Question about Quad Disc Brake Rotor 160mm Bicycle Bike
I have a unilli cx100 quad and ai am finding it hard to get parts like battery,and brake pads can you help!!!!!!!!!!!!!!
A local dealer in galway ireland, got both for me! http://www.galwayquads.com/
Posted on May 27, 2009
  • 4 Answers
EBAY .....
Posted on Jan 09, 2018
    Welcome Back:
    Visited the website for 2 consecutive days.
Coild some one send a detail picture of wat way the loom goes on these
Unilli cx100 - kick start not engaging properly - works sometimes - appears to be a spring missing - where do u get such a part?
Posted on Aug 07, 2010
Mototech mini quad. Where do I charge it
Looks like you need a battery charger. It has two 12 volt batteries. Didn't it come with a charger? And your parental control is via a key.
The MotoTec 24v Mini Quad v2 is the ultimate kids atv! Great for driveway and backyard fun, cruise over bumps and speed through dirt trails with ease. Comes standard with front & rear suspension, front & rear brakes and large 13 inch knobby pneumatic tires. This mini quad provides longer ride times than the competition with TWO large 12v 12amp hour batteries. New features include: headlight, key start, battery meter, forward & reverse, 2 speeds selectable by key and twist throttle with safety foot switch. SAFETY FIRST - ALWAYS WEAR YOUR HELMET AND ALL SAFETY EQUIPMENT AND OBSERVE SAFE RIDING RULES!!! Motor: 24 Volt 350 Watt
Battery: TWO 12v 12ah (24v Total)
Top Speed: 5 & 10 MPH (parental speed control by key) Recommended Age: 6+ years old (A parent's decision to allow his or her child to ride this product should be based on the child's maturity, skill and ability to follow rules.)
Max Rider Weight: 150 lbs
Frame: Steel
Tires: 4.10-6 Knobby Pneumatic (13 inch)
Brakes: 2 disc front, 1 disc rear (with parking brake)
Suspension: 2 independent front shocks, 1 rear shock
Throttle: Variable twist-grip (with safety foot switch)
Seat: Padded (single rider)
Handlebars: Adjustable Forward/Back
Battery Meter: Yes
Key: Yes
Headlights: Yes
Charging Time: 4-6 hours
Charger Included: Yes
Assembly Required: Yes
ATV Size: 42x23x25 inches
Handle bar height from ground: 25 inches
Seat height from ground: 19 inches
ATV Weight: 101 lbs
Box Size: 43x25x22 inches
Box Weight: 114 lbs
Product decoration and specifications subject to change without notice.
Warranty: 30 days parts replacement
MotoTec 24v Mini Quad v2 Blue
Dec 09, 2015 | MotoTec Kids ATV-24v Mini Quad
When i drive over 50k(australia) my front drivers wheel sqeaks and it does it too occasionally when i break. been happening for over 2 months so i rule out that its dirt in the breaks. what could it be...
wow first post ever for country, im GOBSMACKED !!!!
wheel ?steering wheel or tire/wheel.?
hard to find, they are, all squeaks.
first is to see if possible to do, no moving (big safety issue, yes)
bounce the corners of car hard, by hand.?
jack car up spin tires. by hand,
lever them below off ground, to see of balls are shot.
inspections here, look at every inch of suspenson and parts.
Brakes, i hope nothing breaks the brakes.
The brakes all squeak this is normal try lightly pressing the brake pedal, gently while moving slow, squeaking now is 100% normal and harmless. (the pads act like Guitar strings)
Use pad glue to halt it, or ignore it like me....
the pads have wear markers, they have this device that makes noise when pads get too thin, (look at em)
bad wheel bearings.
brake backing plate bent.
caliper guide pins rusted.
and lots of other things bad or just ok , old and making noise, like
suspension "A" arm bushing rusty, or stable bar , same.
moving noise is real hard to find.
Sep 12, 2013 | 1997 Honda Prelude
2002DodgeRam1500 quad cab,when I drive in reverse,to park,when I hit the brakes a noise comes out like an old drum brake ,except mine are disc brakes.The pads are thick and even.Any ideas
well if your brakes are working well i would ignore it but if brakes don't work well i would take pads off the rear brakes and lubricate the slides and also put some behind the pad plate where the piston touch's the pad!! when u put brakes on going forward the pads slightly move forward and then when you go backwards it moves even more and i think thats what causing it!
Mar 25, 2013 | Cars & Trucks
Unilli cx100 piston set
Hi can i assume you meen the Moto Guzi CX1OO, if so try an owners club you will be surprised what you can get, try the link below.
http://www.vintagemotorcyclesonline.com/features/bike-of-the-month/129-moto-guzzi-850-le-mans-ii-and-cx100
Good Luck
lacala69
Apr 30, 2011 | Computers & Internet
Razor four wheeler runs well for a while but loses power after short time has new battery
we had a similar problem, but it turned out to be the back brake caliper was binding due to misalignment. There is a screw on the caliper to adjust the alignment between the pads and the rotor.
Oct 24, 2009 | Razor Dirt Quad Bike
Excessive wear on 1997 s type jags rear brakes
Unfortunatly this is normal, nothing can be done about it. Get pads checked every 15,000 miles to save discs.
Sep 03, 2009 | 2007 Jaguar S-Type 3.0 Sedan
Open Questions:
Quad Disc Brake Rotor 160mm Bicycle Bike Logo
1,406 people viewed this question
Top Quad Cycling Experts
shaun taylor
Charles T Nevin
Charles T Nevin
Are you a Quad Cycling Expert? Answer questions, earn points and help others
