Question about Arris Computers & Internet
How do I find the network key for Arris modem model TG882G
  • 86 Answers
SOURCE: pulse-dialing with Arris modem?
If you have the current firmware for your modem, it should work with pulse. Arris had to make it's MTA's pulse compatible due to old alarm systems that still utilize pulse dialing.
Posted on Jan 20, 2008
oldnovii
  • 667 Answers
SOURCE: how is Arris Telephony Modem installed?
Hi taldrich6 - You have this listed under Arris CM450. Is that what you have?
Posted on Jul 22, 2008
djxtreme979
  • 151 Answers
SOURCE: Switched to cable(arris modem) can't set up network
cable dsl same thing. Did you switch providers and get new modem from them? If so. Just delete previous netowrk and install new one let pc discover new one. Also, with your router you got a disc. It should install correctly. Perhaps it is previous network that is hindering you.
Posted on Dec 30, 2008
Geekman
  • 32281 Answers
SOURCE: How to secure my d-link wireless adapter with my Arris 550a modem
To make your wireless router secure you need to use your browser and type in the router's IP configuration address.
Then you need to change the default Admin password,
change SSID and turn off SSID broadcast,
setup the encryption (use WAP or WAP2 if your wireless card supports WAP) if not use WEP 128 bit encryption
and for added protection use MAC address filtering.
Posted on Apr 15, 2009
reyjoshua07
  • 1157 Answers
SOURCE: Arris Model: TM602G S/N: TM02AH1G6 Modem is not
Hi ltuttle650,
If your modem is not communicating with your Linksys router, your Arris modem was most likely installed directly to a PC or Mac when either you or a technician installed it. As soon as it connected it registered your MAC address from your NIC. You need to make your sure that the modem is still talking to the PC or Mac. Please try the steps below.
1. Find out what your NIC's MAC is (go to "Start", "run", "CMD", "ipconfig/all")
2. Copy down your NIC's "Physical Address." That is the MAC.
3. Go into your router's web based utility (Linksys is 192.168.1.1, username:none ; pw: admin) and click on the "Advanced" tab.
4. Then click on the "MAC Address Clone" tab.
5. Type in the number that you copied down. Click "Apply."
6. Now power cycle your Modem while it is disconnected from your computer and router. Power Cycle the router. After everything has rebooted connect the router to the modem and you should be good to go!
In most cases, this should work, and you ought to have internet access now.
If this did not work, the following is a quick fix:
1. Go to the 'Applications & Gaming' tab
2. Click the sub-heading 'DMZ'
3. Click 'Enable'.
4. Click 'Save settings'.
5. Wait for the settings to save, and click 'Continue'.
If this doesn't work, I would recommend calling your cable ISP and telling them that you need a modem that will work with more than one computer, or you need them to send a tech out who is able to set up the internet through a router.
Hope it helps.
Thank you for using FixYa.
Posted on Apr 14, 2011
I have an arris modem and my wifi keeps going in and out...called comcast they said we have to change the channel on the modem and i have to get in touch with arris.. how do I do this
If you have the model number we can assist you. There are several things that you need to know. Your password to the modem if you have changed it, You need to be able to connect directly to it with a network cable,
May 05, 2018 | Arris Computers & Internet
Find ssid and password
If you are speaking of a network key on a router that is not your own then forget it.
If you are speaking of your own router, check the documentation for instructions on how to reset it manually. This will clear all the information back to factory default, which included erasing any network keys.
Feb 21, 2012 | Arris Touchstone 450a (CM450) Modem
I need the wep security code for my sons dsi to download games on it from the internet. router name arris model # cm450a
When you did the initial setup for your router, you should have configured the wireless adapter in the router:
* set a SSID -- the "name" of the network
* set an encryption-level -- hint: use 'WPA' or 'WPA2'
* set a password for your network
It's that SSID/password that you need to enter on the DSI, to make a wireless connection to your router.
Apr 21, 2011 | Arris Touchstone 450a (CM450) Modem
How do you find a WEP Key for a Arris Model TM502G
The TM502G is an MTA (Cablemodem with 2-line phone adapter)
it does not have a router wired or wireless therefore there is no WEP Key to find
Sep 29, 2010 | Arris Touchstone 450a (CM450) Modem
Where do I find the WEPkey for Arris TM502G? The question is posted all over the internet, but no real answers.
The WEP key is a encryption key that is configured in the wireless settings of the wireless router. This setting is then applied to the wireless card in the computer so it can connect to the wireless router.
To secure your wireless network from unauthorized access, please click on this link and follow my instrucrions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Sep 19, 2010 | Arris Touchstone 450a (CM450) Modem
HELP
need to find the wep key
Mar 25, 2008 | Arris Touchstone 450a (CM450) Modem
Pulse-dialing with Arris modem?
Apr 18, 2007 | Arris Touchstone 450a (CM450) Modem
Computers & Internet Logo
288 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
