Question about Symantec WinFax Pro for PC
Win Fax Pro 10.03
I have a fax in my outbox that says it is being sent so I cannot delete it. I have been able to send other faxes even with the program indicating the fax in the outbox as being sent. How can I delete the fax?
  • mshawamerica Oct 21, 2008
    my recieve log shows a fax coming in with the lightning bolt. I cannot delete the incoming fax. It's as if it is frozen.
  • hamiltoncon Jan 29, 2009
    Occasionally I receive a fax that "gets stuck" in the receive log, sometimes with the lightning bolt sometime not. The only way I've found to get rid of it is to reboot the computer (not just WinFax), go to the receive log, click and drag the call to the wastebasket then delete it.
    I read on another site that Win Fax has issues with XP and discerning between fax and voice calls which may be a contributing factor.
  • 21 Answers
Click on the outbox to open it, right click the fax document and then left click on delete then click ok to confirm the delete is the usual process.
Posted on May 17, 2007
SOURCE:
How do we set Samsung pro express M4580FX to do auto fax sent status and confirmation after each fax is sent (rather than printing reports)
dear
the sent report can be disabled at FAX SETUP.press menu and scroll to enter fax setup scroll to display report enter here to enable or disable the report. the sent report only display for short time after sending the fax. also you can take a print of journalreport.
Thanks.
Mar 02, 2015 | Samsung Office Equipment & Supplies
How do you find fax log for sent faxes on Dell 962 All-in-One
Only faxes sent and received by Fax Console can be seen by Fax Console. View the Status of a Fax Using Fax Console or Fax Service Management
  1. Click Start All Programs (or Programs) Accessories Communications Fax.
  2. Click Fax Console or Fax Management Services.
  3. The following folders appear:
    • Incoming - faxes currently being received
    • Inbox - faxes that have been received
    • Outbox - faxes scheduled to be sent
    • Sent Items - faxes successfully sent
  4. Click the folder of your choice.
  5. Click the fax in the right pane for which you want to view the status, and then click Preferences or Properties.
  6. Click the General tab and view the Status line.
  7. Click Close when you are finished
Mar 05, 2011 | Dell 962 Photo All-In-One InkJet Printer
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after
each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 1.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Can not send or receive fax.
Is the phone line plugged into the "line" jack and not the " phone or Ext " Jack?
Jun 09, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Winfax sending issue,
What you describe appears to be a printer driver problem but cannot be sure , I'd suggest looking at : http://www.getfaxing.com/cgi-bin/ib315/ikonboard.cgi?act=ST;f=17;t=413
Sep 19, 2008 | Symantec Winfax Pro 10.03 (winfax10.03)...
How can i refresh my send logs automatically ?
You can't, if a fax failed, and you leave it in the log, its listed there as a failure. If you're manually resubmitting the fax, while its in the outbox being re-transmitting or waiting, you can delete the old entry that failed in the send log. http://www.getfaxing.com/forums
Sep 08, 2008 | Symantec WinFax Pro for PC
Fax problem
Pending faxes are faxes whose transmission has been delayed either deliberately or unintentionally. Normally, when a fax cannot be sent at the first attempt, the fax machine will redial the recipient's number. If you choose to delay sending a fax, the machine will send it at the time you select for transmission. During the delay period and at any point up to completion of the call, you can cancel the delayed transmission by deleting the fax from the Pending Faxes queue. To do this:
Press the Fax button on the operator panel and then press Options (once only). The Pending Faxes menu will be displayed.
Press Select. If a fax is pending, the printer will display Cancel Fax (the fax number you dialed appears below these words).
Press Select to delete the pending fax.
In response to the Are you sure? prompt, press 1 for Yes ( 2=No).
Press Options (once only). The Pending Faxes menu will now display None.
Feb 16, 2008 | Lexmark X4270 All-In-One InkJet Printer
Send fax using pc
Please perform the following steps to fax from PC.
Click windows-->Programs-->HP-->HP Solution Center
Clik on Send Fax and provide the number of the fax to be sent and proceed with the steps to resolve the issue.
Every application has the option of sending fax from the File Menu---> Print-->Select the Fax icon and click on Ok.
Jan 05, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Faxes sent from PC do not delete from print queue.
its in the fax preferences option...on the fax icon right click and go to properties..somwhere in the preferences should be an option to select automatically delete sen faxes..or something like that.
Aug 30, 2007 | Brother IntelliFAX 5750e Laser Fax
Symantec WinFax Pro for PC Logo
214 people viewed this question
Top Symantec Computers & Internet Experts
Peter Dragonetti
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
