Question about Exercise & Fitness
Lifecycle 95R clutch slipping
Need a troubleshooting/repair guide for Lifecycle 95R Inspire recumbent bike. The pedals free-wheel, slip intermittently. Have replace the 6V battery with no change in symptoms.
5 Suggested Answers
ybchuan
  • 201 Answers
SOURCE: Looking for manual for Lifecycle 9500 HR
U may goto the following website to get the assembly manual. Availability 09-Sept2009
http://www.rectech.org/manual.pdf
YBC (/\)
Posted on Sep 09, 2009
maxtreadmill
  • 832 Answers
SOURCE: I have a lifecycle model 9500HR, will not turn on.
Some of these units have the main battery ( 6v @ 2.5AH ) inside the bike frame and a 9v in the backside of the upper console
Posted on Feb 28, 2010
ercupa190
  • 12223 Answers
SOURCE: I have a NordicTrack SL710 recumbant bike that the
Prepareto oil by filling a grease gun with lithium grease. Check your owner's manualfor the exact type of grease for your unit.
Posted on Nov 03, 2011
ercupa190
  • 12223 Answers
SOURCE: recumbant bike slips while peddling
http://www.youtube.com/watch?v=mVJxs7ALxDM&feature=related
Loose Pedals 1
Kneel next to the left side of the elliptical's base. Use the Phillips screwdriver to tighten the two screws located in the center of the left pedal.
Use the Allen wrench to remove the bolt securing the left pedal arm to the pedal leg and body arm. Use the Phillips screwdriver to remove the screw securing the rear end of the pedal leg to the crank arm.
Pull the end of the pedal leg free of the crank arm. Wipe the crank arm clean, then apply a fresh coating of machine grease or silicone lubricant. Replace the end of the pedal leg back onto the crank arm and use the previously removed screw to secure it back into place.
Join the front end of the left pedal arm to the ends of the pedal leg and body arm. Use the previously removed bolt to connect the pieces together.
5
Move to the right side of the elliptical and repeat the above steps on the right pedal arm.
Posted on Nov 08, 2011
The Fit Test and Fat Burn do not light up as an option on my Lifecycle 6500HR bike, they used to work now they don't.
This really sounds like there is a problem with your console. You might consider contacting LifeFitness for replacement options and or further troubleshooting. 1-800-351-3737 is the contact phone number for them directly.
Mar 23, 2014 | Life Fitness Nut Lock, Cranknut, Lifecycle...
Chain keeps comming off
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
It sounds like you are dealing with a stretched chain. If the chain will not tension any further, you may be looking at the need to purchase a new chain. Use your model and serial number at the following link to order a new chain.
Bike Parts for LifeFitness LifeCycle 9500 Upright Belts Pedals Seats...
Jan 29, 2014 | Life Fitness Lifecycle 9500 Upright...
How do I remove the pedals on a 8500 life fitness recumbent bike
Using a wrench, you remove the left pedal as you would loosen a normal, left hand threaded bolt. The right side is a reverse thread and would need to be loosened in the opposite direction.
Feb 20, 2013 | Life Fitness Nut Lock, Cranknut, Lifecycle...
My lifecysle 9500hr the start button does not light up
I recomend that you read your instruction manual,and check the section troubleshooting. If you do not have go to download to the next web page: www.fitness.manualsonline.com or www.iconservice.com for FREE.
God bless you
Aug 31, 2012 | Life Fitness Club Series Lifecycle...
Where is battery located for LifeFitness' Lifecycle 9500HR
The Lifefitness Lifesyscle 9500HR battery location is at in the lower portion of the recumbent bike. This is a 1/2 to one hour task for most do it yourself'er.
In order to gain access to the battery compartment,you has to remove the pedals.
The center cover has to be remove.
Additional reference: Lifecycle Battery 0819-0012 Model Description Terminal Volts AH L W H Lbs Price 0819-0012 Fits Lifecycle Stairmaster series 4200, 4400 - Lifecycle Lifefitness CT8500, CT9100, 9500HR, 95Ci - Star Trac 5300/6300, 5400/6400, StarTrac 6100 Pro, 6200 Elite, ET4600 (0819-0012 replaces the 0819-1006) F2 6 2.5 4.48 1.81 2.75 2 $19.80
Feb 02, 2011 | Life Fitness Exercise & Fitness
How can I determine which Lifecycle I own.. I purchased it second hand (X-Balley) and other then Lifecycle HR on its side I see nothing else discribing it. The battery is in need of replacement. I...
On the bottom the bike frame their should be s# plate. If you need to replace the battery you need to: first remove the foot pedals,then side panels.
they sold run about $20.00 to $27.00 plus S/H
Feb 26, 2010 | Life Fitness 9500RHRT Recumbent Bike
Feb 18, 2010 | Exercise & Fitness
Looking for manual for Lifecycle 9500 HR (recumbent bike)
YBC (/\)
Sep 08, 2009 | Cycling
Exercise & Fitness Logo
47 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
