Funny smell wdl520 and all lights flashing
Water not emptying, door not opening, funny burning smell and all lights on the pannel flashing.
SOURCE: can't get locked door open
For the door locking problem, on several of the Bosch washers, there is a round plate at the front bottom with a hole in it. One can place a thin phillips screw driver or some thing that goes in and turn the plate while pressing the plastic latch behind the hole to open the plate.
There is a mecahnical door lock release mechanism you can see or reach inside. Open the washer door while pulling on that. You can atleast get to your clothes inside.
There is a filter/drain mechanism inside this area. The manual and the postings here suggest a few more things you can do further to remove junk/blockages in this, but that is a messy job.
Posted on Mar 09, 2009
  • 109 Answers
SOURCE: hotpoint aquarius WDL520 all lights flashing not
There should be a small door at the front bottom of the machine, open it and unscrew the plunger. try that first as there could be a blockage.
The machine will not spin until the water is drained out.
Posted on Jun 17, 2009
venexcsd
  • 1185 Answers
SOURCE: A1400WD has not emptied and has flashing lights
Get some buckets
Take the drain hose off the back of the machine, undo any clips so that it lays it down flat
Put the end into a bucket and the machine will drain off.
When water has stopped running switch off the machine leave it for a few minutes and then put it into a spin cycle
Leave the hose in an empty bucket
That will dry the clothes and relaese the dorr
Your next problem is getting the obstruction out of the drain pump
For that you need a man that can
Posted on Oct 20, 2009
  • 713 Answers
SOURCE: My Performa PAVT920AWW washer will fill with
might b motor fault or jammed gearbox.when motor turns one way it drains and spins, when it turns other way it agitates,might b jamming when it turns for agitate.try looking under unit and remove belt, then turn main drive pulley by hand clockwise then anticlock to see if it is jamming. turn power off first dont want any accidents.please reply to see how u go.good luck
Posted on Apr 09, 2010
FitzOriginal
  • 842 Answers
SOURCE: Smell of 'dirty'water when door
Some washing machine guys call this a "Bug" in the machine. Usually caused by a build up of bacteria from the baterial washing powder you use. The easy way to fix this is to use an anti biological cleaner.... Which is what dishwasher tablets are.
Take 3 dishwasher tablets, throw them in the drum, put the machine on the hottest wash you can select and let it run the full cycle with no clothing in the machine. This will probably fix your problem.
Posted on Jun 21, 2011
Wont drain..door locked..what do l do?
put drain hose below water level when empty should spin
Apr 17, 2015 | Washing Machines
Smoke, burning smell coming from my machine. Door wont open and clothes and water inside is black
the bad smell you refer to is a smell of the electric motor burned out have the motor replaced the machine should be ok
Nov 23, 2017 | Whirlpool Washing Machines
Burning smell
Well I can tell you one thing for sure. Unless you Want a Lot of guys with funny hats on in Big Red Trucks with lights on Also! Keep your machine off...UNPLUG it now! Leave it alone, let it die peacefully. Get a new one! Burning smell means ONE thing...FIRE!
Jan 16, 2014 | Indesit Washing Machines
Door won't open
pull out the plug
take off the top cover
put your hand into the machine on the lock side
you should now be able open the door
Dec 23, 2013 | Bosch Washing Machines
Fridge smell and taste makes you sick, very clean and no food in it
Keep it open for a 4 or 5 hours... Then keep some cut lemon inside it.
Oct 27, 2012 | Hotpoint HSS25GFP Side by Side...
Used our humidifier last winter, cleaned it, dryed it, and put it away. took it out to use it and it was a little dusty, so i cleaned and dryed it again, but for some reason it wont work. when you turn the...
If it smells like plastic burning. Stop using it immediately. As there could be an electrical short or overheating of the unit. If doesn't smell like plastic burning, you'll need to be more descriptive of what the odor smells like.
Feb 09, 2011 | Hunter 33201 Humidifier
Can't get ice or water from the door
I smelled something burning. after that the light at the dispenser does not come on, the other indicator lights work. but can't get water or ice from the door & solenoid got just 36v instead 120
model # lsc26905tt
Jul 20, 2010 | LG LSC26905TT Side by Side Refrigerator
Hotpoint aquarius WDL520 all lights flashing not spinning water still in bowl cant find instructions only bought it at xmas
Jun 17, 2009 | Hotpoint Aquarius WD63 Front Load...
Mildew smell in front loader
Yup! I have the same issue with a WE206BNW (Canadian model). Did the same thing - dried the water off the door and leave the door open when not using it. Sort of helped, but then I ran an empty light load with bleach through it - no clothes, just water. Helped a lot.
Henkfish
May 10, 2009 | Samsung WF337AA Front Load Washer
Empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
