Will not power on
Went to turn on and no power-the lights on amplifier will not come on either-i have changed power outlets-but this is not the problem as my other equipment will run from the same outlet.
  • 4 Answers
CHECK THE REAR PANEL OF THE AMP FOR A FUSE RECPT. OR RESET BUTTON...IT MAY BE AS SIMPLE AS CHANGING THE FUSE OR PUSHING THE RESET BUTTON...
Posted on Jan 03, 2009
Went to turn on tv switched on plug nothing happening no lights on tv power going to
Either your electrical outlet went dead or the power supply in your television went dead. Verify operation of the outlet by plugging a light or other known-working appliance in and, if that is working, unplug your television for a minimum of one hour, plug it back in, and test. If it still does not operate, it will require further service.
May 12, 2015 | Televison & Video
Nuvo Essentia won't power up
First, try unplugging all of the sound system and plugging the amplifier into an outlet on a circuit that was not changed by the electrical work. Also, plug an outlet tester into the outlet you were using for the amplifier to make sure it is correctly wired. If one outlet in a system has hot and neutral reversed and others don't, this could cause problems with some designs.
If you are lucky, dirty power from sparking inside the circuit breaker crashed the control circuitry in the amp, and it just needs a hard reset (power disconnect/reconnect) to be made functional again. In the worst case, something got fried and you'll have to use instruments to track it down.
Apr 23, 2014 | Nuvo Essentia Amplifier
Adcom gfa 7000 amp makes a cyclic humming noise in unit not in speaker
Are your grounds to BARE metal sounds like a ground loop issue.
Feb 25, 2013 | Adcom GFA-7500 5-Channel Amplifier
The power has failed on my Acoustic Solutions SP-100 digital integrated amplifier
This is a wonderfull idea, a great way to learn about electronics. Open the top of the amplifier, check for any internal fuses, if they check out, the power transformer may be open at the primary, [ too wires ] If you have a digital meter set it on ohms and touch the probes on the too wires going into the transformer, if no reading the power transformer is open.
Jun 17, 2012 | Audio Players & Recorders
My 1210 was working fine the other day, my daughter was playing around with it turning it on and off but nothing too harsh. I went to turn it on today and there is no power what so ever. How do I change...
Your turntable may be plugged in to a "switched" power outlet on your receiver/amplifier. If it is, your amplifier needs to be on for your turntable to get power.
Apr 26, 2011 | Technics SL-1210 Turntable
My amp stopped working after 2 days from the day bought it. It stayed on standby for a while, about ten to fifteen minutes, but once I switched it on it started humming and making crack and pop noises.I...
Take it back for warranty replacement or repair since you only had it for 2 days. Since there is burnt smell this could be very serious problem. Probably a fuse blew due to any of several problems.
The pilot light runs off a rectified output of the power transformer but it is fused. There are three sopplies from the transformer and any of those could have a short and blow the main fuse or their individual fuses.
Take it in as I stated as this is NOT DIY repair. There are high voltages in this unit and if one is not adept at electronics you probably would not be able to repair it anyway.
Nov 29, 2010 | Peavey ValveKing VK112 50W Combo Amplifier
Capacitor shuts off
HI DUDE UR CAR BAT NEED TO B CHANGE PLUS UR ALTERNATOR IS GOING TO FAIL SOON ... THATS ALL ... IF U ARE USING NOW IT MAYBE COZ LOTS OF PROBLEM TO CAPICATOR
Apr 05, 2009 | Kicker DX700 Car Audio Amplifier
Protection light
double check the blue stereo input wire to amp is this a new amp if not speaker channels in amp might be blown
Nov 08, 2008 | Kicker KX120.2 Car Audio Amplifier
Flashing Protect light
what are u using to play music??
Feb 12, 2008 | Infinity Reference 5350a Car Audio...
 Grubhead
Grubhead
