Question about Miele Vacuums
HOW TO REMOVE HANDLE ON MIELE S7260 - Miele Vacuums
2 Suggested Answers
wentlanv
  • 710 Answers
SOURCE: How do i remove the cover to check the fanbelt on
Did you check the belts that go around the end of the brushes?
There is a service panel that remove with a coin. It is located at the rear, bottom of the vacuum.
The star shaped screws you mentioned are Torx screws. You can get a set of torx drivers at any hardware or home improvement store.
Hope this helps, if it does, please place a vote for me.
Good luck,
Handie Andie
Posted on Mar 27, 2011
Testimonial: "Thank you for your expert advice."
It is not sucking at all
So your machine sucks :>) Sorry I couldn't resist.
Remove the bag. Turn the machine over and remove the base plate. At one side of the brush towards the back, you will see the hole that all the fluff goes through, to the motor and then onwards and upwards to the bag. That is where your blockage will be. If you can get it all your can make a little hook from a wire hanger. You can also put the machine outside and run it without the bag. This creates a lot more force and will often dislodge blockages. Remove as much as you can first though.
Nov 22, 2015 | Miele S7260 Bagged Upright Vacuum
How do I replace the drive belt
Hi, it's Allie from Crucial Vacuum!
Changing your belt is crucial in keeping your unit running efficiently. It is recommended for belts to be replaced every 6 months.
To get access to your unit's belt, your floor base should have two plastic screws that will allow you to remove the roller brush casing. After removing the casing, you will be able to see your roller brush, now it's a good chance to, with a pair of scissors, cut any tangled hair strands or left over debris that is tangled in your roller brush. There are also four more screws that need to be removed to get access to the belt and the clutch assembly.
The roller brush clips in onto the floor base with one clip on each side, you can gently but easily unclip it. Remove the cover on top of the belt and the bearings with a screwdriver, remove the bearing end caps to reveal your unit's belt to be replaced.
You can purchase direct your replacement bags and filters from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=S7260
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Sep 23, 2014 | Miele Vacuums
Split suction hose
try e spares on the internet they have most parts
and to replace is very easy
Mar 20, 2014 | Miele S7260 Bagged Upright Vacuum
Miele Vacuum Cat and Dog Upright S7260 Loss of Suction
could be a couple things first make sure the hose is clear check real good the other is make sure your bag is good and tight and clean and make sure you have no holes or tears in the hose
Mar 07, 2014 | Miele Vacuums
Vacuum not sucking
Check for a block in the hose and the bag is in properly allowing the lid to latch.
Jan 09, 2014 | Miele Vacuums
How do you read the "full bag indicator" on a Meile S7260?
typically if your vacuum is loosing performance it is time to replace the bag depends on how fine of dust some really fine dust will clog the pores at a 1/4 full
Apr 14, 2013 | Miele CatAndDog700 Bagged Canister Vacuum
How do i remove the cover to check the fanbelt on my Miele s7260. The brush has stopped spinning and when i tried to check i found that it had unusual screws. They are not the flathead or phillips type but...
Good luck,
Handie Andie
Mar 27, 2011 | Miele S7210 Bagged Upright Vacuum
Vacuums Logo
1,056 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
