Question about Bose Audio Players & Recorders
Reset bose qc15
Noise-cancelling does not work
SOURCE: the bose noise cancelling 2
Change the battery or batteries. If that doesn't work they have to go back to Bose.
Posted on Mar 05, 2011
SOURCE: i play drums, and when
Does this problem only happen on when playing drums? For me, when my battery is running low, if I move my head back and forth quickly or lightly tap the right headphone, they will clip in and out briefly, but replacing the battery always fixes this. My guess is that you are playing drums a lot, your battery is running low, and you might be throwing your head around violently, causing a similar problem.
Posted on Mar 20, 2011
Geekman
  • 32281 Answers
SOURCE: Bose qc15 no sound
Try the headphones in another stereo and if it still has no sounds the the headphone cord or plug is faulty.
Posted on Apr 10, 2012
SOURCE: My Bose QC15 won't turn on, I've already tried replacing the battery. What could be the problem?
Mine did this as well, totally frustrated I kept on rapidly switching them on and off, and eventually it just switched on!
Posted on Jun 23, 2012
murf427
  • 336 Answers
SOURCE: Bose QC15 makes a high pitch noise
Go to support on the Bose website. Enter your model number and click on trouble-shooting. They should have your solution there.
murf427
Posted on Aug 02, 2012
How won't my new headphones connect with my I pod through bluetooth
In most cases this is because the new owner didn't read the instructions.
When you turn on Bluetooth on the iPod and click Search, you have to press something on the other piece of equipment to send the signal TO the iPod. Once they find each other, they connect automatically after that.
However, we have a problem. Your headphones Bose Quietcomfort Qc15 don't appear to be Bluetooth enabled! You have to connect with a lead.
http://worldwide.bose.com/library/assets/pdf/guides/headphones/qc15/en/owg_en_qc15.pdf
manual is also here
Bose QuietComfort 15 Owner Manual Page 4
Jul 20, 2016 | Bose Quietcomfort Qc15 Acoustic Noice...
Bose qc15 right side not working
If the cup itself is not cracked or broken, you can carefully detach the "snap on" cushion to expose the inner workings. There may be an inner cover which also can be carefully detached to expose the wire connections. After making repairs, reverse the disassembly process.
Jan 10, 2014 | Bose QC15 Headphones
murf427
Aug 02, 2012 | Bose Radio Communications
Bose qc15 no sound
Apr 10, 2012 | Bose QC15 Headphones
Mar 25, 2012 | Bose QC15 Headphones
I play drums, and when playing with my QC15's on certain loud sounds seem to make the noise cancellation clip and cut out audio for a second. why is it doing this?
Feb 15, 2011 | Bose QC15 Headphones
Bose QC3 makes a high pitch noise when i press it against my ear
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a siginficant reduction in the outside noise getting to your ears.
The airspace inside the earcup is a tuned chamber defined by the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs. When you press the earcup close to your ear, you are changing the size and shape of the air chamber inside of the earcup thus directing more of the speaker sound toward the microphone than the design can compensate for causing audio feedback to occur. You are hearing that feedback. Removing your hand from the earcup should restore the shape of the air chamber allowing the circuits to return to normal operation.
If the feedback occurs too easily when you are NOT pressing on the earcup, then the foam may have weakened/deteriorated and it may be time to replace the ear cushion.
On my QC-3 headphones, I can cause the feedback squeal in both earcups, with the left earcup being more sensitive to the shape change than the right.
Feb 16, 2009 | Apple Bose QuietComfort 2 Acoustic Noise...
87 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
