Question about Stanley 30-305 HI VIS MEASURING TAPE
How to fix a stanley power-lock 25 ft measuring tape
It is a 33-45
My brother wants to know how to rewind the tape once it has been completely unwound. Does anyone know?
Take the four corner screws out and the last center (short screw out). Split the shells in two pieces. Seperate the yellow or measureing tape from the black spindle tape. The spindle tape holds or attaches the measurement tap to the spindle. I have only seen a plastic spindle and this tutorial only applies to the plastic one. Take the spindle out and set the half casings on their backs, so you can see the cavity of the shells. The black spindle tape will be preformed to only wrap one way. Go ahead and attach the yello measuring tape to the black spindle tape. Pay close attention which side of the yellow tape is facing up or in our intended direction which is towards the center of the spindle. This way when you pull the tape out it is facing up for the person can see the measure marks. Wrap the tape tightly. If the tabs are broke and there's no way to secure the Yellow to the black, use two strips of Duct Tape and adhere the sections together. Do not use too much tape, since the clearance inside the spindle is tight. Once you wrap the tape inside, put a temporary piece of tape to secure the yellow and keep it from unraveling again. Next take a 1" wood screw and a battery powered drill and insert the screw into the center of the plastic spindle. Slowly tap the screw until it catches, do not drill the screw all the way in, only enough to catch in the plastic. Once the screw is partly into the plastic place the spindle into one of the half shells. The reason for the drill and screw is to return the tension back to the internal spring. Whichever side you placed the screw into you need to be sure to apply a clockwise turn. Keep the hex head of the drill so to not release the tension. At the same time place the spindle in the half shell and lock its square center piece into the shell. Now you can remove the screw from the center, then remove the tape holding the yellow meauring tape down, Still holding the measuring tape so it wont unravel, begin placing the last half shell on. Obviously you need to line everything up so the tape slides freely through its opening. Align the tape slide stop, which rests between the two shell halves. Replace the screws and remember the short one goes in the middle and holds down the belt clip.
Frank
Posted on Oct 17, 2009
  • 36 Answers
Just take it in to a building center and trade it for a new one, they never work right later, and they are lifetime guaranteed, i believe most menards building supplys trade them at the customer service desk
Posted on Feb 13, 2009
Stanley tape measure rewind
Spring has stretched now Best get a new one.
Jan 19, 2018 | Measuring Tools & Sensors
I can not extend the tape measuer more then 4-1/2 ft without the tape twisting. The tape measuer was only a few months old when it started twisting on me. It is very frustrating when you are trying to get...
If your talking about the tape twisting side ways just feed the tape out and slide it on the surface and when the catch goes over the end turn the body so that the catch turns down and pull it in to place.Put a strain on the tape blade and turn the tape body back up the way it needs to be.I like the smaller Stanly tapes but when it comes to a 25 foot tape, a Luftin is lighter and easier to use.They have a Stanly tape filler on the inside. They make an inch wide case .The Max is just to bulky and the Luftin is lighter.This is an ebay price.Thank You for choosing FixYa.com.
Jun 04, 2011 | Stanley 25' Fat Max Tape Measure 33725
I have a Stanley Power Lock 30' Tape Measure with 2' 9" of tape that I cannot get back into the housing, Is there an easy solution to this problem? Advise and thanks,
you can try to pull the tape all the way out and then with a rag lightly oiled let the tape rewind back into the housing if that does not work then you probably need to purchase a new tape. for whatever reasona the spring inside has gotten weak. i use a tape daily and have had this same problem when a tape gets old or abused
Feb 11, 2011 | Stanley 30-305 HI VIS MEASURING TAPE
How to replace the tape on a stanley 25" tape measure
Did it break and go flying up inside there? Take it back where you bought it, tell them you want a new one, they will replace it, all Stanley tools are warranted, the dealer may not want to do it, but he has to. You will never get it right by replacing the blade. I take that back, you might get it right.
Mar 04, 2010 | Stanley Leverlock Tape Measure, 10'
I have a Stanley Powerlock 25 ft. tape that broken at the 6 ft, mark where do i do to get if fix
those are garuanteed for life,as long as it was product defect.I take mine to local hardware store for replacement.Been 5 yrs. since I bought one.
Feb 10, 2010 | Measuring Tools & Sensors
I have a Stanley 12 ft. Powerlock tape model # 33-212. The plastic thumb locking trigger just broke. Can I purchase a new one and if so where?
No. You'll have to replace the tape measure, or find another similar model to rob the part from...See here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 21, 2009 | Stanley Tools/Goldblatt Tool No.30 - 506...
Adress needed
United States
Canada
Stanley Tools
1000 Stanley Drive
Concord, NC 28027
Attn: Quality Assurance
Stanley Canada
1170 Invicta Drive
Oakville, Ontario L6H 6G1
Feb 23, 2009 | Farberware Stanley Power Return Tape...
Need info on teturning tapes under warrenty
stanley tapes are life time warranty take it back where you bought it they should replace it.
How to basically operate my stanley fatmax, TLM100. The directions that came with it were for another Stanley product. Thanks,Ralph
Press the red button - (distance) you will see a red dot on the wall you are measuring - then you will hear a beep - release the button and read the display - the measurement should be displayed and accurate within a quarter inch.
Nov 16, 2008 | Stanley 100 ft. Tape Measure, FatMax
Stanley 30-305 HI VIS MEASURING TAPE  Logo
8,568 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Lawrence Oravetz
Vernon Taylor
Steve
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
