Question about EdgeStar Heating & Cooling
I having a problem with the heater on edgestar 14000hs wont heat up
Edgestar 14000hs fan blows but will not heat
2 Suggested Answers
SOURCE: edgestar 12,000 portale air conditioner and heater
There are 3 possibilities beginning with the most likely problem
1) If your heater heats up for a few minutes and then quits, chances are there is a blockage in the air flow, check for dust and grime blocking the air intake coarse filter , airgun blow to clear accumulated dust and otherwise clean the coarse filter .
2) If the heater fan blows but there is no warm air, the heating element needs renewal ( this happens very rarely)
3)If the fan stalls and the heater heats up and the thermostat kicks in, then this will be not be a DIY job. This is least likely as you said the air cooler works.
Posted on May 06, 2008
Why wont my heater system on my 1999 dodge pickup blow heat out of the vents?
Fan not working or you would feel cool air if heater door was working. Can you hear the fan?
Feb 24, 2015 | Dodge Cars & Trucks
Ac fan wont blow
I would disconnect the fan connector and use contact cleaner to clean the connection. Usually corrosion. Also fan might be going bad (Common Problem).
Mar 27, 2013 | 2000 Saturn L-Series
How do I replace the exhaust fan on edgestart portable airconditioner AP12000S
I have an Edgestar AP 420HS and I need to replace the horizontal hamster wheel type exhaust fan that is rattling badly. I removed all screws and still can not remove the back of the unit. Two screws required a 7 inch long hex screw driver. Please post any information that may be helpful.
Aug 13, 2012 | EdgeStar Portable Air Conditioner Heater
2000 Jeep Grand Cherokee, heater wont blow heat!
Check the thermastat or your cooling fan to make sure all is working good. If your engine cant warm up, you will not produce any heat inside the car
Feb 04, 2010 | 2000 Jeep Grand Cherokee
How far from floor should exhaust hose hole be made edgestar 12000
makes no difference, as long as the ducting is not kinked.
keep in mind heat rises
so obviously if you could dump the heat elsewhere, away from the area you are cooling, then it would not creep back up through the floor. If your flooring is well insulated it will not matter.
Oct 10, 2009 | EdgeStar Portable Air Conditioner Heater
Heater keeps cutting off as if it reached the set temp.
sounds like its in defrost mode and the electric aux heat is not working
Feb 20, 2009 | EdgeStar Portable Air Conditioner Heater
Edgestar 12,000 portale air conditioner and heater
Apr 25, 2008 | EdgeStar Portable Air Conditioner Heater
Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
Dec 24, 2007 | EdgeStar Portable Air Conditioner Heater
Edgestar AP550Z won't heat, goes into some sort of alert mode
http://edgestar.com/ownersmanuals/AP550Z_wire-fix.pdf
This could apply to at least one of your units. Apparently these models have had some trouble with the compressor capacitor wires coming loose. If they're barely touching they could cause the compressor to run intermittently and possibly overheat. The compressor runs in heating and cooling mode.
Dec 04, 2007 | EdgeStar Portable Air Conditioner Heater
Heating
http://www.edgestar.com/ownmanuals.htm
Here is the URL for the Edgestar owner manuals. You can select your unit on the page. You'll need Adobe Reader to view the manual.
Nov 28, 2007 | EdgeStar Portable Air Conditioner Heater
Heating & Cooling Logo
29 people viewed this question
Top EdgeStar Heating & Cooling Experts
John Tripp
John Tripp
Gene Tuck
gbob59
Are you an EdgeStar Heating and Cooling Expert? Answer questions, earn points and help others
