Question about Whirlpool Dryers
Dryer not heating up to max
Whirlpool dryer mod LGQ8800JQ0 is NOT heating up or not drying the cloths the way it use to. the vent is clean. It does heat though but we have to run the dryer a couple of times to dry them. What is going on?
  • 163 Answers
HI!!! check your home vent blow it with a blower it can be plugged inside the walls of the home..You cant see that..If problem is not solved then your thermal cut off switches are faulty..Good luck..
Posted on Jan 03, 2009
    Sergeant:
  • 311 Answers
99 out of 100 services calls i did with your complanit its the venting.to elimanate that as a possiable you dry a load with out venting[it wont hurt a thing]if dryes then,venting.if not ither your washer is not spining enough water out of clothes or the air passage ways in your dryer are restricted.ther is only one element if it heats ,its fine.could be electronic but most of time no.check it out.God bless,tom
2 Suggested Answers
vanni7
  • 163 Answers
SOURCE: my whirlpool dryer isn't drying
Hi!!! Your vent line behind your dryer is plugged clean it and all is fine again..Also get a blower and blow your home vent dryer hole its plugged. blow it from inside the house to the outside good luck.trust me its an easy fix..Good luck..
My dryer won't dry my clothes
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
Nov 27, 2011 | Whirlpool Dryers
I have a Whirlpool duet washer and dryer. The dryer is not working well. the ligts come on and it spins but it doesn't dry the clothes, what can the problem be?
Is it heating or not? Is this gas or electric? The first thing to check is your vent and clean the lint filter. Then you should check the heating element and the thermal fuses if it is not heating (assuming electric). If it is heating and you're not getting dry clothes then your venting must have issues. Good luck.
May 02, 2011 | Whirlpool Dryers
Won't dry clothes thoroughly
It could be or the moister sensor is bad. Do this first for most people never think of doing this. Disconnect the entire venting duct work. Inspect it and clean it. If you get a wad of lint every foot length from this vent this will be your problem in drying clothes. The clogged vent will not let the exhaust pass through and the moister sensor detects that and shuts off the heat automaticly
Apr 20, 2010 | Whirlpool LER7646E Dryer
Whirlpool dryer model #GEW9250PT1 not drying properly
when was the last time you cleaned your dryer?all a dryer does is move air around and if it can't cycle through the dryer the clothes won't dry. unplug the dryer and then you need to clean the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line,if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to clean it out,make sure the outside vent is clear first then blow it out,if it's a short run vac it out,most problems start just from lint buildup,the clothes don't dry the dryer runs hot and parts start messin up,also vac out under your fridge,take the bottom kick plate off and vac it out,you can kill the compreesor if you don't,good luck
Apr 05, 2010 | Whirlpool Dryers
Dryer is taking too long to dry clothes, even on AccuDry setting for Jeans/towels - it still is heating, just not heating enought to dry clothes, I have been doing two cycles at least for a very small...
Your house vent is restricted causing the long time to dry complaint.
Please clean the entire vent to the outside.
Also make sure the vent behind the dryer does not get smashed when the dryer is pushed back to the wall.
Jan 19, 2010 | Whirlpool GEQ9800P Electric Dryer
Whirlpool Duet dryer not drying like it used to
If your duet isn't heating properly and you have taken care of the lint problem then you could have one of two problems. Either you have a bad heating element or you have a bad fuse or temperature sensor.
If your dryer is not heating at all then it is most likely the fuse or temp sensor. If it is heating and just not enough it is probably a bad heating element.
Both problems would require a repairman to come and fix normally, however if you believe it is the heating element that can usually be replaced by the homeowner without too much trouble. Just make sure to ask where it is located from whatever place you but the new element from.
Dec 12, 2009 | Whirlpool Dryers
There is heat, but drying takes two cycles
Clean out your dryer vent. Many times the lint and other stuff plugs up the vent and slows the dry time down dramatically.
Aug 05, 2009 | Whirlpool WGD5300S Dryer
My whirlpool dryer isn't drying the cloths as it use to. It takes longer to dry the cloths ex rub the dryer twice to get them dry. it's whirlpool dryer mod LGQ8800JQ0
Jan 03, 2009 | Dryers
Dryers Logo
106 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
