if you keep 25 and your room temp 23. it will start at the end of 24 or beginning of 25 degree.Cut off also @27 degree beginning. Please check Tips & how to do's in Fixya
Jan 11, 2011 | Honeywell Heating & Cooling
The instructions say the Honeywell DT92E needs only a two wire connection, but the wiring diagram shows three, which is correct Please
This Honeywell control thermostat is made for wireless control, by means of a relay control transmitter with a range of 30 meters. It only needs a 2 wire connection on this stat if indeed it is the DT92E stat. Even though the diagram shows three, you will need only 2 for operation. This is a fact. I have done some reading on this model and many of its relatives, so with built in relays, and transmitters, this is an amazing set-up. Good luck with it as you should enjoy its operation and user friendly features.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Please be kind when rating, as I know you will be. If you have anymore questions, leave them in the comment box so I can check in when I can get to them. Thank you for using Fixya.com
Nov 20, 2010 | Heating & Cooling
During cold weather the fridge in my cabin stops working... anyone know why?
nearly all fridges are made for domestic kitchen environments,where the ambient temp is around +10C to +35C,so anything colder/hotter and the gas/system used is not able to extract the latent heat out of the interior of the fridge and dissipate it to the exterior.you may need to buy a garage conversion for your particular unit.(these units are NOT available in the U.K.where i live,but im informed ARE available for the American/Canadian market)......in other words if you warm up the room its in, it will work fine.
Nov 15, 2010 | Amana Refrigerators
Honeywell T87f 3855 Doesn't Activate Heater
thats becaue you need more than this zone working like you said about the master/slave this zone is a slave.
Jan 25, 2009 | Heating & Cooling
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
