Use one of the provided links for fuel mix ratios:
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
SOURCE: fuel mixture for Eager ****** 2.0 CID
40:1 is the proper ratio of fuel to oil mix. Mix the fuel and oil in it's own can and be sure shake the can thoroughly just before filling the saw each time. Be sure to use a modern synthetic oil made for saw use and fresh gasoline. Hope this helps!
SOURCE: chain saw
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel line for decay or other damage. Make sure you have fresh fuel mix in the tank (40:1) using a modern synthetic oil made for saws. If the above doesn't help, you will need to remove the carburetor, clean it inside and out with spray carburetor cleaner and check the lower chamber diaphragm for flexibility--no holes or cracks. If the two jet needles have been disturbed, turn both screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting which should allow the engine to start and run. Start the engine and allow to warm up, then pull the throttle full on and adjust the H needle CW until the engine starts to speed up, but 4-strokes. Correct adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for better idle, yet allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
SOURCE: what is gas/0il mixture for
Good quaility two stroke oil designed for chainsaws ( not out boards ) and designed to run at 50-1
