Question about Conair Health & Beauty
How do you change the battery on everweigh healthometer scale?
5 Suggested Answers
SOURCE: How do replace the battery on a EverWeigh Lithium
The battery is located behind the LCD screen, slightly on the right hand side side if you are facing the LCD screen. You can drill a hole on the platic case from the back of the scale, and you will see the battery house and 3 screws on the battery house lid, unscrew the 3 screws, you can take out and replace the 3V Eveready button type battery easily.
I have tried to open the case by taking out the spring latches located behind the 4 legs of the scale, it was much harder to put every thing back afterward.
Yi from San Jose, CA
Posted on Jan 08, 2010
SOURCE: Unable to pop battery compartnent in Health o meter EVERweigh
The whole top cover which is the part that you stand on (loading platform) comes off. Turn the scales upside down, pull the sides of the plastic cover to unclip the catches and the body can be removed from the cover. Remove the screws to the displlay and there will be a battery compartment underneath the display. Remove the cover to the battery compartment and make note of the battery orientation. Replace the battery in the correct orientation or you will destroy the scales. Repace the battery cover. Scew the display to the body. Press the cover on the body with the display showing through the window.
Posted on Apr 30, 2010
SOURCE: Healthometer Bathroom Scale
http://www.healthometer.com/Manuals.aspx
Posted on Aug 23, 2010
joeguest2
  • 2080 Answers
SOURCE: I lost my instruction manual
Look on the bottom of the scale for a sliding switch to alternate between Kg and lbs.
If you do not see one then remove the little cover and check inside the battery compartment for it.
Good luck.
Comment back here and rate with 4 Thumbs up if this was at all helpful.
Thank you.
Posted on Feb 23, 2011
I want to change the time and date on healthometer scale
Google (healthometer)(model)(manual) without parens to get instructions.
Jan 25, 2017 | Healthometer Health & Beauty
Changing battery in everweigh electronic scale
This should be a relatively simple process of finding the battery compartment, opening it, removing the old battery, installing the new one (observing correct polarity), and closing the battery compartment.
Nov 10, 2016 | Health & Beauty
Healthometer change kg to lbs
With scales off. Hold select button for approximately 5 seconds, lbs flashes hit select to confirm
Apr 28, 2012 | Sunbeam Healthometer Body Fat and Weight...
I have a healthometer model bfm884dqn-60 and i have already set the height the first time. how do i change it?
Took me a minute or two to figure this out. You hold the number of the user that you want to change (1-4) and then, while holding it down, you press and hold the 'select' button. The screen will blink, and after holding both down for a few seconds, a flashing 'Erase' message will appear. Select YES, and then you can enter new information.
Feb 06, 2010 | Sunbeam Healthometer Body Fat and Weight...
Jun 05, 2009 | Sunbeam Health O Meter Body Monitoring...
Health & Beauty Logo
62 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Julia Tatspaugh
Level 1 Expert
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
