Question about HP Office Equipment & Supplies
Hp laserjet cp3505 black roller smudges
Whenever I print a document, black smudges appear on the front of the finished printed product. The smudges are obviously from the rollers that pick up the paper, however I have tried cleaning every roller that I can find and nothing is making these smudges go away. I'm printing on cardstock for this project and set the paper setting to cardstock. The smudges are much darker and apparent on this kind of paper as opposed to regular paper. Help!
inferno45
  • 45 Answers
SOURCE: roller marks on paper
Hi, Sounds like your problem is not the rollers. If its marked on the pages, its not the pickup rollers nor the Exit rollers that leave marks.
Either 1 you have a bad Toner Cartridge. or 2 Fuser sleeve is bad and needs to be replaced.
(1) If the toner cartridge is refurbished that is your first indication that you should replace with a HP Manufactured Toner. Refurbished toners always go bad. In fact many of them do not even last the amount they are said to last.
(2) If its not the toner cartridge, then the only other thing that is fusing roller marks is the fuser. In order to do this. You will have to remove the back panel. Unscrew the fuser.*note fuser can be extremely hot after use. be careful.* From this point you should be able to look at the Fuser sleeve and see a worn out sleeve on the side which your roller marks are at. You will either need to replace it if it looks bad. Or you can clean it when its got with a piece of paper or an alcohol pad to remove excess toner clocked on the fuser.
That toner is whats showing up as roller marks on your prints.
I hope this helps. PLEASE RATE Porfavor :)
Victor C.
If you need more detailed help please comment back ill be willing to help. I like helping others.
Posted on Oct 10, 2008
mickspaceNET
  • 115 Answers
SOURCE: HP LASERJET 4 PAPER JAM 13
Rollers do not turn on!
Rollers are driven by a motor.
How is the printer telling you this information? (does the PC give an error, or the printer flash lights)
Does the paper make it out of the machine?
Is this "Rollers in the Back" the Fuser Unit?
is The Fuser unit is going bad,
if you open the back top cover, where it gets real hot, where the paper exit's, you should see two rollers, one orange, one either brown or black.. if that orange roller is damaged, has crease's, or covered with black toner, if the paper jams here alott, you probably need a new fuser unit. there is a pm kit available which includes the fuser and rollers, transfer, etc, which this site might have
http://www.all-laser.com/cgi-bin/webc.cgi/Menu_HP_maint.html
Posted on Oct 23, 2008
Inkworks
  • 87 Answers
SOURCE: HP Laserjet smudges across entire page
More than likely you have a bad toner cartridge.
Inkworks
866-381-0541
Posted on Nov 21, 2008
  • 85 Answers
SOURCE: HP Laserjet 3050, need to press ok each time printing
did it work before? check paper size for trays - suspect it is set for a4, change to letter size
Posted on Mar 13, 2009
  • 202 Answers
SOURCE: HP Laserjet 3600 Fuser
google feedroller and go to their site they have the service amnual on the printer. you will need it if you never done one before.may as well check the corona wire while you are there.
Posted on Jul 20, 2009
Printing is fine, copying is a black smudge
if you print correctly, the damage was photocopied unit, should be dirty, it should be cleaned.
Nov 13, 2013 | HP LaserJet 1100 Printer
My HP LaserJet 1300 printer smudges the entire document and the toner is very faint. The cartridge has toner in it.
It means your machine needs cleaning. You can purchase cleaning sheets from the office supply store, and insert it like a regular document, hit print, and the dirt comes off.
Dec 21, 2012 | HP LaserJet 1300 Printer
HP LaserJet 4Plus - just changed the fuser and rollers - was getting smudges and shadow on the printer paper. Now getting (on the left 1/4th of the page) light areas with little or no print. The shadow...
Take the toner cartridge out of the printer. Shake it side to side. Reinstall it and print something.
See if that fixes the output.
Could also be the transfer roller.
Jun 28, 2011 | HP LaserJet 4 plus Printer
My HP 4100 printer prints with a black smudge clear down the page. I clean the roller but continues to print bad copies. Should I replace the cartridge?
Problem is either the cartridge or the fuser.
Put paper in the manual feed tray(tray 1)
Print something. When the paper gets 1/2 way into the printer, open the
top cover. Pull out the toner, look down at the paper.
If it has the smudge replace the toner. If no smudge, replace the fuser.
Apr 29, 2011 | HP LaserJet 4100n Printer
I'm printing on my HP LaserJet CP3505. Documents are being printed from Print Shop Deluxe. When my document prints it leaves out one graphic on the page and following the printed document a page prints...
this error means that the image doesnt meet the specifications of the program you're using. which is really strange....you can try to reinstall the program, but make sure you remove it completely first. reinstall the program and make sure you have updated the software (if you can) update your printer software and dirvers as well. if the issue continues, them you'll have to find another software to use for what you're trying to do, because thats more than likely where the problem lies.
Sep 24, 2009 | HP LaserJet CP3505n Printer
Black bar printed in the center of copied document
try copying the document to your computer and then from computer take a print out.
Aug 23, 2009 | HP Photosmart 2575 All-In-One InkJet...
Ink smudges on the right side of the paper
Your problem is due to a worn fuser unit (upper fuser roller).
The teflon coating has worn again, alowing the toner to stick to the roller and then "repeat" about 3x down the paper (getting fainter each time).
You need to order a new fuser unit.
Click here to go to HP direct
RM1-1083-070CN Fuser assembly - 110 VAC - For LaserJet 4250/4350 series RM1-1083-070CN Fuser assembly - 220 VAC - For LaserJet 4250/4350 series
Make sure you order the currect voltage (US or UK)
Regards
Vince.
Mar 04, 2009 | HP LaserJet 4250n Printer
HP LaserJet 1100A unwanted toner marks on face of print
check this link,
either fuser or print drum. to verify , start print job, open door before finnished and see if marks appear before or after fuser. Before paper gets to fuser toner ink will smudge.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl70340#RepImgDef
Feb 15, 2009 | HP LaserJet 1100a Printer
Poor quality smudge and ink blotting marks in the centre of any printed document
Try performing a test by printing a test page from Tray 1 and open the top cover as soon as the paper is 60% inside. The paper would jam below the toner cartridge before it reaches the fuser. Remove the toner cartridge carefully and verify if the smudges occur. This would eliminate the fuser. If the print quality is fine, then you need to swap the fuser.
Oct 30, 2008 | HP LaserJet 4250n Printer
Hp laserjet 3380
The problem is not your scanner, is in the rollers, the rollers are smudged with ink or other mateial or your glass is smudge, remove the four star bolts on the top and clean the undersurface of the glas with a conventional glass cleaner wipe and re install the top cover.Be careful with the ribbon cables connected to the circuit board.
Oct 29, 2008 | HP PSC 1315 All-In-One InkJet Printer
Seeker5211
Seeker5211
