Question about Whirlpool Duet GHW9150P Front Load Washer
I am getting an F1 error message on my new Whirlpool Washer
I paused the washer to "add a garment," something I have done dozens of times before.  Now it will not restart.  I am getting an F1 error message.
Help.  What can I do.  I am virtually without a functioning washer.
  • 530 Answers
Is this a whirlpool frontloader if so you have a faulty control board it's located under the lid. you can remove with 3 bolts 1/4 " socket . and the board is located on the front right side
Posted on Jan 04, 2009
I pressed the pause button to add a garment to my Whirlpool frontload washer. After doing so, I pressed the hold to start button, but the washer would not restart the cycle.
Switch the power off from the power outlet for a few minutes , then switch on and reset the wash cycle . Front loaders are not designed to add clothes mid wash.
Mar 18, 2015 | Whirlpool Washing Machines
Whirlpool Duet washer - paused cycle to add a garment now can't get it to resume cycle or clear the cycle.
I did as Drunan did and unplug for 10 and plugged it back in and it started like a champ! Thanks!!!!!! ;)
Jan 16, 2012 | Whirlpool GHW9300 Duet Washer
Whirlpool washer duet is flashing after adding garmet. Will not return to washing
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 29, 2010 | Whirlpool GHW9300 Duet Washer
Whirlpool washer Model WTW6600SW2. Error F1
My boss's washer has the same problem, located the tech manual inside the washer at the front it was saying to check the pressure hose for any kinks if no kinks found and problem continues replace the motor control board.
Nov 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a whirlpool ghw9100lw the light is flashing but it will not start
Aug 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Can't get washer to start again after pushing pause/cancel button
sounds like central control unit problem, you can check for diagnostic mode operation by setting (door closed) drain/spin, no spin, pressing prewash 4 times in 5 secs pressing prewash again will advance through diagnostic cycle. replacing user interface may also be necessary
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F1 error code on cabrio washer
CALL 18002531301 AND TELL THEM YOU HAVE THE F 1 CODE PROBLEM. THEY HAVEN'T CALLED THIS A RECALL, BUT THEY ARE CALLING IT A CUSTOMER AWARENESS PROBLEM.
WHIRLPOOL IS SENDING TECHNICIANS OUT NEXT DAY FREE OF CHARGE.
T W
Feb 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Call Whirlpool at 800-253-1301 in USA. There is a recall on this washer for the F1 code. Service call and parts are free. I just did it today.
Jan 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Duet Sport, brand new. It keeps asking to add a garment when the washer is jam-packed with clothes. Is it a malfunction, does the "add a garment" light ever shut off?
the add a garment light will stay on through most of 1st wash this lets you know that if you forgot something it can still be added ..if not already overloaded..by pressing pause the door will unlock and allow something to be added ..yes it's normal
Aug 10, 2008 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
265 people viewed this question
Dan Webster
Dan Webster
Sal De
