Question about Toshiba 50HX70 50" Rear Projection Television
TV picture shaking!!!
My TV is going on 7 years old. No problems other than a convergence problem 3 years ago that was fixed. Now I have a picture shaking issue going on. The convergence seems fine and needs adjusting every few weeks with the weather. The picture shakes when first turned on then seems to settle for awhile. Thanks for any suggestions or help.
  • 4 more comments
  • HGTC Dec 24, 2007
    Sound like we have the very same problem. My TV is five years old and the shaking problem started about a month ago after I had to move it to replace the living room carpeting. Have not found a solution to the problem.
  • BrokenTV19 Feb 27, 2008
    Opps i think i posted for additional information. Anyways I am having the same problem, with the shakes, but the menu does NOT shake when activated. I have a mitsubishi of the same size and age.
    Thanks in advance!
  • Craig Heilman Feb 28, 2008
    My Toshiba is now going on 8 years old. The past few days I've had to adjust the convergence. The shaking is not consistent - it seems to occur at the start up. The shaking is not severe, but it is consistent with the picture regardless of whether cable or video. Picture quality is still good. Shaking goes away after awhile.
    Since the set is getting older - I doubt the repair costs are worth investing more $, especially with the new HDTV's and lower costs, etc.
    Can a lay person check the hyper board? Where is it and are there ways to "look" at it to tell if it's failing? (Dark spots, fused links, etc?)
    Thanks
  • jhoffman1223 Nov 29, 2008
    I have this problem as well. The menu shakes along with the picture. It is intermittent.
  • BrokenTV19 May 11, 2010
    Highvoltage, I have the same problem, and the menu does NOT shake when i hit the menu button. Does this mean it is something other than the hyper board? My tv is a vs 5006r (mitsubishi).
    Thanks in advance!!
  • kris Jul 20, 2013
    I have a toshiba 57h81 projection tv screen is shaking zig zag wise but menu shows fine also when i do pop (side by side screens) the one on the right is working just fine but the one on the left still is shaking and full screen always has some shake to it please help me
  • 24 Answers
It sounds like the Hyper board is begining to fail....Does the menu shake too?
Posted on Jan 11, 2008
2 Suggested Answers
albertv29
  • 87 Answers
SOURCE: TV picture shaking!!!
You have a Hyper module problem.Very common with these chassis.Toshiba part # 23148024.This part is no longer available,but it can be repaired.I dont know how much electronics training you may have but it`s a pretty detailed job.The hyper board is the silver stand up module inside the unit right behind the external Audio/Video jack panel.There are 11 little capacitors that all need to be replaced.The value of these caps are 10uf @ 16VDC.I do this job for about $245.00 and the unit works fine.Check with your local shop if it is too much for you.If you don`t know what you are doing you can ruin this module then it`s time for a new set.Good luck.
Posted on Jan 15, 2009
I have a 42" Maxent plasma TV about 7 years old.
Is it 7 years old? Marvelous. Exciting. the lifetime of Maxent televisions are 6 moths the most!!!
You're lucky.
May 12, 2017 | Maxent MX-42VM10 42 in. HD-Ready Plasma...
My Mitsubishi TV is about 12-14 yrs old. The
DLP projection tvs are bulky and have a design flaw in the convergence board the 2 STK convergence ICS alway dies constinely require replacement,if u use about 4 or 5 hours day in and day out.If the old Mitsubishi tv several years since is was repair,u use it alot?If yes,it time to retire it,and buy the refurbish Plama tv.Not,than get the old tv repair.U Know how to solders?Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.U can go to You Tube type in Convergence problems will see a tutoring video in repairing 2 STK Convergence ICS.
Mar 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
The left side of the picture has red and green stripes and ghost images. The right side does not have this problem, but the picture is not quite right. The convergence chips were replaced two years ago and...
That sounds like the convergence problem I had about a year ago, and like you, I replaced the convergence chips and that fixed the problem. It's cheaper to replace the chips if you do it yourself, but maybe not if you send it out for repair. If you can find an exact replacement board, that would fix it too, but I wouldn't necessarily expect it to last longer. The advice I read on replacing the convergence chips in my rear projection TV was that they would last 2 or 3 years and then need replacing again. So you're within that range.
Feb 27, 2010 | Sony KP-51WS500 51" Rear Projection...
Hi I have a toshiba 50h82 tv that is 7 years old with a convergence problem with the red and green lines that is going to cost $400 to fix but now that I am thinking about it before the convergence problem...
You are describing 2 different problems. The convergence problem can be fixed by either resoldering the convergence ICs or replacing them. These ICs cost about $25 each and there are 2. I suspect that the $4oo is for replacing the convergence board. This should not be necessary as the board can be fixed. Also, the brightness problem can be dirty CRTs, dirty mirror or faulty coolant fluid on the CRTs. If the picture was good prior to the convergence problem, the set is probably worth the repair if you can get the board fixed. While the board is being repaired, the service shop should be able to tell whether or not the brightness can be adjusted.
Dan
Oct 12, 2009 | Toshiba 50H82 50" Rear Projection...
Jan 15, 2009 | Toshiba 42H82 42" Rear Projection...
Panasonic 47wx53 covergence issues
Is the power indicator flashing three times? If so the Ics have shorted shutting the set down. You will need two STK392-110 convergence ICs. You can get replacement ICs at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Aug 18, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Three colors are not together
Convergence problem needs two ic 's to fix.
May 25, 2008 | Philips 55PP9401 55" Rear Projection...
RCA HDTV blurry
this indications that you have a problem with convergence. first try to go into customer menu...setup....convergence. and see if the convergence will adjust.. if it wont then you have a problem with the convergence cuircit boards.
Oct 05, 2007 | RCA HD52W59 HDTV Projection Television
Power supply/convergence issue...
Your Projo is a complicated piece of equipment, involving 3 picture tubes (like 3 tv's), convergence failures are extremely common, I dont think $550 is totally unreasonable, but I dont think it is a power supply issue if it is just effecting 1 color, usually it would cost around $100 parts $300 labor to repair, might be a little high, I suppose they are also charging you for pickup and delivery, I hate taking sets into office as that sometimes jars stuff loose or cracks boards.
Jul 10, 2007 | Panasonic PT-47WX51 47" Rear Projection...
Wavy picture
this is caused by a bad convergence module, and there are probably some dried out electrolytic caps in the circuit as well. i have one in the shop right now that came in with the same problem. if you have it serviced, make sure they replace all of the convergence modules (there are usually 2, but sometimes 3 of them), because if one went bad the other(s) is likely to go out soon as well.
Jun 28, 2006 | Toshiba 65H82 65" Rear Projection...
Toshiba 50HX70 50" Rear Projection Television Logo
4,146 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
