Question about Bionaire Dryers
My tower fan won't stop squeaking and I am not sure how to fix it.
No matter the speed, the fan will squeak very annoyingly. I can't seem to open up the fan very easily either.
4 Suggested Answers
  • 40 Answers
SOURCE: Squeak in aloha breeze tower fan model 05538
If the model is equipped with a fan, and the noise occurs even when not oscillating it must be a fan/blower motor. If it is a squeak. A squeal could be an electical component going bad which is always bad. I would definitely take some bottom drawer tools , ie. screwdrivers and WD-40 and oil that squeaking motor. Being a fan it goes through alot of air pollutants. That tends to build up on the shaft and can work its way into the bearing seal. Good luck.
Posted on Jun 28, 2009
  • 130 Answers
SOURCE: how to stop squeaking noise
usually these units have very inexpensive sleeve bearings that require little maintenance. Have you tried squirting a little WD-40 on the bearings?
Posted on May 16, 2010
miket756
  • 2702 Answers
SOURCE: my fan squeaks loudly at
try a splosh of wd40 on it first that wont hurt the motor or the switches
Posted on Aug 11, 2010
Reebok 8100 es wont go any faster then .4mph
Please adjust the speed sensor, see the diagram, test it for open or faulty, clean it, and tight the plug very well.
However you must RUN the software calibration for easy diagnose, and troubleshooting and fix it. Go under HOOD motor, and follow the steps .
God bless you
Dec 03, 2012 | Exercise & Fitness
Rear Hatch Window won't stop rattling
apply some strong tape to the stricker adding a little at a time until all the excess play is gone
Jan 01, 2018 | 1985 Chevrolet S-10 Blazer
Fan noise ecoquest 2.1
sounds like the bearings are going bad on the motor check and make sure the fan blades aren't rubbing anything at higher speeds sometime's they will flex
Jul 04, 2012 | Ecoquest Fresh Air Air Purifier
Fridge door squeaks, freezer door bumps
Slacken the three screws, align the door and tighten the screws up again. Try not to lean on the door when it's open.
Apr 21, 2012 | Refrigerators
I just bought the Honeywell Quietset 8-Speed tower fan (black and silver on top). I installed it correctly but the fan is extremely loud and squeaky and can hear the inside pole that rotates the fan, even...
STOP! Before you take anything apart, turn fan upside down and find the large plastic "screw"(cord passes through it)that secures the fan to the pedestal. Is same color as unit. Loosen it and see if squeaking stops. Worked for me!
Mine was driving me nuts and I was prepared to return it to store.
Aug 30, 2011 | Honeywell Comfort Control Tower Fan -...
There are two small fans on in the ceiling. A small round vent on the driver's side in the back, and one in the front by the driver. It is loud and squeaking and won't turn off. What are these...
{: ) They are called the inside air temperature sensors. The HVAC module on your vehicle monitors the feedback from these sensors and helps regulate the climate comfort inside the vehicle according to your preferred settings. Yes it has this tiny fan inside, and if the noise is loud and annoying to you, the only fix is to replace it.
May 30, 2011 | 2003 GMC Yukon XL
BMW 320d e90 fan noise from AC/climate control unit. Very annoying. It comes and goes. Please note the AC/climate control still works and the noise seems to be the only problem. It only started a couple of...
Check if happening at specific settings on the fan. Fans use resisters to slow down their speed. Typically the lowest setting will mess up before the highest. If coming a going means you change the speed and it goes away.
If it doesn't matter what speed, there is probably something in your vents. Do you park outside? Mice love getting into warm cars on cold nights, and build nests... a nice comfy place can be in vents...
Or have very small kids... mine used to love putting things in the vents and have them disappear! Could be cherios
Nov 07, 2017 | BMW 3 Series Cars & Trucks
Dryers Logo
116 people viewed this question
Top Bionaire Dryers Experts
Jerry Greenberg
Jerry Greenberg
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
