Question about Dometic Refrigerators
Wiring diagram for Dometic 3 way refrigerator model RM4223
I am restoring a 10' non cab over Alaskan camper,and could really use the assistance
  • 68 Answers
SOURCE: Dometic rm4223 wont run at all
Make sure you have 12 volt DC power to circuit board. If you do you need a circuit board.
Posted on Mar 19, 2009
  • 127 Answers
SOURCE: Info on replacing drain hose on dometic model 2652
You will need to remove the fridge and set it on the floor or at least pull it forward enough to reach the top of the drain hose. There is clip that holds the drain tube to a nipple that sticks out of the back of the fridge that will need to be removed. Remove this clip and the drain hose should pull right off. Route the new drain hose down through the cooling unit coils to the door panel. Attach it back to the nipple with the clip and you should be good to go. The part number for the new drain hose is 2932749019.
Hope this helps,
Jeff
Rate me please!!
Posted on Jul 03, 2009
  • 9 Answers
SOURCE: dometic rm4223 has leaked coolant. The
You need a new cooling unit. That ammonia smell means that your heating unit is shot, needs to be replaced, and there are a coupla ways to go here.
1) Order up a rebuilt (or new) online, and replace it yourself. (Handyman skill level:fair.) $500.
2) Go to an RV repair shop and have that done $700.00 - $100.00
3) Buy a new fridge. $1000.00 ++
Posted on Jul 26, 2009
  • 193 Answers
SOURCE: Need wiring diagram or schematic for GE refrigerator
if you look on the back there should be one stuck to the inside of the case near the compressor. if not go here: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=TFX20JRSM
Posted on Aug 14, 2009
SOURCE: finding wiring diagram whirlpool refrigerators
take off bottom cover should be on back if not look around compressor they usually leave them stuck around there
Posted on Apr 12, 2010
Dometic rm4223 model does not run on 12v when traveling
You could contact me and I'll buy your old broken fridge, or you could buy my brand new rm4223 that is missing parts (but the cooling unit and cabinet are brand new, never used.
Sep 08, 2013 | Dometic WA3210 Compact Refrigerator
Replaced control board have 115 to board can't get 12v nothing lights on frig or in side where does 12v come from voltage is good in camper Couchman with Dometic md RM2652
The 12V comes from 2 wires that come from RV and affixed to a terminal block on fridge. Insure you have 12V at those wires. Also check the fuses located inside the main electronic board. ArctiCold Refrigeration We keep it cold 28659511-ac6f-4f0b-b8c3-c7ac7cf165ac.jpg 8e5a2b6c-5f1f-429e-8512-595071232c90.jpg
Aug 29, 2013 | Dometic Refrigerators
Our 1995 30FL Leisure Star camper Dometic fridge is not working. the camper is level. the Check light goes on after a few moments of turning it on.
Give Arcticold Refrigeration a call toll free tech support 1-888-782-6665 We will require the model number so please have that available. We will require more info to help with this problem such as results on electric, ect. ArctiCold Refrigeration We keep it cold da1720cc-2c8a-48ab-b560-ebb5655e2d6c.jpg
Aug 24, 2013 | Dometic RGE400 Top Freezer Refrigerator
Wiring_Diagrams
Main wiring to fridge is just the 12 VDC to rear of fridge which should be marked where they connect. What other info are you looking for ?
Nov 07, 2011 | Dometic RM2652 Refrigerator
I.would.like.instruction on fitting a 240v heater into a dometic 3 way frig model rm2553
The PDFs at the links below show how to check your heater element and show circuit diagrams.
http://gasrefrigeration.net/dom_techdata/2552.pdf
http://www.gasrefrigeration.net/dom_techdata/36044804.PDF
If you need any further assistance then just ask.
Jun 16, 2011 | Dometic Refrigerators
Dometic rm4223 has leaked coolant. The refrigerator was running but not cooling as we smelled ammonia
Jul 11, 2009 | Dometic WA3210 Compact Refrigerator
Camper fridge will not cool down(unsure of model)
ok firstly if you remove the element and give it 110v does it warm up if it warm up and still not making the fridge cold the propane chemicals are not right any more
May 15, 2009 | Dometic WA3210 Compact Refrigerator
Feb 15, 2009 | Dometic WA3210 Compact Refrigerator
Refrigerators Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
