Curtis-Mathis CM27101S TV Logo
Posted on Jan 03, 2009
Program channels on curtis mathes tronics tv
How do i program my channels on curtis mathes tronics tv. it only goes up to channel 47
  • Anonymous Mar 20, 2009
    How do i program my channels on curtis mathes tronics tv. it only goes up to channel 27 then jumps to cannel 74? Thanks.
3 Related Answers
Anonymous
  • Posted on Mar 31, 2008
SOURCE: sanyo ds25830
There is a button under the bottom edge of the screen (with the controls) that has the options "Normal" and "CATV" - press this and it should solve your problem.
Tracey
Anonymous
  • 133 Answers
  • Posted on Jul 06, 2008
SOURCE: Curtis Mathes TV Remote Control Codes for Programming the remote to the TV
I own a One-for-All universal remote, and my booklet says the setup code for a Curtis Mathes TV (without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee these numbers will work with your remote, but it is worth a try.
Chi Chu
  • 8457 Answers
  • Posted on May 15, 2010
SOURCE: does my curtis mathes tronics tv model CM19011
No,all CRT tube tvs don't have digital tuner inside.They're analog tvs.Must buy the converter box,and hook it up to get the free DTV airwave signal.Trust me,i help an elderly person hook up this exact this tv model with a converter box.Try buy the RCA model converter box,it matches with this tv model very well.
I have an old school Curtis mathes TV for my son Xbox 360 can not get right channel no code works any suggestion
The XBOX360 does not connect via any RF channels (TV aerial). It connects through either the analogue video & audio inputs e.g. SCART or PHONO connectors, or via HDMI (which will not be supported on your old TV). If you have connected via the SCART or PHONO type then you can select 'AV' or 'EXT' via the remote to get input from the SCART/PHONO.
Curtis mathes tv cannot change aux back to normal channel like three. how do you get to get dvd from aux to normal channel.
Just contact the folks at the link below:
http://www.curtis-mathes.com
They are great a helping folks with problems with their Curtis Mathes televisions and stereos; and they do it for free :)
Does my Curtis Mathes Tronics model 19001 have a digital tuner?
No,all small tvs CRT tubes analoge tvs design under 35" none of the tvs have a digital tuner inside of it tv Tuner signal board.Must get a signal through a Digital Converter box to recieve a free on AIR broadcating channels from a Digital broadcasting signal.Tvs that are analoge CRT tubes design that have a Digital Tuner design inside of it are only some DLP tvs analoge CRT tube design 40" and above have it only.
1helpful
While moving my parent's Curtis Mathes Cm19001 TV produced in 1999, I touched the channel button which took the TV off of channel 3. We've tried to use the channel buttons to return to channel 3,...
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try Remotes.com to buy a tv original remote.Return the universal remote.
2helpful
Philips universal remote needs code for Curtis Mathis Tronics TV
Try these
Curtis Mathes
0047 0466
0016 0054
0060 0093
0145 0030
0154 0451
0166
Please rate my help++++Thanks for using FIXYA
I have a curtis mathes/tronics tv Made in May/2001 Serial no#CM19022S I am trying to hook up a digital conventer box to it and I am having troubles. I also need a users manual for this model and year, pls...
No need for the tv manual.Just follow the basic hook up instructions in the booklet came in with the Converter box.Very easy use channel 3.Use the codes for Curtis-Mathis tv in the booklet for the remote.I hook this Exact model of tv is take 20 mins.
2helpful
TRYING TO FIND A CODE FOR MY CUTIS MATHIS TRONICS T.V. ON MY ONE
here are the codes.
Curtis Mathes 0047, 0054, 0154, 0451, 0093,
0060, 0702, 0030, 0145, 0166,
1147, 1347
You can also get the setup info here
http://www.solidsignal.com/manuals/URC-3021%20Remote.pdf
Remote programming codes
Hey Kashaclysm, try this: www.urcsupport.com
Have your remote handy, have your TV model number handy.
27helpful
4answers
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Thomas Perkins
Thomas Perkins
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
