Question about GE Nautilus 24" Built-in Dishwasher
Dishes not clean, soap still dripping down from dispenser.
Washer is 4 years old. Used every day. Lately have noticed dishes are all cloudy. When done I open the door and soap is still streaming down from the dispenser. Nothing is rinsed.
Maybe its my imagination but the machine seems to be too quiet, hums a lot, goes into periodic silence. It does go through the full cycle but I dont hear the usual "Swishing noise".
I have tried putting the dial to "rinse" again and that helps.
  • tgroh854 Jan 05, 2009
    My dishwasher seems to fill but soap does not dispense what else could be the problem?
  • 4 Answers
CHECK TO SEE THAT THERE IS NO SILVERWARE STUCK IN THE BOTTOM AND RESTRICTING THE WATER AGITATOR FROM SPINNING...MAKE SURE THERE IS NO CLOG IN THE WATER LINE GOING TO THE PUMP. COULD BE A DEFECTIVE WATER PUMP TOO.....ALSO CHECK IF YOU ARE GETTING WATER INTO THE UNIT AFTER YOU START IT UP...IF NOT, YOU HAVE A BAD VALVE WHICH IS ELECTRICTLY OPERATED OR A CLOGED WATER LINE...
Posted on Jan 03, 2009
    Sergeant:
  • 311 Answers
Yes its the water that washes that soap out,no water no wash.so a couple of things.eazy first.im asumming it drains fine.1 so check the flood switch dome,its in the tub ,frount area if enpty should be down.if you pick up ,will hear small click.2 [harder] with a volt meter put the probes into the water valve.its in bottem behind panel most of the time its blue,so whiteor yellow.with probes in water valve connections.turn on dishwasher at begining of cycle.after short time should get 110 volts if yes need to clean out valve[minerals]or replace because failed.God bless,tom
In the last month I have noticed that my dishes aren't getting clean. My dishwasher is less than a year old and has done a great job so far. I tried adjusting the amount of rinse aid and the amount of...
First I would run the hot water until hot. Then start the dishwasher on the longest setting with the dispenser door closed( no detergent). Then after about 10-15 minutes open the door and check to see if the dispenser door opened, it should have. Then pour in about 1 cup of white vinegar and let the dishwasher finish. When the dishwasher reaches the end of the cycle open the door and it should be hot and steamy. If not check the heating element. If it is hot this should have cleaned it out, now try it with a load of dishes.
Dishwasher heating element replacement
Sep 28, 2010 | LG Dishwashers
Maytag dishwasher
Go buy a product called Lemi-shine and run it thru your dishwasher empty to clean out any hard water and soap deposits. If you can try using only about 2 table spoons of detergent and stay clear of the premeasured tablets. Most of the dishwashers being sold are low water usage units and it is very easy to overwhelm them with soap. It also helps if the oils from the foods are still on the dishes. People tend to clean the dishes to much before loading them and then the enzymes in the detergent have nothing to attach to. Basically this leaves the soap nothing to attach to except the dishes and hence you get cloudy dishes with soap stuck all over them.
Jan 30, 2010 | Dishwashers
Soap dispenser does not always open
You should only need to replace the soap dispenser assembly.
Aug 02, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Cutlery is cloudy and dirty, some food is dried onto knives and forks. Cups and glasses are cloudy and not clean on inside. Coffee or tea stains are not removed. Plates and soup bowls seem OK , and water...
they must have changed the way they treat the water in your area. those spots are caused by hard water. www.dishwasherfilter.com has a product out for this problem. it filters the water going into your dishwasher leaving them spot free and crystal clear with every load. you will love the way your dishes look.
Mar 21, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
Glassware and dishes getting water spots lately.
I think your dish washer is starting to go out. We have a Kenmore dish washer (unsure if the model is the same), it started with not cleaning the dishes well to not sanitizing and now it doesnt dry. We are actually replacing ours today. We we noticed that it wasnt cleaning properly (water spots, or not rinsing well) we too added Jet Dry thinking that that would solve it. We soon discovered that it didnt help at all. Hope this helps you.
Mar 17, 2009 | Kenmore Dishwashers
Silverware becomes cloudy and is difficult to polish
The new water-conserving dishwashers, including the LG LDF 7811 are very sensitive to the dishwasher soap that is used.
If you notice white staining beneath the soap dispenser at the end of each full wash and possibly undissolved powder remaining in the dispenser, I recommend you stop using that powder and buy a box of Electrosol or Cascade powder and use it in place of what you currently use. Avoid using gel or tablets in all dishwashers.
I experienced very similar problems with the LDF8812 that I personally own. First step to fix was pulling the filter (10 phillips screws) rinsing the filter as best possible, remove all debris. Replace filter and spray arm.
Place a bowl filled with white vinegar in a bowl on the rack of the empty dishwasher. Run a quick wash cycle to the end.
Look closely at the RinseAid cap inside the door, remove it and turn the little dial to a lower number. Over time, adjust it up if dishes are not drying properly.
Use the dishwasher normally - do not overly pre-rinse the dishes because the food particles are actually used during the wash cycle to help clean the dishes. Also, do not over load the dispenser cup with soap. A Tablespoon will do it. If you run out of the rinse aid, feel free to use white vinegar.
Oct 21, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Cloudy Dishes
there is a new product out that filters the water going into your dishwasher. the film or cloudy white look is caused by hard water. this filter eliminates the problem and is very affordable. you can get it at dishwasherfilter.com. i was amazed how clean my dishes came out after the first load.
Nov 03, 2007 | Dishwashers
Dishwasher soap dispenser won't open during cycle
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Oct 26, 2007 | Dishwashers
Dishsoap stays in soap dispenser
ok, either a spring, trigger prob, on the latch, or a electronic prob. ok so to see if the latch is ok (or not) look closely for soap residue and scum, that may be hindering the latch or spring under. use metho, and warm water to clean this part. secondly go down to a white goods repair place and take your electrical component, button, lights its all one unit, simple unscrew it, i do think you will need a set of torque screws for that tho... anyhow ask the guy to get you a new or second hand one and install it. the timer will run, and the clip will release. good luck!
Sep 25, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Soap dispenser slow leak
Plug off the wall socket first. Remove screws to remove the top of your machine. Check to see if the rubber hoses are connected well to the dispenser chamber, if not connect them properly. Another thing could be your dispenser drawer; you could pull it out gently to clean it; or you could even use a tooth brush for access.
Sep 20, 2007 | LG WD-1080FD Front Load Washer
GE Nautilus 24" Built-in Dishwasher Logo
117 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
