Error f2 04 sharp ar 5015 - Office Equipment & Supplies
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
Posted on Jun 06, 2009
M2Tech1
  • 313 Answers
SOURCE: ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Posted on Jun 12, 2009
  • 990 Answers
SOURCE: Sharp AR-M205 - Error Code L6
Hello sir; "L6" display it means laser motor defect need to replace.
Posted on Aug 19, 2009
xptareq2000
  • 1447 Answers
SOURCE: Sharp AR-M208N copier with error code U2-40. What
reset u2
press c -interrupt-#-interrupt
press 16
press start
machine off
again machine on
remove this signal.
Posted on Jan 20, 2010
How to open the fuser unit
the green levers on both sides spread the roller pressure, bit if you need to take it apart, it has to come out of the machine
Aug 16, 2014 | Sharp AR202DR Copier Drum Unit AR-201 202...
Tip
How to clear code H4 in All sharp copiers.
All the sharp copiers reset by code 14.
type of codes entry:# interrupt C interrupt.led goes off,press 14 and start.
2`nd type:(# * c * ) 14 start ( M 207 model)
3`rd type: C interrupt 0 interrupt (almost for analog copiers)and AR-161 .AR - 5015
on May 30, 2010 | Sharp AR-5320 Black and White Copier
HOW TO CONNECT PRINTER TO COMPUTER
This can be connected via a USB cable in standard configuration. If you want to attach to a network you will require a network interface option to be fitted.
Jan 27, 2014 | Sharp Copier Developer AR-201 202...
Error code h-3 on my sharp ar 5015
Basicly, you have a problem with the fuser unit.
Aug 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
My Sharp AR 5015 has 2/U error Please help me to solve it.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} CRUM chip communication error
Aug 14, 2010 | Sharp AR-5316 Advanced Digital Imager...
I am using Sharp AR-5316E copier (It makes noise)
Yes, Toner waste sump over filled; 100%!!! To confirm it, remove Toner cart. & make copy; I found same problem in Toshiba eStudio161, which is Sharp AR163, 5015, 5020 & 5316(all are same)
Jan 04, 2010 | Sharp AR-5316 Advanced Digital Imager...
Error code "L" & "1"
L1 indicates a scanner feed problem. Make sure the scanner isn't locked in the shipping position. It is underneath the scanner where the paper exits the machine. Look for a plastic dial and turn it one way or the other.
Jul 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
126 people viewed this question
k24674
jasbo
jasbo
