Question about GE Microwave Ovens
Need to remove and replace round disk on ceiling of microwave
3 Suggested Answers
vitg55
  • 78 Answers
SOURCE: GE Spacemaker appears to be sparking inside/top
1.Needs to remove that disk and clean the grease under it.
2. With sand paper clean dark burn spots.
3. Apply touch paint on open metal spots.
4.Put everything back.
Posted on Dec 01, 2008
breddi2
  • 126 Answers
SOURCE: plastic melted inside oven, dripping from ceiling Kenmore 721
The round peice in top of unit is a cover for the stirrer wich moves waves around for even cooking. The reason for it melting is almost certainly there is not enough paint in cavity and waves are shorting out to metal.CALL the manufacturer and depending on age of unit they may replace it free
Posted on Apr 22, 2009
Why did it catch on fire?
Any flaws in the painted surface on the inside of the unit will cause a spark and that generates heat. Examine the surfacecor any exposed metal. You have to use special paint to resurface the inside.
Nov 15, 2015 | Microwave Ovens
The plastic round ceiling cover in my OTR Samsung smh9187 has always been missing the locking clip/screw and has gotten loose but was easily turn back in position, yesterday it came loose and fell down ,...
Microwave ovens have special coatings on some of the interior panels and covers to prevent arcing. If there was arcing then that can cause the main component in the oven to fail and be expensive to replace. IF you do keep it you have find what is arcing and repair that.
Dec 27, 2014 | Microwave Ovens
I have a Sharp Carousel Microwave R-1460A. The disk on the ceiling, opposite the warming plate and about the same size, has severe burn marks (probably from food splatters). Any idea what that part is
see this indication and fix it. God bless you
  1. Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  2. Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  3. Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity pain
Nov 08, 2013 | Sharp R-1460 Microwave Oven
How to remove the round disk from ceiling of the ge profile spacemaker xl1800 microwave?
mine had a small round plastic push in pry out retaining button on the frount side of the disc once that was removed the disc turned out of its locked position & droped out
Oct 16, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave stop working the clock and timer works but food is still cold. (The round cardboard piece on it's ceiling fell off about 3 months ago.)
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 09, 2010 | Sharp R-1480 Microwave Oven
GE Profie JE1860SH 04 microwave sparks
Our JE1860SH was also sparking after a few seconds. The GE tech pulled the upper round disk and found the problem. The plastic was burned and the round metal which is behind the plastic dome was arching with the frame. Lasted seven years expected more especially from a GE product. So my suggestion is to remove the dome and check it out.
Jan 03, 2010 | GE Profile Spacemaker Over-the-Range...
There is a round silver disk (seemingly made out of card board) that fell off. Can it be replace with another cardboard cut out in the same shape?
the disk is just a microwave diffuser but, it is made with a special foil do not put regular foil into a microwave for any reason; just glue the disk back on with ordinary glue
May 20, 2009 | Microwave Ovens
Plastic melted inside oven, dripping from ceiling Kenmore 721
Apr 21, 2009 | Microwave Ovens
Replace burned inside ceiling of microwave?
Do Not Use The Microwave. If You Need Parts Try Finding A Part Number And Use Ge To Order Parts. Click Here To Order Parts
Jan 15, 2009 | GE JEM31 Microwave Oven
Nov 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
62 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
