Question about Iomega Jaz 1GB (10771) Internal JAZ Drive
Formatting a disk
Disk in but wont load new project... recorded one track then lost project. this is a continual problem. sometimes a get thru one song , sometimes one track.sits at (propject not loaded)
    Genius:
  • 2,985 Answers
Iomega drives had a short life and then were overtaken by other technology. They were/are very fragile and had a high fail rate. Time to move on I guess - burn a disk or two.
Posted on May 17, 2007
I have a technics SL-CH505 compact disc but it will not play burnt CD;s any suggestions my other technics SL PG 400A plays them noproblem
The Optical Pickup(laser) may be weak. It takes much more power to record than play, which I guess it works.
Oct 13, 2014 | Technics Audio Players & Recorders
Samsung DVD-VR330 unit will not accept a brand new blank DVD-RW disc---machine says 'load' for 20 seconds, before saying 'open', which it does.
The DVD-RW will work at random, some brands will wok better than others. Memprex, Sony, Maxell are 3 I can use sometimes. Once the disk is accepted it must be formatted. Click that and if accepted, first do a record for say 2 minutes to see if ti works.
If it works don't take it out until you're ready to finalize it.
That's mostly so the disk will be readable in other players, should it not want to go back in, you probably lost the record.
Don't write on the back, use a card and keep it in the cover.
Sometimes I can use those disk's in PC for data.
regards
Jan 03, 2013 | Samsung DVD-VR330 VCR and DVD Recorder
My recording studio is stuck on the project load screen
Your VS-2000 is showing symptoms of fragmentation--resulting in the unit freezing or failing to completely load. The only possible solution is formatting the hard drive. Formatting erases all data on the drive.
Note: If you have any files that you need to keep, you may contact our Roland Customer Support department (323-890-3740) to arrange a "Data Recovery" service. Our service technicians can attempt to recover any data that is in your hard drive. Customer Support is available M-F 8:30am-5:00pm Pacific time.
CAUTION!!! Formatting the hard drive erases ALL recordings and data on the drive. This includes any installed plug-ins as well. Be sure to back up all of your project data (recordings) and plug-ins to CD/DVD(s) before formatting the drive.
Unlocking the System:
1. With the VS-2000 powered off, press and hold the TRACK/STATUS button for track 4 and the FX 2 button.
2. With both buttons pressed, turn on the VS-2000's power. Continue holding the two buttons until the display has loaded completely. This can take several minutes.
3. Once the system has loaded completely, release the buttons.
Formatting the Hard Drive:
Note: The format steps below pertain to using the VS-2400's on-board LCD screen. If you're using an external VGA (video monitor), press and hold HOME and press F6 to switch to the on-board LCD.
1. Press SHIFT AND F1/PROJECT.
2. Use the CURSOR buttons to Select "IDE:0".
3. Press PAGE until "FmtDrv" is displayed above F2.
4. Press F2.
5. CURSOR to "Physical Format".
6. Turn the TIME/VALUE dial until "ON" is selected.
7. CURSOR to "Surface Scan".
8. Turn the TIME/VALUE dial until "On" is selected.
9. Press F5 (OK).
10. Press ENTER/YES twice.
Oct 13, 2011 | Roland Vs-2000CD Digital Studio...
We have a Toshiba D-VR40SF DVD/VCR combo. It will record happily on a Sony x1/x2 DVD providing it is a disc we have already formatted and recorded on. But with new discs from the same pack, (or new discs...
Since it is doing this with both old disks and new disks, it is not discriminating and we cannot say it is a media incompatibility issue. I just think that the Electronics may be fubar. Wait, I think it has lost the ability to format the disk. That is what your old new disks and new disks have in common - they are not formatted!
Sep 20, 2017 | Computers & Internet
Cannot use the floppy disk of my CVP 65 as it appears the memory is full. It plays new discs, but won't record.
This sounds like it MIGHT be a floppy drive problem rather than a full memory... REMEMBER to ONLY try recording a file no bigger than what the floppy will hold which is 720Kb.
NOTE: The disks used in this are not the COMMON 3.5 inch floppies, but the older 2DD 720K floppies. They have only one hole on corners where the new 1.44 Mb ones have two holes.
To USE the 1.44 Mb flopies do this: Use an opaque tape to cover the hole that does NOT have the write protect slider. THEN most omportantly DEGAUSS the disk with a degausser. THEN Reformat the disk in the CVP 65.
The pre-formatted 1.44 disk when formated at the 720Kb used by the CVP 65 will have ARTIFACTS between tracks since the higher density also have half the track spacing and the formatting doesn't always clean enough width leaving artifacts between the tracks when formatted as 720Kb These ARTIFACTS can cause trouble.
The 720Kb disks are ESSENTIALLY unavailable anymore.
Jan 15, 2010 | Music
Err format while recording - 1 hour lost!
I have almost the exact same problem.
I did not interrupt my recording. I stopped recording, turned off the recorder, unplugged all the mics, turned on the recorder, listened to the first 10 seconds of the recorded track, turned off the recorder, plugged it into my mac, turned it on in USB mode, attempted to transfer the track file, and the track size is "zero kb." I ejected the recorder, turned it off and back on, and now the track says "err format" and skips to the next track.
This seems like a unique problem, as any "data recovery" software will search for deleted files instead of corrupted files. And even if the file is corrupted I have software that can read the raw wav data. However, the filesize is incorrect and obviously doesn't contain any wav data. Shouldn't it be the actual file size? How can I fix this???
Sep 13, 2009 | Marantz PMD660
DP02 when mastering it says trk too short???????
CDs are formatted like any other format of digital audio.  One of the restrictions of a CD's formatting is a track can be no shorter than 4 seconds.  Usually this happens when there are tracks that were created as part of your project and were not recorded on.  When you try to burn a CD, if one track is shorter than four seconds it will give you that message every time. This is because the standard gap between songs is usually three seconds.  The CD burner's format requires it to check how many tracks there are (another limitation of the CD format is you can only put 99 tracks on a CD) so the burner reads every bit (literally bit) of audio for the gap between tracks.  You must determine the length of every bit of audio on your program and make sure each track is longer than three seconds.    I have been mixing and mastering records on CD for ten years and I still get this problem.  It happens to the best of us.  Don't be frustrated.  Remember a machine will only try to do what you tell it to do.  It wont always tell you what you are doing wrong. It will only do what you tell it to do, or not, if it is impossible.   Go through every track in your project and examine how long each track is.  Read your error message carefully. My burner will say "track 5 is too short". Check and double check. Make sure no track is shorter than four seconds. When you are confident you have corrected the problem. (delete all empty tracks) Then burn baby burn!
Jan 10, 2009 | Tascam DP01 All-In-One Recording Package...
Disk problem
There is a website out there dedicated to just Cyberhome equipment. if you do not see anything pertaining to your system, register as its free, and leave a post.. I hear they get alot of assistance there. Good Luck Please do not forget to rate this thread.
Dec 10, 2006 | Cyberhome DVR 1600 DVD Recorder
Iomega Jaz 1GB (10771) Internal JAZ Drive Logo
208 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Marvin
Marvin
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
