Question about Sony Playstation 3 (PS3) Console
Ps3 wont hook up to my wire less g router
Cant find a way to connect. the ps3 just says "no ethernet cable plugged in"do i need an adapter or is there something i'm missing?
    Problem Solver:
  • 4 Answers
Go to the main screen and check your internet connection settings...
Posted on Jan 03, 2009
PS3 Not Detecting Ethernet Cable
If its not the cable and not the switch port rhat its plugged in to, about rhe only thing left would be a failedfailing ethernet port on the ps3 itself. When you look into the actual port, do the wires look good? Try plugging the ps3 directly into some other ethernet device to see if you get a link anywhere. The actual link pulse and whole process of the initial handshakes, etc for AutoNegotiating the speed and duplex matching settings sometimes doesn't work with some brands of equipment. by using other equipment connected directly to your ps3, you'll simply be testing that the problem doesn't exist with another nic or port brand. Try several devices, preferably all devices with gigabit capability to support the Auto Mdix functions so that you don't have to use a crossover cable. If you connect the ps3 directly to a pc with only a 10/100 mbps adapter, you will likely need a special crossover cable to get that connection's link light lit up. If your ethernet switch supports configuration settings (not likely though if its a basic home internet router), try forcing the speed and duplex settings of the switch port to see if anything helps.
Nov 03, 2013 | Video Game Consoles & Games
What connections are needed to hookup the ps3 to the internet?
You can either hook up your PS3 through hard wire using an ethernet cable plugged into your PS3 and your modem or wireless since the PS3 has a built in wi - fi adapter for the wireless network in range.
May 12, 2010 | Sony Playstation 3 (PS3) Console
A need help
you can set your playstation 3 online by two ways, 1- by a wired connection, and 2- Wireless,
1-Wired Connection: Plug an ethernet cable from your highspeed modem to the back ethernet input on your ps3 system, and follow on your ps3: Network Connection > Internet Connection Settings > Easy > Wired Connection. and follow steps
2- Wireless Connection: You must have a Router connecting ethernet cable from your intenet modem to the router, and follow on your ps3: Network Connection > Internet Connection Settings > Easy > Wireless Connection and follow steps,
hope this helped you on setting up your ps3 connection :)
Apr 13, 2010 | Sony Playstation 3 (PS3) Console
My Advent Roma 2000 says network adapter not connected. How do I connect it?
First, you need to have something to connect it to, such as a cable-modem, an ADSL-modem, or a router.
Second, you need a "straight-through" Ethernet cable, not a "cross-over" Ethernet cable.
It's an 8-wire cable -- do not use a 2-wire or 4-wire telephone-cable.
Plug one end of the cable into the 'LAN' port on the other device, and the other end into the network-port on your computer.
Apr 10, 2010 | Computers & Internet
Wireless switch on my pc is on but cant connect Work with ethernet cable plugged in.Are there any settings?
Things to try:
1. Plug in the ethernet cable then restart the laptop.
2. Right click on your local area connection and make sure its enabled
3. Make sure your wireless adapter is disabled.
4. Check if you need a static ip address on your work network. and if so have them assign you an ip address for your laptop.
5 Test your computers ethernet port on another wired network to make sure that it is good.
6. Get a usb to ethernet adapter for your laptop if your ethernet port is bad on your laptop.
Sep 11, 2009 | Intel Computers & Internet
I cant get onto the internet with my playstation 3 .
If u can get online Playstation Network to the point wer features like adding friends become availible then there shiould be no problem. If you cannot sign in to playstation network then there is a something wrong with your network aettings. If an arror code comes up type into google something like "What does error code *********** on the PS3 mean???". Be specific
Jan 14, 2009 | Sony Playstation 3 (PS3) Console
Cant go online with my ps3
If you are using a router you may be blocked my the routers firewall. Double check that your IP address and settings are right.
Jan 02, 2008 | Video Game Consoles & Games
PS3 internet problem
Hi, best way to connect the PS3 is to buy a router, wireless or wired router. and if you go for a wired one, connect the ethernet cable (RJ45) from the PS3 to the Router,
Other option is plug ethernet cable into PS3 & other end into the Network card which will be built into the base unit, otherwise you can buy a ethernet card which should cost you about £10.
but you will need the PC switch on, whenever you want to use the PS3, as well as you will have to configure the network setting to get it working,,
Have a good new year
John
Dec 29, 2007 | Sony Playstation 3 (PS3) Console
Connecting ps3 via t-mobile web n walk
now then or you hav to do is plug it to your pc go to internet connection t mobile properties then advanced allow to share to other connections then plug your cable to your pc from your ps3 you might have to turn your windows firewall off or just change the settings if you dont want 2 turn it off
Dec 09, 2007 | Sony Playstation 3 (PS3) Console
Ps3 wireless
It depends... If you use a router for the Internet then you don't need any cable, just turn on the router and then go to the PS3 and configure the PS3 to work with the router. If you have wired internet, then you will need an Ethernet cable, but since the PS3 comes with an Ethernet cable, you don't need to buy one. With the Ethernet cable, you have 2 options. If your modem has an Ethernet port, then just connect the PS3 to the modem directly. If the modem doesn't have an Ethernet port or direct connection won't work, then you can use Internet Connection Sharing to connect your PS3 to the Internet.
Jun 29, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
