Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
My vacuum kenmore canister smells
My vacuum when used on the carpet makes a burnt smell. And when I use on the floor no smell. What could it be? I've cleaned all the rollers and changed filters and bags. THanks in advance.
  • 1 more comment
  • Anonymous Nov 08, 2007
    My vacuum is smelling like something is burning. I have just cleaned the filter out well. I was told at the store yesterday it could be a belt. Can you help?
    Thanks.
    Margie
  • danyiel Feb 09, 2008
    I understand the vacuum needs a belt replaced, I'm trying to figure out how to dis-assemble to get to the beater bar and belt for replacement. Lost my manual, where to find diagram/schematic for roller head. Online offers a lot of places to call or go to or have service come out. It's just a little thing that can be done at home. Where would one go online to get that info? Kenmore canister 51612001
  • sekhemet3 Dec 25, 2008
    be bought a new belt, It deffinatly seems to be the belt. It runs without the belt fine. Once you add the belt it smells aweful and gets really hot. It has a new belt on there, so we wonder why the belt is loose and giving us these problems....
  • 247 Answers
My guess would be a slightly loose belt - tight enough to spin the roller on a hard floor, but loose enough to slip (then get hot and stink) when the roller is having to work against the pile of a carpet. Worth buying and fitting a new belt without pausing to investigate further, simply because they're so cheap and you'll have to replace it sooner or later anyway. A.
Posted on May 16, 2007
Burnt rubber smell when vacuuming
This could be a few things:
A. If your model has a floor selector switch (Bare floor/tools - Carpet) your clutch could be worn. (there is a rubber clutch pad between your cam and roller shell) - Fix would be to replace the clutch pad and belt.
B. If you don't have one of the above models, your belt could be stretched. The belt slipping could cause a rubber burning smell. Fix - Change belt.
C. Have you got any new carpet you are vacuuming or have you moved? Some of the newer style frieze carpets can cause burning rubber smell. The fibers of the carpet are longer and cause the brush to slow down causing the belt to burn. (Imagine brushing long hair with a thick brush, the hair easily gets tangled in the brush, same effect with this carpet.) Some of the newer rugs can do this as well. Some newer carpets with the thicker felt backing and/or the "pet padding" under the carpet can too. it doesn't allow enough air to flow through causing the cleaner head to seal itself to the carpet causing a burning smell. The fix is Move to another home, replace your carpets or replace your vacuum. The vacuum is the cheaper option but be cautious as most vacuums now do this with these carpets. We have had really good response from customers using the Simplicity Tandem Air models, (Synchrony and Synergy models.)
Hope this helps, if you need to talk further feel free to contact me.
Tim
TheVacCenter.com
Mar 13, 2013 | Simplicity Vacuums
Odor when vacuuming
at sears there is a bag fresh lemon scent tab that you can load inside your vacuum,
also at vacuum shops there is a product called "Featherlite Carpet and Vacuum Freshener" - it works very well and a little bit goes a very long ways.
I will comment that on the back of the package it claims "for extra freshness use each time you vacuum" This stuff is so strong that I would not advise using it like that. just put about a half cup of the particles on the floor and **** them up with your hose.
I bet your smell will be drastically improved.
Dec 22, 2009 | Kenmore 23812 Progressive PowerMate Bagged...
Hi, I have a canister Kenmore vacuum with power head. Everytime I use it, it smells sour. Its strong and like FEET with bad odor. My old Kenmore did the same thing but I used it anyway...because the power...
Never heard of this odor but if you have had it in both vacs it might have something to do with a disintegrating rubber backing on a carpet.
Arm and Hammer makes a baking soda based vac powder that will help eliminate some odors.
Do several things , get the powder and pour a tablespoon of it or baking soda into a fresh bag. Keep your filters fresh. If you use washable filters be certain they are thoroughly dry before reinstalling. And use a Mutli ply filter bag.. and NEVER pick up anything wet or vacuum a damp carpet
Sep 10, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore vac won't shut off, blowing heavy air from vent
For the stack of problems you have, it sounds like it be best for you to ditch it and get a new vacuum. The heavy problem sounds like a motor issue. The burning smell is most likely from the belt being loose on the power head.
Economically, you should just get a new one instead of replacing the whole system guts
Aug 14, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Canister motor not on - power to power mate is on
if its a long plastic tube with snaps on it that is where the fuse is.open it up and you will find the fuse
Apr 28, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Rainbow Vacuum smells like something is burning.
Your belt is worn and that is why there is a burnt rubber smell. You need to change your belt. You can find a replacement belt and instructions here:
Rainbow Replacement Belts
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Removing kenmore vacuum Canister motor cover model 116-27312790
What you need to do is take it apart and look for any carpet peices dug up in there preventing the motor to spin. Also go look for another filter for it and if you google it you can probably get instructions or if you still have the book.
Jan 22, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore 23613
if it smells like burnt plastic it is something wrong with the motor part, but if it is a wet dog,burnt hair gross kinda smell it cool change the bag and buy deoderizer tablet to put under bag kinda like a airfreshener. if it dont work like it used too not picken up like should something wrong
hope that helps,
Dec 29, 2007 | Kenmore 22085 Bagged Canister Vacuum
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
463 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
