Question about Lands Phones
Panasonic kx-tga520m display screen blank - Lands Phones
4 Suggested Answers
SOURCE: my panasonic kx-tga520m cordless handset does not
Because your phone was low on battery, you will not see this feature. Once you charge your phone fully, you will start receive phone calls and you will see this feature activating again.
Posted on Jan 20, 2010
  • 1340 Answers
SOURCE: My Panasonic KX-TGA520M expansion handset
Yes,it's the battery.Ours does the same thing.Let it charge all day,5 minute phone call,call gets cut off.Being a 5.8 GHz,you may be able to find battery(ies) for it.Mine is older and batteries are discontinued(2.8GHz).Make sure it is rated the same,3.6V,600mAh,or whatever yours is,that is just a sample.Also,it should still be NiMH.Nickel-metal hydride.The packaging wil list the brand names it is for but the numbers definitely need to match 100% or it could cause more serious problems such as battery leaking from wrong rating.The newer technology is DECT 6.0 which was adopted from Europe technology.It is supposed to have better range away from the base,clearer sound,maybe a couple other minor things but I have my doubts as seen on trouble forums and sites such as this one.For one,they work at 1.9 GHz,which will give better range anyway because of the lower frequency used.1.9 GHz is about equivelant to trying to bend a 1/4" steel pipe around a corner while 5.8GHz is like trying to bend a 3/4" piece of pipe around a corner.The 1.9 signal has more "bend" allowed in literal terms.That's the best way I can explain it.Anyhow,I am waiting for a really good sale on phones for holidays to give it a try.Just unwilling to pay full price on a similar technology that was typical of all phones 10 years ago.If you do find batteries,I was going to say maybe buy 2 for each handset,but batteries do not do well sitting around for 5 years.They COULD leak and be worthless by then,unsure but never know.There are many factors to storing them so that they will last.They will be unavailable by then so we can't win for losing.Something like that.Good luck,Greg Also,if you ever get battery acid on you or anywhere you don't want,put baking soda on it ASAP.Baking soda neutralizes acid.Cover in about 1/4" thick layer.
Posted on Nov 17, 2010
  • 17 Answers
SOURCE: Panasonic cordless telephone KX-TGA101CS troubleshhot
you can contact the service provider..
Posted on Dec 15, 2011
Caller ID setup on cordless phone panasonic kx-tga520m
I would call your phone service provider and have them reset your caller id service.
Jul 21, 2014 | Panasonic KX-TGA520M Cordless Expansion...
No display panasonic cordless phone
The display on that particular phone may have to be replaced.
Dec 28, 2013 | Lands Phones
System is busy please try again
please remove battery and wait a while and then insert again. reinitialize and try. hope this helps.
regards
Mar 12, 2011 | Panasonic KX-TGA520M Cordless Expansion...
Display screen has gone blank
You would need to change the screen. Go to a phone repair shop to assist you in changing the screen. It will cost you a little.
Best regards
Jun 06, 2010 | Panasonic GigaRange KX-TG5432 Cordless...
Screen does not show anything
There seems to be a problem with your display screen or the connection might be loose. You phone care be repaired from any Panasonic or electronic shop as the problem is not that big. The screen display might need to be changed or the repair person will fix the internal connections because of which also the display might not be there.
May 28, 2010 | Panasonic KX-TGA520M Cordless Expansion...
Can you just tell me how to change the phone from two rings to four rings, I cannot find my manual
1) press the button
2) use the up or down arrow on the button and scroll to "initial setting"
3) press "select" using the button above the button
4) "set answering" should be displayed, if not use the up or down arrows on the button to select
5) "number of rings" should be displayed, if not use the up or down arrows on the button to select
6) use the up or down arrows on the button to select the desired number of rings
7) press "save" using the button above the button
Feb 03, 2010 | Panasonic KX-TGA520M Cordless Expansion...
My panasonic kx-tga520m cordless handset does not display caller id anymore. the second handset does display this feature. What should I do?
Jan 18, 2010 | Panasonic KX-TGA520M Cordless Expansion...
Display for Caller Id incorrect
After calling Panasonic US at 1800-211-PANA (7262) regarding my kx-tga5420 and kx-tg5230 system's handsets.
On the handset, verify that Caller ID Edit is turned on first.
Menu-->Initial settings
Go to Caller ID edit
Select Auto edit ON
Save
Exit the menu
On the handset main display
Hit the button that relates to CID
Scroll down until you find the desired 1-xxx-xxx-xxxx number that you want to
be displayed as xxx-xxx-xxxx
Hit the edit key until you see the number displayed as xxx-xxx-xxxx
Save
(Note: You have to initial a call once you have saved the change.)
Now hit the TALK button to dial this number
Now when you receive calls from this number it wll show as xxx-xxx-xxxx instead of 1-xxx-xxx-xxxx.
Jul 06, 2008 | Panasonic KX-TGA520M Cordless Expansion...
Lands Phones Logo
47 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
