Question about GE Profile WPRE6100G Top Load Washer
Ge WASE4220A0ww will not drain or spin
GE Profile, agitates but does not drain or spin, makes humming noise when it reaches the drain/spin cycle. Last week we left it open overnight to let clothes soak, next day water had leaked on the floor but tub was full. Seemed to operated normally for the week then this new problem yesterday. We were going to open it up to investigate if the pump was bad but can't even get the cabinet open!
  • 163 Answers
HI!!! You seem to have a bad transmission or a bad motor they are all expensive to repair..Good luck..
Posted on Jan 03, 2009
Make a humming noise and spins very slowly
MINE DOES THE SAME. HOUSING IS CRACKED THAT ATTATCHES TO DRUM. WHITE METAL CANNOT BE REPAIRED.
Jul 25, 2010 | GE WPXH214A Front Load Washer
Ge PRofile Mod # wpsr31001ww
CHECK THAT DRAIN PUMP IS NOT CLOGGED, THEN CHECK DRAIN HOSES, . IF NOT CLOGGED, IF GOOD THEN CHECK PWR TO DRAIN PUMP. IF U GETTING PWR TO PUMP,AN NOT SPINING OR HUMMING REPALCE PUMP
Aug 19, 2009 | GE Profile WPSR3100W
GE Profile Washer WPSR3120W2WW agitates but won't drain/spin
Your drain line is more than likely plugged with a sock or something of that nature.
Aug 11, 2009 | Washing Machines
My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Jul 15, 2009 | Washing Machines
1.5 year old ge profile washing machine will not agitate or spin
Timer seems to have gone bad. Manually move the timer to make the dryer spin. If you get it to spin and drain then it's your timer.
Jul 01, 2009 | GE WDSR2080D Top Load Washer
I have a GE Profile Prodigy top load washing machine. Sometimes the spin cycle does not spin, sometimes it spins. It makes a clicking noise during gentle cycle
The gears maybe going out. Sometimes it is able to engage in the other direction which the spin, sometimes not. Washing machine have complex gears that in one way agitator works, and the other the gear locks to turn the whole tub. The clicking noise is probably the locking mechanism in the gears that has caused the whole intermittent problem.
Jul 01, 2009 | GE Profile Prodigy WPSE4200A
Agitator problem
Check to see if any thing is under the agitator. If not then maybe the bearings going out or other part of machine . Besure the cap is tighten so agatator don't come off. Check for ware on agatator top to the tighting nut.
Jun 02, 2009 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
Ge profile prodigy make clunking before spin cycle
Is there a humming sound? Check you have the hot and cold water supply turned on. Check the water inlet hoses are not kinked.
May 03, 2009 | GE Profile Prodigy WPSE4200A
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
GE Profile WPRE6100G Top Load Washer Logo
321 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
