Question about Samson C01U Consumer Microphone
Cannot hear sound from mic on Samson CO1U. - Samson C01U Consumer Microphone
  • Anonymous Mar 24, 2009
    sounds fuzzy and when i speak into it i cant hear anything?
    problem solver??????
I can't install logitech desk mike model ak 5370 in vista
Posted on Jan 04, 2009
Samson CO1U won't work - it's installed fine, the sonar LE cakewalk has installed aswell.. but for some reason it won't let me click on the Microphone to use as input. i am using windows 7 - will that have...
hmm that is strange, are you seleting the mic as an input in the source for audio? the software works on win 7. have you tried other mics in the input on your sound card?
Mar 19, 2011 | Samson C01U Consumer Microphone
I dont know why i can not record my mic into my nuendo4
plz first setup your driver. ten setup nuendo 4. device setup-vstaudio system-click switch
Apr 04, 2010 | Intel Steinberg Nuendo AudioLink PCI 96...
Cant get any sound from mic!!!!
Go into Play control on your computer. Click on options then properties. Look at your settings for playback and recording. Check play control and your source eg. microphone. To reach this double click on the speaker icon in your toolbar or you can find it under sounds and devices in your control panel.
May 23, 2009 | Samson C01U Consumer Microphone
SAMSON CO1U recordings sound like they're underwater on my MAC
The behavior you describe suggests that the mic is not getting power. Since it is a condenser mic, it requires what is usually called "phantom power". This should be provided thru the USB port. Check to be sure that the USB port is supplying that power. Check with another port for example. If that fails, you may have a defective mic.
Keep us posted.
Dan
Feb 10, 2009 | Samson C01U - USB Studio Condenser...
Static with playback on samson-gtrack with windows xp
i have the same problem with my g-track on a macbook im just going to take the thing back
it works for a feww min when i first start recording the is falls apart
Jan 10, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Sound quality not good at all
open up the sound icon on control panel...select recording......select samson mic....make sure set to default.....go into properties ...and boost main volume slider....most mics after install are set quite low and you have to go in and adjust the vol input level
Jan 03, 2009 | Samson C01U - USB Studio Condenser...
No good sound quality
ARE YOU RECORDING IN STEREO OR MONO
Sep 01, 2008 | Samson C01U - USB Studio Condenser...
SAMSON CO1U USB MIC FAILURE
Your first issue is vista... it just sucks. I would have to be there to figure this one out but im going to state the obvious, does it have an installation cd you didnt use? does it have online drivers you can find? Try looking around in your control panel and messing around with some of the options, good luck.
May 01, 2008 | Computers & Internet
Samson co1u recording issue
you first 3 people are idiots... maybe if you had worked with the hardware you would know how the mic works because its obvious you don't. The 4th person is correct because this is exactly how i use the mic and it captures sound in stereo format beautiful when set up rite. Using it in mono, whether use keep on one channel or two drastically reduces the crisp sound that this mic can record.
Mar 18, 2008 | Samson C01U - USB Studio Condenser...
Problem with Samson CO1U
Here are some instructions relayed from someone who was able to fix a similar problme with help from Samson tech support:
The C01U is a WAV device. Therefore, adjusting the slider for your default MIC input level on the volume control applet does not adjust the gain on the C01U. You access the actual volume control for the C01U as follows:
Start, Settings, Control Panel, Sounds and Audio Devices
Click on Audio tab.
Under "Sound Recording", insure that Default Device is selected as Samson C01U.
Once Samson C01U is selected as Default Recording Device, click on the Volume button just below the name. A new window will pop up, with a vertical slider. This window will be labelled "WAVE IN", however it actually does control the MIC volume for the C01U.
The key here seems to be that the USB device that represents the Microphone input (as far as Windows is concerned) is not a traditional microphone, but (as mentioned above) a WAV-IN device.
Jan 03, 2008 | Samson C01U Consumer Microphone
Samson C01U Consumer Microphone Logo
330 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
