Alpha sy9-24 boiler has a fan fault - Heating & Cooling
2 Suggested Answers
burty681
  • 56 Answers
SOURCE: Boiler Alpha CB24. No hot water at taps unless cen...
its diverter or the flow switch
Posted on Jan 20, 2011
Alpha boiler cb24
Google Alpha boiler you should be able to down load a online manual with a ff chart in it . which should have codes in there for flashing lights .
Jul 29, 2017 | Water Heaters
I've got a Alpha 240 e combi boiler..... Everything seems to be wor,kin ok but it won't start the ignition sequence .
could be air presure switch which tells pcb that fan is working and would then bring inn ignition system then main gas valve.Would suggest getting gas engineer in.pommie engineer
May 26, 2012 | Water Heaters
Baxi duo tec e160 code
Fault Code E160 on a Duotec Boiler is a fan fault.
Mine has just gone for the 2nd time! Gas engineer is on his way......
Jan 31, 2012 | Heating & Cooling
Alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
Aug 21, 2009 | Water Heaters
Fault light flashing 1 flash per second
Prior to writing the above fault I had asked the owner to turn the boiler temp controller , for the heating side, down just a fraction . I was phoned this morning to tell me that the boiler had stayed on allnight with no fault light . After consulting with the plumber who fitted the system it appears that there might not be a room stat ,
Nov 30, 2008 | Bosch Water Heaters
I have an Alpha CB28 combination boiler and it is not working at all. The bottom neon indicator light is flashing every second and the helpline suggests it is a temperature sensor fault. I have had it...
try tapping the 3 relays on the pcb,"thats the circuit board under the front cover...
it sounds like a dodgy relay thats starts up the pressure fan in next to the flue....
maybe a dry solder joint,maybe a new relay needed....
its a common fault on this model..
Oct 15, 2008 | Heating & Cooling
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
